Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 04-26-2014, 10:32 AM   #451
blfuller123
blfuller123's Avatar
Re: 72 Dropmember Suburban
Went to the Pate swap meet yesterday and got a good deal on a carb. The one I had didn't have the choke on it and needed a rebuild.
blfuller123 is offline   Reply With Quote
Old 04-26-2014, 06:53 PM   #452
jtp67-72
jtp67-72's Avatar
did u buy it from CFM motorsports??...he's one of my vendors at conroe....good guy....jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 04-26-2014, 08:48 PM   #453
blfuller123
That was the guy.
Spent the day getting all the seats and console holes drilled so I could get the carpet in. After all that, I realized the carpet I got was for a low hump, not the high hump that I ordered. I called the place I got it from and they are supposed to order carpet again Monday and they said it may be in this weekend.
I did get my slosh tubs pedal cover polished and installed.
Old 05-02-2014, 12:14 PM   #454
ebustos
nice build. how do you like the vhx gauges.
ebustos is offline   Reply With Quote
Old 05-02-2014, 01:05 PM   #455
blfuller123
Thanks, I love them
Old 05-02-2014, 02:52 PM   #456
Stickman
Stickman's Avatar
Just sat down and went through the entire build. You are doing a hell of a job and your Burb is absolutely beautiful.
Stickman is offline   Reply With Quote
Old 05-02-2014, 03:01 PM   #457
blfuller123
Im slowly knocking down my to do/to get list. Im hoping to drive her this summer.
Old 05-06-2014, 02:21 PM   #458
ebustos
once again nice build. I was just wondering how and where you mounted the elevel sensors. Also what aluminum dash bezel is that. I thinking of switching my autometer gauges to the vhx. If you can post pics that would be great.
Old 05-06-2014, 03:07 PM   #459
blfuller123
Thanks! Here is a picture of the right rear elevel sensor. I don't think I have a picture of the front ones. Ill take one when I get a chance.
The aluminum dash I got from someone locally but I believe its the same one LMC and the other companies sell.
Got some more parts ordered. I should be home for a while in a week or two to get some work done.
Old 05-12-2014, 04:40 PM   #460
blfuller123
Seems like every time im heading out of town, parts come in.
Got the rear ac cover I bought. Im hoping to get an Old Air evaporator that will wit under it. If not, I will continue to look for a factory one.
Front brakes got here too.
Will be another week or two before I get this put in.
Old 05-12-2014, 04:44 PM   #461
kikkegek
kikkegek's Avatar
nice score!
what is that air-evaporator? I thought water evaporated? hahaha...got any info on that? is that an early A/C option based on water evaporation?
kikkegek is offline   Reply With Quote
Old 05-12-2014, 04:46 PM   #462
blfuller123
Originally Posted by kikkegek View Post
nice score!
haha, sure is. Like a swamp cooler
Old 05-12-2014, 04:47 PM   #463
kikkegek
kikkegek's Avatar
cool (literaly :-) )
Old 05-12-2014, 04:57 PM   #464
blfuller123
I think I can make this kit work http://www.oldairproducts.com/catalo...it-p-4509.html
When I get back, Old Air isn't too far from me, I may take the cover up there and see if they have a demo unit that I can look and see if it will work.
Old 05-14-2014, 04:53 PM   #465
blfuller123
Im ready for music now. These came in the other day and I painted them to match everything else inside.
I ordered some license plates to put on if I go to a show. They are just plastic but I think I am going to glue some magnets on them so I can just stick them to the real plates.
Old 05-14-2014, 05:06 PM   #466
kikkegek
kikkegek's Avatar
Old 05-15-2014, 09:43 AM   #467
blfuller123
I didn't cut the dash and I got the radio installed. That is something that should have been done before I put the ac in but its in.
I wish I could have gotten it with blue lights, but it will work.
Old 05-15-2014, 08:30 PM   #468
blfuller123
Spent the better part of the day working on getting the brakes put on. I only got one side done. I ordered the spindles for a 72 and apparently I had 63-70 ball joints. I had to pull the lower A arm to swap out the ball joint which meant I had to take the header loose to get the mount A arm bolt out. Im hoping to get the other side done tomorrow.
While the truck is on jack stands, I still have a lot to the under side so before I take it off jack stands, im going to try and finish that all up too.
Old 05-15-2014, 08:37 PM   #469
jkeating1
jkeating1's Avatar
You're a machine!
JK
jkeating1 is offline   Reply With Quote
Old 05-17-2014, 04:29 PM   #470
blfuller123
Got the correct carpet and it installed.
Old 05-18-2014, 12:57 AM   #471
smbrouss70
smbrouss70's Avatar
What color carpet did you use with the parchment seats? It looks good.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 05-18-2014, 10:01 AM   #472
Hart_Rod
Hart_Rod's Avatar
[URL=http://s1127.photobucket.com/user/blfuller123/media/72%20Suburban/accover_zps53881604.jpg.html]
Burg looks great! You should have someone pull a fiberglass mold off of that cover. I bet you could sell a ton of them....
Hart_Rod is offline   Reply With Quote
Old 05-18-2014, 10:52 AM   #473
kev2809
low n' slo
kev2809's Avatar
man that looks great!
did you buy the full carpet set or just the front and the middle?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 05-18-2014, 11:13 AM   #474
blfuller123
Thanks, the carpet is ACC brand and it is cutpile 7075 Oyster/Shale
Thanks, I hadnt thought of making a mold. I don't know anyone that could do it.
Might be a cool idea, maybe make it just a little larger to make an aftermarket evaporator fit in it, could add a rear dome light and speakers...hum Know anyone that can do it?
Thanks, I bought carpet for just the passenger area and it came in two pieces and I also ordered the matching floor mats. I really like the carpet!!!
Old 05-18-2014, 02:31 PM   #475
jtp67-72
jtp67-72's Avatar
Never been much on the plaid.....but you and Losh have made me a fan!.....love it...that oyster color was popular in 70's and early 80's vettes....always liked it...jim
