10-21-2014, 03:29 AM | #26 |
Re: Walbro pump failure
10-21-2014, 08:05 PM | #27 |
What EFI wiring harness are you using? Where does it receive power from? Interior fuse block or directly from the battery?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
10-22-2014, 12:02 AM | #28 |
10-22-2014, 11:02 PM | #29 |
I would wire the pump like this:
10-22-2014, 11:51 PM | #30 |
11-01-2014, 02:10 PM | #31 |
11-01-2014, 11:12 PM | #32 |
I like your camera!
That is a very good clear picture!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
11-01-2014, 11:18 PM | #33 |
11-01-2014, 11:21 PM | #34 |
Tested the pumps amperage and I got a 8.40-8.65 reading....any thoughts?
11-05-2014, 12:11 AM | #35 |
bump for some knowledge regarding my last update
11-05-2014, 12:30 AM | #36 |
The ~8.5 amps is reasonable for your fuel pump. There's nothing to worry about there. I still think your problem was just a bad connector at the sending unit bulkhead. Just solder the connections as discussed earlier and you should be good to go.
