#26 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: Trying Out Homemade Lizard Skin- $10 Per Gallon
I think I'm going to try the kool seal/micro balloons too. It's cheaper than other stuff. I don't think it can hurt a 30 plus year old truck.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#27 |
if I can catch enough lizzards, I might try skinning them and glueing their little hides to the floor pan.
Otherwise, I've thought about geting the micro spheres and mixing them in some bed liner material and coating the panels with that. it would be more durable than latex.
"Negative people always seem to have a problem for every solution" |
#28 |
man, this is cool! ive been using the peel-n-stick from lowe's....the poor man's dynamat
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
#29 |
very cool, too late for me but I did give it a thought, some one else posted up on the mirco ballon. I just got done with the last step on insulation.
62 long box with a little SBC ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=510631 http://good-times.webshots.com/album/561798652HdwqzG |
#30 |
Still Learning
Any updates on this experiment?
#31 |
![]() Join Date: Jan 2010
i read like 60 or 70 pages of a thread on this. may have been the one you posted, i didn't look. great to see this tested here
66 LWB/BBW work in progress 68 Camaro SS bigger work in progress 95 Roadmaster Wagon 12.36 @ 107.74 99 Hayabusa 8.72 @ 162 00 Hayabusa 9.33 @ 153 |
#32 |
I haven't mixed up or sprayed anymore since I last posted. I am happy with how the latex mix sprays out and dampens noise for what it cost. The airspace from the micro balloons would make this stuff great for roof skins and firewalls to minimize heat transfer into the interior. It's much lighter than Dynomat or other stick on sound deadener since it's half air ballons that weigh nearly nothing. That's a huge advantage if you're building a dual purpose track car/daily driver and want to keep weight down as much as possible. That said, I eventually want to try mixing micro balloons with Kool Seal elastomeric roof coating and see how much better (if any) it is at dampening sound. I would think that the softer coating would absorb vibrations in the metal better and reduce the level of transmitted sound more than latex does.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#33 |
I'll be trying this in the next couple of weeks!
Do you think dynamat will stick to the latex? Thanks! |
#34 | |
#35 |
Still plays with trucks
While researching the micro sphere additives for the paint I came across this product. Sounds like more along the lines of what we really need for this home made coating.
http://www.hytechsales.com/insulatin...additives.html
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#36 | |
Still Learning
I would love paint the bottom of my cab and be done with it. |
#37 | |
I would do a test panel using the high hump tunnel cover and play around. This way you could mix a small amount of paint as a test and not have a tough part to scrape clean if things don't work out.
#38 |
Apologies for resurrecting an old thread but I'm wondering if anyone has actually used this and what kind of results you got. I always like to hear from actual experience. Thanks.
Jeff |
#39 |
#40 |
How was the heat difference???
#41 |
I made some up this weekend, i put an open flame to it and noticed a 60 degree difference!
#42 |
I learned about this from the hot rodders forum a few months ago. Been thinking about it on and off, but had a few questions for those who have done it. How well does it hold up? Does it kill any of the sound on top of the heat barrier? What kind of paint did you use? Can you put any fatmat/dynamat down on top of it? And how many gallons was needed for your reg cab or [preferably] Suburban?
#43 |
All I did so far was mix it up with some cheap latex paint on spme scrap sheetmetal, and test it in my garage.
#44 |
Looks good
1967 C10 SWB Stepside (without the ugly spare tire holder) 1968 c10 SWB Stepside (with the ugly spare tire holder) |
#45 |
Somebody ought to ping the OPon a PM. I already heckled him on another thread so it can't be me, haha.
#46 |
Opon?
#47 |
![]() Join Date: Jun 2002
Original Poster on a PM (should have spaced the on)
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
