Old 11-27-2011, 10:22 PM   #26
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: ls turbo build
Originally Posted by BR3W CITY View Post
Then they don't deserve the 6L, they should surrender all 6L engines directly to my PO box I will gladly exchange them for some 4.8's I saw sitting around.
I have a low mileage 4.8 I'll gladly trade for a 6.0 as well
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 12-21-2011, 01:24 PM   #27
duwem
duwem's Avatar
Re: ls turbo build
The reason why the Lq4 is boost friendly is the lower compression ratio to the LQ9.
duwem is offline   Reply With Quote
Old 12-21-2011, 11:04 PM   #28
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: ls turbo build
LY6 is similar...at 9.65:1 vs 9.4:1 for LQ4...tho it also has the genIV rectangular port heads and VVT.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 12-23-2011, 03:35 PM   #29
1moretoy
Re: ls turbo build
here is a pic of my ls1 motor with a turbo. Stock bottom end with a speed inc tu1 cam double spring kit and 60# injectors. I hope to be around 600hp with 6-9#'s of boost. running the stock 4l60e for now
1moretoy is offline   Reply With Quote
Old 12-23-2011, 06:23 PM   #30
69trk
69trk's Avatar
Re: ls turbo build
can you tell me what size turbo you are running? Also, with the fuel injection did you have to have the accelerator pedal from the donor vehichle? Which engine is it? thanks
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 12-23-2011, 09:19 PM   #31
1moretoy
Re: ls turbo build
it is a 70mm turbo and no I'm using the stock gas pedal in the truck
Old 12-23-2011, 11:09 PM   #32
68GMCCustom
Re: ls turbo build
motor looks sweet with that car intake and painted that color with the GMPP valve covers.
Kurt -
Old 12-25-2011, 06:41 PM   #33
1moretoy
Re: ls turbo build
the motor is out of a 2001 camaro
Old 12-25-2011, 11:37 PM   #34
softballnrd27
Always a work in progress
softballnrd27's Avatar
Re: ls turbo build
I hope you plan to take it easy with the stock 4l60e.
You don't need a special pedal if you use a cable driven TB. You only need the gas pedal if you plan to run a drive by wire, along with the tac module and computer(from the same vehicle)
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 12-26-2011, 12:42 AM   #35
prostreetc10
prostreetc10's Avatar
Re: ls turbo build
not to metion, 5.3s are going for $500. say they cant sell them because people arnt breaking them. friend of mine just bought one and bought twin turbo setup from ebay for $1200. keep in mind i know those turbos are cheep knock offs, but his money not mine.
prostreetc10 is offline   Reply With Quote
Old 12-26-2011, 02:02 PM   #36
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: ls turbo build
haha those ebay turbos are actually intriguing. Some of the older ones actually had epoxy holding them together, but seems it was only a certain run. Most of them now are just knock offs of proven designs, usually with slightly poorer materials or tolerances. That being said, over on the turboforums, people are going FAST on them. Junkyard motors + ebay turbo running 11's all day ain't bad. Let us know how his setup works.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-28-2011, 04:46 PM   #37
PokeyC10
PokeyC10's Avatar
Re: ls turbo build
600 hp = short life for a stock 4L60E. I am curious if the #60's will be maxing out if you are close to 600 rwhp. Are those manifolds off a Vette, G8 or? Very nice build.
PokeyC10 is offline   Reply With Quote
Old 12-29-2011, 11:02 PM   #38
69trk
69trk's Avatar
Re: ls turbo build
Here we go, just sold the big block and trans. 1st thing is that i'm going to have everything under the hood painted the ketchme kopper by house of kolor to match the truck, then i'm going to rewire everything with a new painless wiring kit.... I also found a ls motor out of a chevy truck complete with harness and everything for $450. I'll give him a call tomorrow to find out how many miles are on the engine and everything. Then i'll send it to an engine builder to change the rod bolts, head studs, cam and gaskets. I'll start posting pictures, you guys wish me luck!!!
1.58- 60'
11.37- 1/4 @115.81
Old 01-05-2012, 10:08 PM   #39
69trk
69trk's Avatar
Re: ls turbo build
The ls motor that i was looking at already sold. So i'm still looking. What year did the lq4 ls motor come out of? Or is the lq4 mean it's a 5.3? I bought a used procharger intercooler good for 1100+hp and a procharger blow off valve. Both cost me $600... And for the trans, i was planning on building a 4l80e, but the cost was going to be over $3000 complete with converter to handle over 1000hp. So i decided to go back to the old reliable turbo 400 with reverse pattern and a transbrake... Here's a couple of pictures of the bov and intercooler...
1.58- 60'
11.37- 1/4 @115.81
Old 01-05-2012, 11:09 PM   #40
low69chevy
low69chevy's Avatar
Thumbs up Re: ls turbo build
Lq4 have dished pistons good for boost they came in 99-06 hd trucks and the 07up are ly6 this is similar to wat I'm wanting to do to my 69 I have a 5.3 there I'm not using that I might throw in my truck. Good luck with ur build keep us updated
low69chevy is offline   Reply With Quote
Old 01-05-2012, 11:28 PM   #41
usmcchevy
usmcchevy's Avatar
Re: ls turbo build
LQ4 is the "low" compression 6.0. LQ9 is the high comp 6.0. LM7 and later the LY5 is the 5.3.
http://en.wikipedia.org/wiki/GM_Vortec_engine
Build thread
LSx Swap FAQ index
Old 01-06-2012, 12:56 AM   #42
Mr. 250r
Mr. 250r's Avatar
Re: ls turbo build
The 5.3 is.... a 323 in terms of CI if I'm correct but called a 325/327, the 5.7 is 347 and the 6.0 is 364 CI the 6.0 having the 4.00in bore is nice because they have really nice stock heads like the l92 head swap. As far as lq4/9s are only 6.0s and the lq9 if I'm correct has slightly thicker connecting rods and obviously pistons as well check my sig for the ls primer link it tells everything and one last thing I think the gen IV engines started in... 06? Using different rectangular port heads instead of cathedral which means not interchangeable and vvt and few other things making those heads cost possible a little more along with cam although vvt can be eliminated although some of this is already mentioned, TSP 427 6.0 stroker kit would be nice also :-p
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 01-21-2012, 04:18 PM   #43
69trk
69trk's Avatar
Re: ls turbo build
Just picked up a 5.3 out of a 2003 tahoe complete minus alternator and ps pump and starter.... Tore it down today, and ready for the machine shop... might change heads, but not sure yet, they are the 706 heads... I gave $450for this engine with computer and all harnesses... Also picked up my built turbo 400 a couple days ago.... Radiator and hydraboost will be here monday!!!!!!!!!!!!!!!
1.58- 60'
11.37- 1/4 @115.81
Old 01-21-2012, 04:20 PM   #44
69trk
69trk's Avatar
Re: ls turbo build
one more...
1.58- 60'
11.37- 1/4 @115.81
Old 01-21-2012, 04:34 PM   #45
noonzor
Re: ls turbo build
very cool!
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 01-21-2012, 04:34 PM   #46
cletis
cletis's Avatar
Re: ls turbo build
That looks good.
I think I can, I think I can,
http://67-72chevytrucks.com/vboard/s...d.php?t=452601
cletis is offline   Reply With Quote
Old 01-23-2012, 09:00 PM   #47
69trk
69trk's Avatar
Re: ls turbo build
just got the new radiator in... it's by entropy!!!!!!!!!!!!!!!!!!!!!!!!!!!!
1.58- 60'
11.37- 1/4 @115.81
Old 01-23-2012, 09:48 PM   #48
mooseknuckles
mooseknuckles's Avatar
Re: ls turbo build
awesome!....that looks like sweet rad.
mooseknuckles is offline   Reply With Quote
Old 01-23-2012, 10:00 PM   #49
chevy-fun
chevy-fun's Avatar
Re: ls turbo build
When you do the hydoboost setup can you go in a lil more detail on setup an what parts. Wanting to do for my 84, thanx an lookin forward to rest your build
chevy-fun is offline   Reply With Quote
Old 01-23-2012, 10:21 PM   #50
69trk
69trk's Avatar
Re: ls turbo build
will do.... i'm getting it tomorrow, i'll take pictures of it also.... I plan on ordering new brake line just to run from the mastercylinder to the 1st place they connect just to make it look alot better than what i have.... i think summit racing has a role of tubing with a bender for $80....
1.58- 60'
11.37- 1/4 @115.81
