07-30-2012, 08:08 PM | #26 | |
Re: Stock air conditioning with LS swap
Installing a fan in front of the condenser will restrict airflow at highway speeds. Find the biggest 134a "parallel flow condenser" you can that fits your truck. Keep the "fin & coil" condenser...And change to R-12...Getting all the PAG oil out will be very important though. |
07-31-2012, 12:04 AM | #27 |
Hey clinebarger getting that pag oil out of the compressor will probably be almost impossible as the components inside will still be coated. What oil would one use to refill to be compatible with what's left over inside the compressor? My system was the ARA under dash which was the dealer add on I think my truck is a 69c10 ls conversion. Also when I reinstall this unit should I trigger one or both fans to come on while the a/c is engaged gonna keep it r12 I think or should I go 134? Oh yeah my motor is 06 ls truck motor and compressor thanks
Posted via Mobile Device |
08-01-2012, 01:09 AM | #28 | |
PAG OIL (Polyalkylene Glycol) Refrigerant oil made for HFC R-134a systems CANNOT tolerate even minute amounts of chlorides...It will "destroy" any PAG oil thats in the system. Chloride is an ingredient in R-12. Getting as much PAG oil out as possible....Draining the compressor, Replacing the dryer, & flushing the condenser & evaporator will go a long way. Whatever PAG thats left will "stick" to any aluminum surface it can find....as a black greasy film....Not ideal but doesnt really matter. R-134a will NOT hold in a ARA unit....They have "flare" type fittings. |
08-01-2012, 09:45 AM | #29 |
Then refill compressor with what type of oil
08-01-2012, 07:37 PM | #30 | |
08-02-2012, 06:21 PM | #31 |
Thanks looks like enough to put some in and re drain. How much should that compressor hold.
08-02-2012, 08:17 PM | #32 | |
I havnt seen any 525 mineral oil in smaller bottles. I change the oil in my vacuum pump with it...So it's never a waste. Last edited by clinebarger; 08-02-2012 at 08:23 PM. |
10-07-2015, 09:48 AM | #33 |
I'm finishing up an 82 with an 03 dbw truck 5.3 /4l60e and looking for help with the 03 high pressure switch to turn fans on with ac. Fans already working wired parallel but how do I get them coming on with the a/c. Any advice or links would be greatly appreciated. Thanks in advance to anyone who might be of assistance
10-07-2015, 11:41 AM | #34 |
[QUOTE=MB Customz;7333025]I'm finishing up an 82 with an 03 dbw truck 5.3 /4l60e and looking for help with the 03 high pressure switch to turn fans on with ac. Fans already working wired parallel but how do I get them coming on with the a/c. Any advice or links would be greatly appreciated. Thanks in advance to anyone who might be of assistance.
10-07-2015, 08:15 PM | #35 |
Old member
I used all the factory AC boxes but upgraded everything to 134A products. The air system system looks pretty much stock.
10-07-2015, 09:44 PM | #36 |
MB,
Check out my thread. Should be similar to what you have. http://67-72chevytrucks.com/vboard/s...d.php?t=468107 I use the stock pressure sensor and the ECM to control the fans according to the high side pressure, so either none, one, or two fans come on as needed. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
10-08-2015, 08:02 AM | #37 | |
12-09-2015, 04:11 PM | #38 |
I know this is an old thread but I don't want to make another thread since this is already on the topic. IBread through this and noticed everyone here was talking about using as much of the factory 67-72 AC boxes with the factory EFI LS motor and original compressors to the LS series motor. But for me I'm not running the stock/factory Intake and fuel injection or computer, I have a 67 with factory AC and At first I will run my engine carburated, (yes I know it's quite possibly the stupidest thing to do to an engine which is already fuel injected) I'm looking to find out how to hook up the factory AC of the 67, to the my 2002 5.3 from a silverado. I'm open to switching evaporators/condensor/reciver dryer to other units as long as they fit in the evaporator box and on the radiator support with little modifications, I would like to run 134a instead of r-12 and I know as of 1990 you need a low and high pressure switch so the system does not vent refrigeration out. Im also willing to getting a different AC compressor and bracket if there is one that can be used better or easier with the 67 then the one I currently have. I'm having some problems fitting the AC compressor bracket to the block with my motor mount plates as they stick out further forward, I was thinking about clearencing the bracket but I don't want to structurally compromise the bracket, what are your guys thoughts? I suppose there is the high mount AC option as well, but I do like how the compressor is tucked in out of the way with the low mount.
12-25-2015, 11:34 PM | #39 |
Ttt
12-26-2015, 10:01 AM | #40 | |
Old member
http://www.classicautoair.com/Chevy_..._Chevy_AC.html I used their kit at the bottom of the page. When I did the LS swap I had to buy a new bracket. LS1 bracket.
11-05-2016, 11:28 PM | #41 | ||
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
11-08-2016, 02:06 PM | #42 | |
As far as the pressure fault goes, there is a high/low pressure protection system built into the PCM. If the A/C pressure goes too high or too low (low is normal, just cycling the compressor on/off to prevent freezing the evap), the PCM will turn off the compressor. It will also cut off the compressor with WOT. Since we lose PCM control of this, you would need a low pressure and high pressure switch in the system, wired in series, to cut off the compressor in these situations. In my case, I used the factory low pressure switch (88' squarebody crewcab), and my replacement Denso 10S17F had a high pressure switch in the back of the compressor body (which cuts out at 455psi). So, I have 12v from the factory control head, through the low pressure switch, through the high pressure switch, to my relay, which controls the 12v+ side for the compressor. If any of the switches goes open, my compressor shuts off. |
11-10-2016, 12:05 PM | #43 | |
Thanks for the info. Does your compressor come on and stay on until you turn it off? Mine isn't it's cycling on and off and I assume it is being controlled by the computer, which would lead me to believe that it has some over/under pressure protection that is being provided by the PCM. But I would like to be certain because I don't want to damage anything. Thanks again. FYI, I'm using a 2006 Tahoe P59 PCM. More info here: http://67-72chevytrucks.com/vboard/s...=709611&page=2
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 11-10-2016 at 12:10 PM. |
11-13-2016, 03:40 PM | #44 | |
To confirm how yours is controlled, you'd need to trace the wiring. If the trigger wire to the relay is coming from the PCM, the PCM is controlling the cycling. For a 2006 PCM to do so, I believe it would need to have a serial A/C request in most cases. I have heard of a few cases where people were able to get the later PCM to accept a 12v+ A/C request, but in talking to a few tuners and harness builders, it was hit or miss on success. If the trigger wire is coming from the low pressure switch on the accumulator (assuming you have one, and aren't using a POA valve system), the cycling will likely be controlled by that switch. |
11-13-2016, 10:31 PM | #45 | |
My setup: 3 wire truck pressure transducer connected to plug from Speartech harness 12volt a/c signal from the VintageAir to Speartech harness green a/c request wire Two wire (green and black) plug to factory 2005 compressor from Speartech harness NO binary switch (in dryer not wired) Blue/Green PCM OS 12587811 & system 12591524 Compressor type - ANALOG
11-14-2016, 12:55 PM | #46 | |
11-01-2017, 11:23 AM | #47 | |
