Old 02-25-2006, 01:25 PM   #26
Hart_Rod
Hart_Rod's Avatar
Re: kp components weld in step notch
Originally Posted by XXL
The third member will bang the body tub before you even get to a c-notch (like the CPP bolt-in c-notch).
On my 69 Burb, the center section touches the floor about 1/4 of inch prior to hitting the bumpstops on the CPP bolt in notch. Not sure about on the trucks.
Rob
Hart_Rod is offline   Reply With Quote
Old 02-25-2006, 05:09 PM   #27
XXL
Seņor Member
XXL's Avatar
Rob
My original comment may have not been clear... we're saying the same thing. On the trucks, you hit even faster if you have a wood bed.
XXL is offline   Reply With Quote
Old 02-25-2006, 05:30 PM   #28
bagged74
its just $$$$$
bagged74's Avatar
I dont mind cutting a hole in the body for clearance, I was jsut wondering if you could use this big of a notch if the bags are mounted in the stock location. I dont want to put in a big notch if the smaller one will be sufficient.
bagged74 is offline   Reply With Quote
Old 02-25-2006, 08:37 PM   #29
72MARIO
72MARIO's Avatar
I second that.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-27-2006, 10:39 PM   #30
jlaird
jlaird's Avatar
clint, I sent you an email about the notch. Be on the lookout.
Thanks,
Josh
jlaird is offline   Reply With Quote
Old 02-27-2006, 11:03 PM   #31
Kontrol Phreaks
Kontrol Phreaks's Avatar
I got it and will be getting back to you on that. Not going to be a problem.
Also talked to Tom71 today on the phone. Killer guy who is totally into the truck as we all are, and was exicted to hear and trade stories with me. Only draw back was he made me get back to work and stop talking C10 projects ... hahahaha Thanks Tom.
Clint Petree
KP Components Inc.
Kontrol Phreaks is offline   Reply With Quote
Old 03-07-2006, 10:28 PM   #32
tom71
what happened to flint mi
tom71's Avatar
no probs clint , i got my notch today im gonna install it this weekend
tom71 is offline   Reply With Quote
Old 03-08-2006, 03:05 PM   #33
424shee
this is kinda off the subject but I was just wondering what kind of wheels those are that are on the orange and the black truck?those are sweet!
424shee is offline   Reply With Quote
Old 03-11-2006, 04:04 PM   #34
tom71
tom71's Avatar
sweet572, i was mocking mine up this morning and it lloks to me like you would have to weld in the out side piece first then cut out the cross member where the shocks mount up , i would use a good air hammer and chisel them out , then weld in the the inner part of the notch and the top section ,(mine looks like it is gonna have to be trimmed to fit ) , then cut out the notch section of the frame . i had the ccp notch in and its not low enough for me , the cross member that mounts the shocks is gonna hit the diff any way , so in my opinion youre better off getting rid of it , its a bit more work but worth it. tom
Old 03-21-2006, 02:19 AM   #35
BigShoe24
True Addiction
BigShoe24's Avatar
Does anyone have any good install pics on this particullar notch. Thanks
BigShoe24 is offline   Reply With Quote
Old 03-23-2006, 01:04 PM   #36
BigShoe24
True Addiction
BigShoe24's Avatar
Sorry To post again, Im trying to attach my URL on here.
Old 03-23-2006, 01:44 PM   #37
randomhero472
randomhero472's Avatar
yes.. pics of the kit would be great!!
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 03-26-2006, 04:11 PM   #38
Beto
Originally Posted by Kontrol Phreaks
Here are some images of a 69 C10 that I built for a customer when I had my old shop. This truck is laid out on 22" wheels and uses KP Components brackets all the way around. Here is how our rear 60-72 Step Notch kit looks installed. You can see how the notch is designed to match the contour of the factory frame rails. It also has our Under the Bed floor kit installed off the front of the axle tube to locate the airbags. I went ahead and relocated the shocks off the back of the rearend, and had to shorten the pan hard bar as well.
If you have any questions about the truck, or parts used, please feel free to post them here. Or you can PM me and I will get the information over to you.
Clint Petree
KP Components
866-KP-LINKS
can anyone tell me if those are the stock trailing arms in this pic? Looks like they kept the trailing arms, and just added a notch with bags, and relocated the shocks, and also put in the panhard bar? is that right. I want a setup like that and need to find out what to order ASAP
Beto is offline   Reply With Quote
Old 03-26-2006, 10:28 PM   #39
randomhero472
looks to me like they are the stock arms, thats one slick truck.. very nice and simple design!
Old 03-27-2006, 12:08 AM   #40
Bagd72Chevy
C10 Collector
Bagd72Chevy's Avatar
Will these notches work with the ECE super track bar kit. I have this kit and it mounts the track bar to like the back of the trailing arm, by the U-bolts??
I really want to order KP's notch, but I need know if it will work. Or can someone close-up pic of the passenger side with the truck laid out?
Thanks guys,
Ryan
PS>in two weeks I get off for spring break and I'm laying out the truck> So quick help is appreciated.
Bagd72Chevy is offline   Reply With Quote
Old 03-28-2006, 12:46 PM   #41
tom71
tom71's Avatar
bagd72 , give clint a call his info is in this thread hes way cool and will answer any questions you have , i havent installed mine yet but the way it looked to me was that i would have to remove the cross memeber and track bar mount and re attach it (the track bar mount ) to the same location after the notch was installed . tom
71 swb 2wd fleet frame off in progress
72 4x4 blazer daily driver
70 olds cutlass s mint condition owned by a grandma
56 gmc 2wd project waitng
97 fiance mobile
Old 03-28-2006, 05:39 PM   #42
sweet572
i just got mine put on ill try and get some pics by tonight
sweet572 is offline   Reply With Quote
Old 03-28-2006, 06:43 PM   #43
Bagd72Chevy
C10 Collector
Awesome, thanks alot.
Old 03-30-2006, 08:16 PM   #44
sweet572
here is some of my notch and one of my truck i still need to add to the wiring and fuel lines and stuff like that all i did was notch the cross members slide the notch in then weld the cross member back up ill be happy to answer any ???? you may have eveything is in the stock location
Old 12-01-2006, 05:01 PM   #45
BigShoe24
True Addiction
BigShoe24's Avatar
Im going to install mine this weekend, I hope to upload some pics very soon.
Old 12-01-2006, 07:35 PM   #46
p-low
p-low's Avatar
i used this exact notch and it was pretty straight forward ...i talked to clint for a long time and he was super nice and informative......i used the deluxe trac bar and it barely misses...but on my truck i swapped the rear end out for a 5x5 gm 10 bolt and wen i welded on the trailing arm perches i moved them each in like 1.5 to 2 inches (cant remember exactly) to keep the trailing arms from interfering with the frame which caused me to have to section the trac bar and it worked perfect.....i also used the same brackets as the truck clint did (black one) which is actually the same truck as the orange one...as well at 2" blocks....this put me like 2-3" from laying out in the back on a 29 inch tire.....i can email pics if you guys want..... pm me
p-low is offline   Reply With Quote
Old 12-04-2006, 04:22 AM   #47
BigShoe24
True Addiction
BigShoe24's Avatar
So this is as far as I got this weekend. I want to run a simple set-up, but also want to have a qaulity truck. Any suggestions? Thanks
Old 12-04-2006, 04:24 AM   #48
BigShoe24
True Addiction
BigShoe24's Avatar
and
Old 12-04-2006, 11:15 AM   #49
bagged74
its just $$$$$
bagged74's Avatar
looks like you are headed in the right direction. Are you going to use the stock trailing arms?
Old 12-04-2006, 06:44 PM   #50
blazntn
Does anyone know Clints email address? I sent him a message on here and I havent heard back.
blazntn is offline   Reply With Quote
