Old 12-04-2015, 04:39 PM   #451
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Originally Posted by Dieselwrencher View Post
Very nice! It's getting real close now!
Thanks Not much more to figure out then assembly and wire.
Originally Posted by Chance48 View Post
Looks great, that is the same valve I'm gonna use for bias. Can't wait for some vid of your first burnout!!
The tires that are on it now where just to build with. I'm hoping for a 3rd gear burnout in there future.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 12-04-2015, 05:16 PM   #452
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Originally Posted by 99 to Life View Post
I wish I could be of more help there. As my first bagged ride still hasn't hit the road (though very very soon it will) I'm running sleeves in the back so its gonna differ from your monsters. I feel 2600lb bag up front and sleeves is about 60/40 front to back. I just never hear of guys running over 100psi up front but you might find some info out there where guys are. If you just put a put a cup in there, I think that would help you out alot. I'm running cups top and bottom. I had to angle cut my bottom cup to work with my stock lower control arm. which you prolly won't need to do with yours.
I have to apologize to 99. He was giving me advise about the air bags and I was wrong on a few things. First I have 2500 bags up front and 2600 in back. Also I added a lower cup on the front this week so the bag was not so extended and gave them an angle cut to level out the bottom of the bag. I also don't need as much psi to get to ride height like 20psi less. I feel much better about this setup now. Thanks to everybody's advice and knowledge I do listen to everything, I just might be stubborn sometimes. This is my first build it has been a huge learning curve. Man I can't wait till spring when this thing will be rolling down the rd.
1951 MG TD
Old 12-05-2015, 12:39 AM   #453
99 to Life
99 to Life's Avatar
Re: My 52 GMC Build
no sweat man, if I run 60 psi up front on my 2600 lbs bags its a little bouncy. I run a little too much air in my rear sometimes too, could def use about a 1inch cup for those but its still comfy when I get it set right. Just make sure you got some room up front, almost a finger width would be good so your bag doesn't rub. I'd highly rec a 2600 up front, esp if you drive it and it feels stiff or bouncy.
Coming along great though. Driving them is fun, but the bugs can sometimes keep lingering!!!
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 12-05-2015, 01:35 PM   #454
Coach529
Coach529's Avatar
Re: My 52 GMC Build
That is something I have never really given a lot of though to. Dialing in ride height and pressure, etc.
Is there a spec for the bags? For example X brand bag, 2600lbs, work best when height is between 4" and 6".
Does that makes sense??
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 12-05-2015, 11:05 PM   #455
99 to Life
99 to Life's Avatar
Re: My 52 GMC Build
Unfortunately I don't think there is that magic number you are looking for, perhaps there is if everyone chimed in and gave exact specs. but that is the number one issue, not everyone has the same set up. For example, I used s10 chassis with stock lowers, angle cut bag cups, airlift 2600 bags and about 3" or less with my body off frame.
So the frame swap stuff I feel will be a little over the place, M2 kits on stock frames might yield more consistent numbers.
The key is to have as little pressure as you can get at your desired ride height, the 2600lb bags let you get same height as a 2500 with less pressure. One thing that is common is the pressure numbers. I hear a lot of 60 up front and 40ish in back. So I'd say start with 2-3" bag cups and cut down if necessary.
I was unsure as well, having no idea what pressure I'd be at for every inch the truck went up. Its going to be a lot of trial and error and really isn't an exact answer all the time. but that is the beauty of it, all the variables, not a dead set rule book all the time.
Old 12-05-2015, 11:47 PM   #456
Coach529
Coach529's Avatar
Re: My 52 GMC Build
Thanks for the info. Always fun to learn and figure out something new. I will definitely keep you posted on what I find!!
1949 Chevy 3600
Old 12-06-2015, 11:04 AM   #457
Chance48
Re: My 52 GMC Build
Good info guys....hope that works for ya lowers. I'm glad I went with 2600's thanks to you, now I just gotta get them in and adjusted properly.
SHAKE N BAKE BABY, SHAKE N BAKE....
http://67-72chevytrucks.com/vboard/s...d.php?t=686729
Chance48 is offline   Reply With Quote
Old 12-07-2015, 08:24 AM   #458
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks for that guys!! I feel much more confident in my setup now. If I have to redo for some reason ill modify for 2600 bags. So even with all the variables involved if someone built 2 identical trucks the pressures should be the same right?
1951 MG TD
Old 12-07-2015, 11:31 AM   #459
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Here is a brain scratcher question: What is this? I have been looking everywhere for it. It was mounted on the running board of my 1950 gmc I had before my '52. I'll have the answer tomorrow and good news.
1951 MG TD
Old 12-07-2015, 11:45 AM   #460
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
Re: My 52 GMC Build
I recognize the housing, it's a universal truck style license lamp, my old C3500 had that as a rear plate lamp ... why it would have been on a running board? Some kind of truck numbering or license that was supposed to be illuminated??
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
Old 12-07-2015, 11:52 AM   #461
RockinKees
RockinKees's Avatar
Re: My 52 GMC Build
The only thing I can come up with is this:
But Minions is probably not the right answer??
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 12-07-2015, 11:57 AM   #462
oldman3
oldman3's Avatar
Re: My 52 GMC Build
Good one Kees...Jim
oldman3 is offline   Reply With Quote
Old 12-07-2015, 12:44 PM   #463
YukonXL04
YukonXL04's Avatar
Re: My 52 GMC Build
Someone added running board lighting? lol maybe they wanted to see the step at night
YukonXL04 is offline   Reply With Quote
Old 12-07-2015, 02:55 PM   #464
Advanced Design
Advanced Design's Avatar
Re: My 52 GMC Build
I am going with what Kees said.
Advanced Design is offline   Reply With Quote
Old 12-07-2015, 03:53 PM   #465
70chev383
70chev383's Avatar
Re: My 52 GMC Build
Sweet build!
70chev383 is offline   Reply With Quote
Old 12-07-2015, 07:59 PM   #466
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: My 52 GMC Build
I also was going to say an old license plate lamp housing.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-08-2015, 09:25 AM   #467
lower50's
lower50's's Avatar
Re: My 52 GMC Build
You are ALL correct!! It is a 1949-1950 CHEVY LICENSE PLATE LIGHT.
I have been looking for this for quite a while. This past weekend we went and visited my father in law. Having a beer in his garage he pulls out a old box and says do you want these? He said he has been holding onto them for some reason for about 30 years. He never knew I was looking for them.
1951 MG TD
Old 12-08-2015, 05:30 PM   #468
Dieselwrencher
Re: My 52 GMC Build
What are the odds of that huh? Cool deal!
Ryan
Old 12-08-2015, 06:37 PM   #469
Advanced Design
Re: My 52 GMC Build
Score! It was meant to be.
Old 12-08-2015, 10:09 PM   #470
99 to Life
99 to Life's Avatar
Re: My 52 GMC Build
great coincidence! I must say, I'v searched and bought and built these for the last 5 years and I haven't ever seen those. Very cool to learn about the little details.
Old 12-10-2015, 09:40 AM   #471
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Ya I could not believe it.
Sure sounds like it.
It was cool. Now I have no idea what kind of chevy. I searched for the lights and searched vehicles. I can't find any thing else about them, but they where from a '49-50 chev.
1951 MG TD
Old 12-10-2015, 09:43 AM   #472
lower50's
lower50's's Avatar
Re: My 52 GMC Build
All ready to bleed the master, then the brakes. Fingers crossed for no leaks.
1951 MG TD
Old 12-12-2015, 11:12 AM   #473
Chance48
Re: My 52 GMC Build
Nice find! Man you're getting close....
Old 12-15-2015, 12:54 AM   #474
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks Chance!!
So Friday eve my GF and I started to bleed the brakes. Yup Friday night date in the garage LOL. Bleed master then bleed brakes, down-up, down-up. No bubbles all good. No peddle no good. Call it a night. Sat bleed master again finger over port method got some bubbles. Bleed brakes I can get peddle with 3 pumps. Monday eve pressure bleed, pump up crack line. Got bubbles Now I get peddle on second pump. I am thinking because everything is new there are bubbles hiding. I'll try again Tue eve. I have no leaks so that part is good.
1951 MG TD
Old 12-15-2015, 01:18 AM   #475
99 to Life
99 to Life's Avatar
Re: My 52 GMC Build
I figured you would have a good handle on your brakes, not that you don't. I refrained from saying, I had no luck bleeding my master while it was on the truck. Not saying that that is your problem, but having it one the bench, you can def make sure you're pushing the plunger completely in. Maybe try that, but if your getting fluid to your lines, its a good sign. I'v had two sep times not get fluid fully to lines and I took MC off and bench bled, solved problem both times. No leaks is good, Im sure its just a bleeding issue.
bagged, build, diesel, gmc, hot rod
