#451 | |
Re: LFD's 4dr Tahoe Build
Now for the fun part I get to spend most of tonight with the Plasma making all my parts and pieces for the other side so it all matches and still add 1 or 2 gussets to this rear mount. I hope to have my Re8's soon so I can start mocking up placement and ratios and see what is left for the shock placement. Kevin LFD Inc. |
#452 |
![]() Join Date: Mar 2007
Can you share what sizes you are using for the Hiem joints for the track locater? Are they 5/8x5/8" and is the tubing 1" ID? I'm about to order the supplies for my IRS and I wondered what you went with.
Ryan 84 ![]() My reBuild: http://67-72chevytrucks.com/vboard/s...d.php?t=346328 |
#453 | |
I have not ordered mine yet. I will be calling in the morning to see what will work best for my set up. If you are doing this in a truck I would use the stock rear diff cover and just raise the frame 4" and use the stock set up for the track. I only went through this in order to keep the rear floor as low as I could for the rear seat my wife wanted. Kevin LFD Inc. |
#454 |
Kevin,
Do you need a slam bag rs8 for mock up I have three in my garage and one is damaged to use for mock up welding purposes! Tony from Norcal |
#455 | |
You did mean to say RE8 right? Thanks Kevin LFD Inc. |
#456 |
![]() Join Date: Jul 2006
Hey Kevin this suburban is so ambitious. The rear hatch with hidden hinges is great. I was wondering if you are going to do something slick with the tail lights. I always thought there was too much metal around the lenses. Maybe a larger tailight that appears stock would fill the void. Just thinking outloud. Anyway great job with all your work. I will keep tabs on your progress.
#457 |
Restoring a 68 SWB
I am still holding you to the CHEVROLET lettering across the back
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor Last edited by tdave00; 03-18-2009 at 08:15 PM. |
#458 | ||
![]() Kevin LFD Inc. |
#459 | |
Restoring a 68 SWB
![]() Thought you said you had one upstairs you were going to use? Everything looks great BTW.
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor |
#460 |
Seņor Member
Find a couple of old beat up gates and stitch parts of each together to read C H E R V O L E T
#461 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#462 |
VA72C10
![]() Join Date: Mar 2008
Or, check with NWD02...he's putting in a panel with the older chevrolet script so he might be willing to hook you up with the original letters. I have a gate that the letters are pretty good on but the bottom's rotten that I could cut out the letters for you...but shipping would probably kill the deal for you.
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#463 | |||
![]() Quote:
Kevin LFD Inc. Last edited by Rokcrln; 03-19-2009 at 07:51 PM. |
#464 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Whos truck are the backwards stuff going into..?
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#465 |
Gate is on the Blazer I sold to Hickman and the dash is back in my attic
#466 |
Well I think for sure today was the hardest day of this build so far, but I got it. I was working on the front 4 link bars for the C4 and had a heck of a time in trying to keep the bars low and still maintain the smallest amount of front to back wheel travel during the full range of up and down wheel travel. I started out with equal length bars and had them parallel to the frame and that gave me over 1 1/2" of front to back wheel travel through the 10" of travel. After allot of different set ups and allot of thinking I ended up with 30" top bars and 31 1/4" lower bars. They are parallel to the ground at ride height and during the full 10" of travel my front to back movement is less then 3/8" total. I have it set up for the wheel to be centered in the wheel well at full dump and at ride height it is back 5/16".
Here are a few shots with the laser set up for checking the final configuration. First shot is full stuff and the laser is dead center of the hub Axel nut. Next is ride height and a close up of the tape. Then the last hub shot is at full lift and it is once again perfectly centered. I still need to play with my track bars abit because I am getting a few degrees of tow change during full travel and I think I can get it all out with some more work. If I can get it to zero it will also decrees the 5/16" number a very small amount. Kevin LFD Inc. [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() |
#467 |
So in order to make it all work I had to bring the top bars into the floor by 2". This really won't be a problem because my seat mounts are just above this and will still allow for a sheet metal cover over the seat mounts and top bars and the seat will still lay forward and down flat like it should. I will make some simple covers to go over the bars but leave access for the bolt to be removed. The upper bar has to have a down ward bend to it in order to clear the rear floor step structure and also to keep the bar below the magic 2" floor #. I will bend this bar in my hydro bender but first I will sleeve the inside of the 1 1/4" tube with a .120 wall 1" on the inside then if I feel it is needed I will add a gusset blade to the bottom of the tube.
The lower links are parallel to the ground at ride height and are angled in to the frame about 3"+- at the leading end of the bars to minimize the front to back travel of the hub during the up and down travel. I have 10" of travel 5" each way from ride height and that should have the frame 1" off the ground with a 31" tall tire and 6" of frame clearance at ride height. Kevin LFD Inc. [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() |
#468 |
nice work, its lookin real good
#469 |
Check this out. I'm putting it on my tail gate. Something a little different... MEKDAD machined it for me.
#470 |
The LuvShack Garage
Looking good LFD
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#471 |
![]() Join Date: Apr 2004
Looks good Kevin.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
#472 |
#473 |
I know not much but it was my evenings work all the same. I finished welding the bars and added a small brace to the two bent arms. Here is a pic of the section I cut out for the poly end to weld to so you can see what is on the inside. The sleeve runs from the ploy end to 4" back from the rod end. Combined it is just over .250 thick and I will add 4 plug welds on each side of the bend to lock it all into one piece. I am waiting on 3 new threaded ends that I should have on Tuesday so I can finish up these bars and start on the toe in/out bars on the diff cover.
Kevin LFD Inc. [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() |
#474 |
![]() Join Date: Nov 2008
Wow Kevin, that IRS is sure taking you lots of hard work, evrybody can weld but not evryone can design. Im pretty sure your 5.3 conversion will be easier
cant wait for that! ![]() |
#475 |
It sure has been allot more work then I was thinking but it is still worth every bit as I see it coming together. If I would have just been ok with cutting up higher in my floor this would have been allot faster and easier but I want a certain look when it is done so I brought it on my self. I too believe the 5.3 swap will be a cake walk especially with PorterBuilt's C4 Drop Member that is on it's way. I still have a few trick up my sleeve that will add extra work but it will all be worth it in the end. Thanks for checking in somtimes I think I am just posting this for my self
