Old 05-22-2014, 03:02 PM   #26
Crash_OK
Crash_OK's Avatar
Re: Crash's 1988 Land Cruiser Build
Originally Posted by alsriv2 View Post
Those inline 6's were bullet-proof. Not understanding why you would go thru this mod with the engine, but it is a interesting project to say the least. The interior restoration turned out very well. Great job there.
I wish you the best with the conversion.
Thanks.... i guess the same could be said for the 1st gen Chevrolet small block, yet many people replace them with late model FI engines. Better power, better drivability, better fuel economy, increased dependability, greater availability of parts, etc... plus i enjoy doing it...
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash_OK is offline   Reply With Quote
Old 05-22-2014, 05:27 PM   #27
Jonboy
Slots go on anything!
This is a sweet build. After reading the whole thing last time, I had to pull up CL. There is a guy in my neighborhood that flips Grand Wagoneers. I drive by his house on the way home from work every night and have to take a look. I have a feeling one of those is in my future somewhere, with an LS swap. Just have to finish the current one first.
1974 Jimmy- 5.3/4L80e/NP241
Old 05-23-2014, 12:46 AM   #28
mcbassin
Still Learning
mcbassin's Avatar
Did you forget a small difference in ponies?
mcbassin is offline   Reply With Quote
Old 06-02-2014, 04:04 PM   #29
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
And that's what matters.
Like another member said...Chevy's and Toyota are my favorites as well.
I wish you the best on your project.
Alan
2012 Ram 3500 Dually Crew Cab 6.7 Cummins
2014 Palomino Columbus 340RK 5th wheel
'69 Chevy C10 396BB
alsriv2 is offline   Reply With Quote
Old 06-02-2014, 04:09 PM   #30
Crash_OK
Crash_OK's Avatar
Thanks....
Mark
Crash's 69 4x4 SWB
Old 06-07-2014, 02:36 AM   #31
1968k10blue
1968k10blue's Avatar
Not too long ago I read through you 69 build, I am definitely looking toward to this build!
Austin
2005 GMC Sierra 1500 4X4 4.8l V8 (Wrecked)
2003 Chevy 1500 standard cab short bed 4x4 w/ 5.3l
1968k10blue is offline   Reply With Quote
Old 06-07-2014, 09:41 AM   #32
Crash_OK
Crash_OK's Avatar
Thanks.. Update coming soon..
Mark
Crash's 69 4x4 SWB
Old 06-07-2014, 09:54 AM   #33
Crash_OK
Crash_OK's Avatar
Time for an update..
Got the Advanced Adapter parts…
Decided to clean up the injectors…
Cleaned up the engine a little more…
Installation of the adapter..
Setting the air gap on the speed sensor..
Put it all together..
On the lake today… start the tear down tomorrow…
Mark
Crash's 69 4x4 SWB
Old 06-07-2014, 09:58 AM   #34
mcbassin
Still Learning
mcbassin's Avatar
Looks great Mark!
Old 06-07-2014, 05:48 PM   #35
Crash_OK
Crash_OK's Avatar
Originally Posted by mcbassin View Post
Looks great Mark!
Thanks Mike... Wish we could figure out how to make the adapter stuff.. AA is very expensive..
Mark
Crash's 69 4x4 SWB
Old 06-09-2014, 09:19 PM   #36
Crash_OK
Crash_OK's Avatar
Got the drivetrain pulled Sunday…
Next weekend I will start on the frame clean up and tear down of the transfercase. I believe I am going to have to replace some parts in the TC. The front bearing was very lose.
Mark
Crash's 69 4x4 SWB
Old 06-09-2014, 11:15 PM   #37
mcbassin
Still Learning
mcbassin's Avatar
Wow, you weren't messing around with pulling the old drivetrain. Very quick!
Old 06-09-2014, 11:17 PM   #38
Crash_OK
Crash_OK's Avatar
thanks Mike.. I hope you are making great progress on your build...
Mark
Crash's 69 4x4 SWB
Old 06-09-2014, 11:43 PM   #39
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Yeah, no kidding!
That's gonna be so cool, Mark.
Zoomin is offline   Reply With Quote
Old 06-10-2014, 07:19 PM   #40
Crash_OK
Crash_OK's Avatar
Originally Posted by Zoomin View Post
Yeah, no kidding!
Thanks Steve.... Hope things are going well for you...
Mark
Crash's 69 4x4 SWB
Old 06-14-2014, 11:59 AM   #41
Crash_OK
Crash_OK's Avatar
Removed and broke down the Transfer Case.. It all looked good except for the front output bearing.. it was in bad shape.. Still attempting to find someone to sell me a rebuild kit.
I bought this press a couple of years ago and it is still working well..
Started the cleanup of the TC case and parts..
Next step is removing the old engine mounts and cleaning up the front frame..
Mark
Crash's 69 4x4 SWB
Old 06-14-2014, 12:11 PM   #42
Crash_OK
Crash_OK's Avatar
Removed the front engine mounts and cleaned up the frame..
Removed and cleaned up..
Removed the steering gear and started cleaning it up..
Started the process of getting the engine in the correct position for building the mounts.. I had hoped to use the factory engine mounts and brackets.. but doesn’t look like it will work.. I most likely will order the Advanced Adapter kit…
Mark
Crash's 69 4x4 SWB
Old 06-16-2014, 09:18 AM   #43
Hart_Rod
Hart_Rod's Avatar
Another sweet build!
Hart_Rod is offline   Reply With Quote
Old 06-16-2014, 09:41 AM   #44
Crash_OK
Crash_OK's Avatar
Thanks Hart_Rod...
Mark
Crash's 69 4x4 SWB
Old 06-16-2014, 11:08 AM   #45
mcbassin
Still Learning
mcbassin's Avatar
Nice progress Mark, I be we could fabricate some nice stands to work with the stock mounts.
Old 06-23-2014, 10:35 PM   #46
Crash_OK
Crash_OK's Avatar
Thanks Mike...
Mark
Crash's 69 4x4 SWB
Old 06-23-2014, 10:36 PM   #47
Crash_OK
Crash_OK's Avatar
Update from 06/15/14..
Mounted the LS1 Camaro Fans to the Land Cruiser radiator. I used these fans on my 69 Chevy K10 build and they have really worked well.
I really need to get rid of this..
Mark
Crash's 69 4x4 SWB
Old 06-23-2014, 11:01 PM   #48
Crash_OK
Crash_OK's Avatar
Update from 06/22/14
Headers and motor mounts..
Steering gear box clearance..
Pulled the drivetrain to rebuild the transfer case.. new bearings, seals, thrust washers, gaskets, etc…
Had problems getting one of the bearings off the shaft… had to use an old trick with a new tool.. It popped loose before I cut all the way through.
Idler shaft was worn pretty bad..
Overall, the rebuild was much easier than expected.. I reused the shims that were original to the TC. The preload was a little on the tight side, but still in specs.
Mark
Crash's 69 4x4 SWB
Old 06-24-2014, 08:24 AM   #49
mcbassin
Still Learning
mcbassin's Avatar
The LS1 fans look like they were made to mount up to the stock radiator.
I really like the new headers too. Those look nice! You made the transfer case overhaul look easy.....
Old 06-24-2014, 09:06 AM   #50
Crash_OK
Crash_OK's Avatar
Thanks Mike ... Looking forward to seeing your progress....
Mark
Crash's 69 4x4 SWB
