Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 02-19-2017, 11:03 AM   #26
Hart_Rod
Hart_Rod's Avatar
Re: Babe: The Blue Ox
Originally Posted by rubberbandit View Post
I am excited. I read through your entire build. It only took me a few days. You've put a lot of work into that suburban. How do you like your HDX gauges? I just placed my order today for the white/silver version. they said 4-6 weeks.
I love the gauges! Check Vintage Air for the vents, I be they have something that will work. Great progress!
Hart_Rod is offline   Reply With Quote
Old 02-21-2017, 02:46 AM   #27
rubberbandit
Active Member
rubberbandit's Avatar
Porterbuilt hood hinges installed. Also installed the hood brackets from Hart_Rod. Worked out good!
-Chad
'72, C10, SWB, fleet, 4L80E, 406sbc, EFI, TruTrac Blackfoot
'69 C20 Suburban, PB Dropmember, 3rd row, LS3 6.2L, 4l80e, rear A/C, Dakota Digital HDX Babe: The Blue Ox
rubberbandit is offline   Reply With Quote
Old 02-21-2017, 09:20 AM   #28
Hart_Rod
Hart_Rod's Avatar
Looks awesome!
Old 03-08-2017, 11:46 AM   #29
1fast10
Awesome. So glad someone is dojng a mild rear before i do on a suburban. Im doing the same. Got to keep. The rear row seats for the cool factor
1fast10 is offline   Reply With Quote
Old 03-11-2017, 03:10 PM   #30
Average Joe
Average Joe's Avatar
Wow! That will be a fun Burb! Are you going to open up the rear wheel wells any, or will that effect your rear seat?
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 06-03-2017, 04:28 AM   #31
rubberbandit
Active Member
Making more progess. Shaved firewall
-Chad
Old 06-03-2017, 04:30 AM   #32
rubberbandit
Active Member
looks like I may have to shorten the seat by an inch but maybe I can squeeze it in there without cutting it. We'll see
-Chad
Old 06-03-2017, 04:37 AM   #33
rubberbandit
Active Member
Mocking up rear end. I went with a 9-inch with Detroit trutrac
-Chad
Old 06-03-2017, 09:13 AM   #34
Hart_Rod
Hart_Rod's Avatar
Making more progress. Shaved firewall
The hood plates look grat under there!
Old 11-25-2017, 06:30 AM   #35
1fast10
Any updates on this project
Old 02-27-2018, 04:08 AM   #36
rubberbandit
Active Member
Made a bunch of progress since my last post.
I love the look of these Wilwoods
-Chad
Old 02-27-2018, 04:22 AM   #37
rubberbandit
Active Member
Prepped underneath then sprayed with truck bed liner. This is gonna be my daily driver so need to make it durable.
-Chad
Old 02-27-2018, 09:08 AM   #38
1fast10
Any pics on how you did the cover over the rear notch and did you widen the tubs.what size tire ate you running ?.sorry for all the questions.im doing the exact same notch in my burbon .with intentions on a 20x12 rim
Old 02-28-2018, 02:50 AM   #39
rubberbandit
Active Member
I have 20x11 in the rear. I had to widen each tub by 3" (I think). Here are some pics of the cover for the rear notch. I also had to cut about 4" from the middle section out of the 3rd row seat. Hope that helps
-Chad
Old 02-28-2018, 02:58 AM   #40
rubberbandit
Active Member
Parts back from powder coating.
-Chad
Old 02-28-2018, 03:07 AM   #41
rubberbandit
Active Member
A buddy made this aluminum fuel tank for me.
-Chad
Old 02-28-2018, 08:53 AM   #42
Hart_Rod
Hart_Rod's Avatar
Looks great!
Old 02-28-2018, 01:25 PM   #43
Heliarcn
Looking good! I would love to stop by and take look at this burb sometime.
Bret
1972 Chevy Suburban
1976 Blazer
Heliarcn is offline   Reply With Quote
Old 02-28-2018, 07:59 PM   #44
goldenburb
goldenburb's Avatar
Looking Good must be nice to have a shop and skills. Lol.
Been working on my in the dirt and snow. Looking forward to seeing how you'll be doing the 3rd seat.
70 c10 2wd crashed Suburban
67 c10 2wd sb truck
67 c10 4wd lb truck
goldenburb is offline   Reply With Quote
Old 03-01-2018, 02:54 AM   #45
rubberbandit
Active Member
Thanks Bret,
I'm further along than the photos show but It's taking me a while to post progress on here. We should definitely meet up sometime. I really like your build.
-Chad
Old 03-01-2018, 03:12 AM   #46
rubberbandit
Active Member
Accuair setup. Credit goes to my friend Zach Airth (Airth Defined Hot Rods). He does awesome work. The wood is in excellent shape for being nearly 50 years old.
-Chad
Old 03-06-2018, 03:51 AM   #47
rubberbandit
Active Member
Putting stuff together for the final time.
-Chad
Old 03-06-2018, 08:59 AM   #48
Hart_Rod
Hart_Rod's Avatar
Fantastic job! Can't wait to see this on the road, .
Old 03-07-2018, 02:48 AM   #49
rubberbandit
Active Member
Heat shields for the air lines
-Chad
Old 03-07-2018, 02:59 AM   #50
rubberbandit
Active Member
I know some of these images might be out of order, but I've done a pretty lousy job at organizing them, so just go with it.
-Chad
