#451 |
Re: Brave or crazy? crewcab build
#452 |
![]() Join Date: Jan 2013
Looking good sir! One of these days you'll have to let me stop by and inspect your amazing work!
__________________________________________ AmericanThunder Project Booger Build Thread |
#453 |
#454 | |
#455 |
Prestige Worldwide
![]() Join Date: Feb 2001
Looking good, very impressive fabrication!
#456 | |
Thanks, hopefully I can get back to it soon. |
#457 |
It's been awhile since I've posted any progress pics not much to show.
I have been working on another 4th door because the first one was buckled in the middle and did not fit quite right. So I found another clean drivers door and cut it down the same way I did the first one. this one fits much better. Still a long way to go on the door but its a better door to start with. |
#458 |
Its still looking good sir!
-Rus |
#459 |
Agree with Rus! Awesome truck bud!
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase 1955 Chevy Stepside "Dudley" My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288 1972 Chevy C10, Project "Chevro~Layed out" Nether Storm Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523 |
#460 |
I want to encourage you, this is an awesome project, keep the momentum going!
You are doing a really nice job with the cab and the hard part is almost over. I'm looking forward to the rest of the build. |
#461 |
Wow this is like the coolest build ever. Can't wait to see it finished. Keep up the momentum.
~ It's a Learning Process ~ Click Here for my Blazer Build: 1971 Blazer 4x4 Click Here for my Work Truck Build: 1970 C10 LWB Toys: 1970 C10, 1971 Blazer 4x4, 1976 Corvette Stingray L82, 2011 Cadillac CTS 6 speed, 2008 VTX 1800F |
#462 |
Luv the Crewcabs
Great Work...............
I love how some Guys make it look so easy............... Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
#463 |
Worked on the 4th door a little yesterday lowered the upper hinge 1.5 inches to match the other side. I also had to cut into the hinge support on the inside so I rebuilt that. Then I tacked the door back together to ckeck the fit again.
#464 |
Junk Yartist
I ended up building a whole new hinge area mount. I couldnt get the pivots to line up because the front doors are at a slight angle. Fussed with it for days.
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#465 |
Spent about 5 hours today working on the truck.I got alot done mostly small detail stuff. Since I moved the hinge down I had to weld up the old holes on the b pillar. then i mounted the door and re fit it. fits pretty good still need the rear section of a passenger side door to get the shape of the door to match the front door. anyway here's a few pics
#466 |
Check out how Rokcrln did this door http://67-72chevytrucks.com/vboard/s...=188993&page=4 Nice build by the way
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
#467 |
I'm glad to see you are still determined to finish the 4th door and continue with the build.
What you are attempting is difficult to say the least and you seem undaunted by the challenge. Once you have finished with the 4th door and have 4 swinging properly working doors you can look upon your work with pride knowing you have accomplished what very few men before you have even attempted. I'm looking forward to seeing your accomplishment. Last edited by Xeen; 09-21-2013 at 11:22 PM. |
#468 | ||
I plan on doing mine the same way he did. Quote:
Thanks, I am determined to finish the door I just haven't had a lot of time to work on the truck and I feel like i'm slacking! |
#469 |
Great progress! I have to try building a crew cab some day
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
#470 |
Well I picked up the door section I needed for my 4th door.
All I need is the inner panel so I ground the edge to split the outer skin. Then they just pulled apart, This door had a little more rust then I like but it will be a easy fix. hopefuly more updates by the end of the weekend. |
#471 |
More progress! Woot. Keep up the awesome work bud.
#472 |
I only got about 3 hours of work in on the 4th door but I made a lot of progress.
I was able to graft in the rear of the passenger door to the front of the 4th door. It took alot of trimming and fitting but looks good, I still have to hang it on the cab to recheck fit. Then I will reshape the upper curve of the door to match the front door. Look at the last pic and this door now has 2 door lock rod holes, of course one will go away but looks funny right now. |
#473 |
one more pic check out the scrap pile, this shows how much trimming I did to make this fit.
#474 |
![]() Join Date: Feb 2005
Nice work man...I spy a 36 in the background is that yours?
#475 |
