11-29-2014, 12:27 AM | #26 |
Re: Will 1987-1991 blazer fuel tank work?
Does anybody have the part number of the sending unit? I plan on putting one of these in a Suburban that I am doing a LS swap on. I would guess that the sending unit is the standard 0-90ohm?
12-29-2014, 03:12 PM | #27 |
how can one find out which sending unit you need ? I know there is 2 inch difference from 25 to 31 gallon tank, do you measure from the pan or from bottom of the inside
01-19-2015, 11:13 PM | #28 |
02-07-2015, 10:20 AM | #29 |
good info
10-13-2015, 10:28 AM | #30 |
Collector of Projects
Bringing this back up for information on the connections to the in tank pump. I don't want to run AN fittings. Looking for either a barbed fitting for EFI rubber hose or possible the newer style nylon fuel line.
10-15-2015, 09:32 PM | #31 |
I installed this tank in my 72 with AN Fittings. I bought the sending unit from rock auto. They had sending units that used barbed fittings as well.
10-15-2015, 09:37 PM | #32 |
10-16-2015, 12:02 AM | #33 |
Dorman 800-078 feed
dorman 800-079 return Those look like they would work.
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
04-10-2017, 10:15 PM | #34 |
06-23-2017, 02:19 PM | #35 |
For anyone else looking into this the 92-96 31 gallon tank appears to be identical except the filler neck is on the opposite side but doesn't have the 90 bend on it.
07-03-2017, 11:47 PM | #36 |
for those who have used the 87 tank what fuel gauge did you use? i ran the 87 tank with the 87 sender and my 75 fuel gauge goes past fuel everything is brand new, any suggestions?
07-08-2017, 01:36 AM | #37 |
It's likely the ohm on the sender. Here's some good reading.
http://www.chevyclassicsclub.com/the...ry-1965-newer/
Kirk 72 Blazer CST 4wd highlander 66 Nova |
03-02-2018, 12:51 PM | #38 | |
Filler neck hole is on the correct side for the first gen k5. I need a tank in mine and would like to go ahead and get a bigger one that would work for a further LS swap but could also work for now with my stock 72 motor and fuel pump. Anyone know if I can buy the stock 96 fuel pump/sending unit then pull the fuel pump out and replace it with a piece of fuel line. Rely on the 72 fuel pump then, to suck from the new tank just like it does with the older set up. That way I could go back to the in the tank pump when I do a LS swap later?
1972 K5 Blazer 350/350/PS/PB From GA but live in Panama City, FL |
03-04-2018, 01:41 PM | #39 |
What size is the filler neck on this tank?
03-04-2018, 03:00 PM | #40 |
Not sure, the plan would be to have a filler neck welded on to fit the first gen if needed if the stock tahoe one wouldn’t work. Maybe pull a filler tube from one from a junkyard to save some $. I’ll buy a new tank though
03-08-2018, 11:50 PM | #41 |
After doing some measuring the 92-96 tank won’t fit. It’s too wide to fit between the frame rails. I measure the width between mine at 27 1/4”, the stock tank and the 87-91 tanks are a little wider than this but only with the flanges. Guess it’s back to the 87-91 for me and having the filler next swapped to the other side on the tank or turning it around.
03-09-2018, 12:43 AM | #42 |
Designated A-hole!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
03-09-2018, 08:33 AM | #43 |
1 3/4" looks to me. You measure the diameter below the ridge though, least I do with a caliper
11-16-2018, 09:38 PM | #44 |
ttt
1961 Biscayne http://67-72chevytrucks.com/vboard/s...90#post6978790 SOLD 1971 C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=656258SOLD 1966 Suburban http://67-72chevytrucks.com/vboard/s...85#post7323885 |
