Old 05-02-2015, 04:40 AM   #451
m.o.t
Re: Dutch '59 Fleetside Longbed
You're doing a great job Kees!
Just take care of yourself ..
Truck will be awesome!
grtz
m.o.t is offline   Reply With Quote
Old 05-02-2015, 07:53 AM   #452
Advanced Design
Advanced Design's Avatar
Hope you get better quickly Kees!
Advanced Design is offline   Reply With Quote
Old 05-02-2015, 08:32 PM   #453
Kim57
Kim57's Avatar
Take care. The truck will always be there.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 05-15-2015, 05:48 PM   #454
RockinKees
RockinKees's Avatar
Hi you all !
I'm back
So to get right to the point where I left:
I did get the swing pedal in with the bracket between firewall and steering column:
I even managed to get the parkingbrake assembly at it's original place!
I don't know if I can get the parkingbrake lever to work, but I find it a very nice item to have in the truck.
The swing pedal is made from the original brake and clutch pedal, welded together, you see I recycle stuff
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 05-15-2015, 07:03 PM   #455
Advanced Design
Good to see you back Kees! Nice work on the brake mechanism.
Old 05-15-2015, 11:23 PM   #456
oldman3
oldman3's Avatar
Hey Kees, happy to have you back and posting again. Oh yeah, nice work...Jim
oldman3 is offline   Reply With Quote
Old 05-16-2015, 06:35 AM   #457
RockinKees
RockinKees's Avatar
Thanks Doug and Jim, happy to be wrenching again!!
Those last pics are before the body went down.
So, now with the new things, I was given a nice old steering wheel from my buddy Niels, made it fit to an adapter so I can get it on the column of the old Chevy Van:
I had a few aluminium things lying around that I could use to make a large shim between the steeringwheel and the adapter:
I grinded (or ground, what is it??) the back of the wheel flat, and turned a shim to get the whole surface to be used at the adapter:
Fits great!
Next I put the column in to see what modifications I have to make:
You see, the column is a bit long....
I have to shorten it by 5,5"
Anybody did this or have good tips??
I did a search on this, but didn't get a step by step...
Only thing they all say is to sleeve the steering shaft.
That isn't so hard to do
Maybe I just go ahead with it and see where it ends, worst thing what can happen is to buy a new one
I must say, it looks good in there
Just make my own hornring to finish it off.
Cheers!! Kees.
Kool Guyz CC
Old 05-16-2015, 06:54 AM   #458
m.o.t
Smile Re: Dutch '59 Fleetside Longbed
Oh...He's back!! ..with a vw wheel?
Old 05-16-2015, 07:00 AM   #459
RockinKees
RockinKees's Avatar
Yep, VW, me as an old VW driver thought it was a good idea
Plus I can't afford a Bell Air steering wheel....
It has the right diameter, looks old and it will be great when finished!!
Cheers!! Kees.
Kool Guyz CC
Old 05-16-2015, 09:00 AM   #460
oldman3
oldman3's Avatar
Nice mod to the wheel...Jim
Old 05-16-2015, 10:05 AM   #461
Kim57
Kim57's Avatar
Glad you're back at it.
Looking real good.
I like the wheel.
Kim
My build thread
Old 05-16-2015, 05:20 PM   #462
RockinKees
RockinKees's Avatar
Looking real good.
I like the wheel.
Kim
Thanks Kim!!
Cheers!! Kees.
Kool Guyz CC
Old 05-16-2015, 07:05 PM   #463
Steve-W
Steve-W's Avatar
good to have you back Kees! and nice to see you haven't lost your touch
Feedback is always welcome!
projects:
1969 Chevy C10
1950 GMC 100
1958 Chevy C60 Viking ratrod
Steve-W is offline   Reply With Quote
Old 05-18-2015, 11:53 AM   #464
RockinKees
RockinKees's Avatar
Started slowly today, as always
Last Friday I cleaned the underside, put some rust converter and later some primer on it.
So this morning (at noon....) I sealed the whole underside of the body, the cowls and the firewall.
After sealing, while I was waiting the seal to dry, I started on the trans cover. The old one is butchered by the PO, so I thought of making a new one:
You see the old one isn't much anymore.
I took some 14 gauge steel and the old cover, I will marry the two
When the sealing was dry, I primered the underside:
Now let the primer dry, then I will spray stoneguard (paintable) rubber undercoating, and after that a layer or two, three black paint.
I then have three layers of primer, undercoating and a few layers black paint.
I think that should do it for a while.
When that's finished, I will put the engine back in place for the last time
Moving forward again
Cheers!! Kees.
Kool Guyz CC
Old 05-18-2015, 12:09 PM   #465
Katrina/10
Katrina/10's Avatar
That's going to be a great truck when you get it back on the road. What kind of primer is that? Definitely should not rust after you put all the coatings on.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 05-18-2015, 01:08 PM   #466
RockinKees
RockinKees's Avatar
It's just Hammerite. The rust converter is from Wurth.
Cheers!! Kees.
Kool Guyz CC
Old 05-18-2015, 04:14 PM   #467
Steve-W
Steve-W's Avatar
Originally Posted by RockinKees View Post
It's just Hammerite
Huh...there is a primer from Hammerite?
projects:
1969 Chevy C10
1950 GMC 100
Old 05-18-2015, 05:37 PM   #468
Kim57
Kim57's Avatar
Nice progress.
Kim
My build thread
Old 05-18-2015, 05:56 PM   #469
Advanced Design
That is a lot of progress Kees. Good work!
Old 05-18-2015, 06:52 PM   #470
oldman3
oldman3's Avatar
Kees, looks good...Jim
Old 05-19-2015, 09:35 AM   #471
reaper71
reaper71's Avatar
Looking good Kees! few steps closer!!
Mark...
reaper71 is offline   Reply With Quote
Old 05-25-2015, 03:15 PM   #472
RockinKees
RockinKees's Avatar
Small update from last Friday:
The whole underside has recieved 1 layer of rust converter, 1 layer of primer, all seams are sealed with paintable body kit, 1 layer of primer again, sprayed over with paintable underbody rubber coating, after all was dry, I put 3 layers of shiny black paint over that
Now it all is drying
These pics are taken after one layer of shiny black, after that there are two more layers.
Next is to clean the engine, replace the timingcover with seals, put on some headers and place it back in the frame.
Then I must make an exhaust ( I made a new thread about where to place the mufflers...)
Plumb the brakes, shorten the steeringcolumn, and.....and......and....
We're getting there in the end
Cheers!! Kees.
Kool Guyz CC
Old 05-25-2015, 10:06 PM   #473
Kim57
Kim57's Avatar
Coming along nicely.
Kim
My build thread
Old 05-25-2015, 10:19 PM   #474
Advanced Design
Looks really good, the floor is well protected Kees.
Old 05-29-2015, 12:16 PM   #475
RockinKees
RockinKees's Avatar
Been busy with the engine today.
Cleaned it and bolted a new timingcover with new seals and gaskets.
Took all of the unneccessary bits off to get a cleaner look after I'm finished with it.
It's got a nice new coat of Chevy Orange, and painted the trans also in that color.
Planning is to put the motor back in Monday night....
Cheers!! Kees.
Kool Guyz CC
