08-24-2010, 10:36 PM | #26 |
Re: Help me build my rear end!!!
that's as much as my 9 inch and no where near the rear!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
08-25-2010, 01:04 AM | #27 |
My Carbon Footprint
Squats....leg curls......leg press......squats.......leg curls.......leg press. That should do it. Remember dumb and dumber? "Nice butt! Yeah....he must work out!!" lol |
08-25-2010, 09:08 AM | #28 |
Mean Green
your right. I didn't notice that was a bolt in. My bad
427 SBC 683HP & 590ftlbsTRQ @ fly wheel. 60'-1.38 1/4-10.43 MPH-124.6 New ET current 4/2019 AKA MEAN GREEN. |
08-25-2010, 10:20 AM | #29 |
I'd run the 9", locker, and a 3:70 - 3:90 gear with 33 spline axles, and disc brakes. Spools are nice, but hard on parts on the street with turns, and you know you will be running it alot on the street. DJ's rear is nice, and a Great deal, but I think it might be too much for what you want to do. JMO, and we all know what they are like! Good luck on whatever way you go!
08-25-2010, 11:20 AM | #30 |
Can you get a locker for 35 splined axles? Thanks for the all input.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
08-25-2010, 01:41 PM | #31 | |
"Where were you in '62?"
If you go with a Detroit Locker you will be pleased with it. My dad has one in his rambler! Listen to the tires squawl when the car turns! The legendary Detroit Locker began the revolution in performance differentials and still leads the industry today as an Eaton brand. The Detroit Locker is the most durable and dependable locking differential available. Most Drag Racers use them! The Detroit Locker maximizes traction by delivering 100% of the torque to both drive wheels. It is engineered to keep both wheels in a constant drive mode, and has the ability to automatically allow wheel speed differentiation when required. Applications are also available for C-Clip style axles. http://www.jegs.com/webapp/wcs/store...itemPerPage=90
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 08-25-2010 at 01:52 PM. |
08-25-2010, 01:51 PM | #32 |
Wide n'Low
They do make them for the Ford and the Dana 60 as well.. I did a hybrid of sorts for my truck, I used a 9 in. from a full size ford that has 11in. disc brakes. It gave me the big ford bearing ends, and disc brakes. I put them on a Dana 60 with 35 spline axles and a PowerLoc. My numbers should be similar to yours with my Procharger, and I was looking to built it once and forget about it.. Good luck on whatever you decide.
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
08-25-2010, 05:58 PM | #33 |
I thought that a detroit locker would be the ticket for the street but if the tire still grabs when you turn then all you did was pay 3 times as much as a spool and you still have a spool. I will sell mine without a center section or just without the spool.
I also have another set of axles for a barely narrowed nine inch but they are 5 on 4.5 lug pattern. They are gun drill star flanged moser 35 spline extreme axles with bearings and 5/8 studs. I would take 500 obo and they are 750 new with everything included.
08-27-2010, 06:39 AM | #34 | |
She only does it on hard turns.
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
08-28-2010, 06:56 PM | #35 |
My rear end from wheel mounting flange to wheel mounting flange is 56.75.
08-28-2010, 07:43 PM | #36 |
Thanks Kevin. That's going to be to narrow with the wheel offset I have. If only we could have done this 3 months ago.....
08-29-2010, 12:22 AM | #37 |
Robb is it close or way off?
08-29-2010, 09:12 AM | #38 |
My factory 71/72 rear is 63.5" wide. So yours would bring it in over 3 3/8" per side. I was only looking for about an 1" to an 1.5" per side. Thanks for measuring it. I'm sure you won't have a problem getting rid of it.
R/
08-29-2010, 01:56 PM | #39 |
10/4 I'll shorten it more and put it in Cade's truck if it don't sell.
08-29-2010, 02:00 PM | #40 |
I don't know if I would narrow it more. With a 12" wheel you could run a 5" Backspacing, which would be about perfect......
08-29-2010, 06:42 PM | #41 |
I want to be able to swap wheels from Cades truck to my truck so I want us both to have the same width wheel. I want a 12 inch wheel on his truck with only two or three inches of backspacing. I have a 16x15 wheel I'm gonna run.
