12-04-2014, 10:24 PM | #501 |
A320 Pilot/USAF Retired
Re: My long term 57 project
I picked it up at the show for $150.00.
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
12-07-2014, 02:24 PM | #502 |
Here's a couple of shots of the frame I picked up this summer.
Check out the unique way to remove the cab!!
12-07-2014, 02:35 PM | #503 |
That's one way ... probably not the one I would have used though ...
12-07-2014, 03:30 PM | #504 |
Haha, Apache Convertable
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
12-07-2014, 05:38 PM | #505 |
That's wild.
Kim |
12-07-2014, 06:08 PM | #506 |
Good one!
Just to be clear this was NOT done by me!!
12-07-2014, 07:45 PM | #507 |
As the old saying goes "Were there's a will, there's a way" just NOT our way...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
12-08-2014, 12:22 AM | #508 |
sad thing is, it prolly took longer to do it this way
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
12-08-2014, 03:19 PM | #509 |
Hopefully the upper half was used to fix one in even worse condition....
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
12-11-2014, 11:14 PM | #510 |
I believe the cab was rebuilt, sure it was a lot of work!
Check out these motor mounts, yikes! But someone did do a nice 5 lug conversion.
12-11-2014, 11:56 PM | #511 |
Looks like someone attended the Stevie Wonder welding school ... OUCH.
I still don't understand why people just don't ask someone for a little help. Being a retired GE welder even I ask for info/assistance once in a while. I've never stopped learning ... Life is like a ladder ... |
12-12-2014, 09:19 AM | #512 |
Those are some nasty looking welds.
Kim |
12-12-2014, 10:56 PM | #513 |
Got it up on saw horses to make it easier to remove all of the stock suspension.
12-13-2014, 12:17 AM | #514 |
JJ, I think I would keep the motor mounts, so you could show what NOT to make...Jim
12-13-2014, 10:39 AM | #515 |
This is going to be so cool! Tagging along for more updates.
12-14-2014, 06:47 PM | #516 |
Oh snap. Didn't know you got bit by the porterbuilt bug too, let me know if you have any questions.
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=602142 |
12-15-2014, 11:56 AM | #517 |
Yep I sure did, thanks!
12-16-2014, 06:24 PM | #518 |
Spent a few hours removing the suspension brackets and cab mounts.
Started by grinding the frame rivets flat with a grinder, center punched them and drilled the centers. Followed by a cut off wheel, then used a air chisel to remove the heads. Then I had to drill down into what was left to relieve some of the tension before using the air punch to drive them out.
12-16-2014, 07:25 PM | #519 |
JJ,
I have what is probably a dumb question: I've read all sorts of strategies for removing factory frame rivets and apparently it's not easy. Having never done it I'm sure I must be over simplifying it, but why can't you just grind the head flush with the frame flange, then either use a punch or air hammer to drive them out? Ok, I see why drilling the center gives you a place to hold the punch but why all the other steps?
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
12-16-2014, 07:46 PM | #520 |
That's what I do Dan. Once flush, a BFH and a punch just under the size of the rivet. The outline of the rivet can be seen after grinding flush to the frame.
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 |
12-16-2014, 07:48 PM | #521 |
sometimes a 1/4" or smaller hole the thickness of the frame deep relieves the stress and makes them pop out easier.
12-16-2014, 08:07 PM | #522 | |
I have gotten the heads to "pop off" just by drilling them. I start with a small drill and step up a couple of times, and if you hit it in the center to head will come right off. I still find it easier to then drill down through it a little to get it the rest of the way out. Dan, I couldn't grind the head completely off without scaring the frame. These ideas worked for me, but I'm sure there are better ones out there!!
12-16-2014, 08:46 PM | #523 |
Chuck are you going to swap frames or build another one, hopefully build another one!
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
12-16-2014, 08:49 PM | #524 |
Sorry Chuck I didn't read earlier post!
12-29-2014, 04:08 PM | #525 |
Before cutting the front cross member out, I made a fixture that bolts into the holes for the forward cab mounts, this should keep the rails from spreading or twisting after the cut.
I don't think I can strip it down any further than this! The front frame horns were bent and twisted, so I picked up a pair from DVAP on a recent trip to AZ. And here it is laid out in my small 2 car garage waiting for the PorterBuilt parts to be installed!
