07-22-2012, 10:16 PM | #501 |
Re: Project Grande Slam: Coley's Hot Rod Shop
Guess the TT2s are out .. They wont fit over my brakes.
http://67-72chevytrucks.com/vboard/s...d.php?t=319406
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
07-22-2012, 10:54 PM | #502 |
67-72 parts collector,…
You might contact SCOTI,... but if I remember correctly,... his old TTII's were and 18/20 combo.
I can't believe a 20" TorqThrust II, up front, wouldn't fit over those brakes
07-23-2012, 06:34 AM | #503 |
Maybe its the spoke design and not the diameter? His ad ( from 2008 I noticed ) mentioned the 20x8.5 fronts. (??) Ill pm him to find out.
Maybe the spokes wont clear the calipers? Posted via Mobile Device
07-23-2012, 09:39 AM | #504 |
A guy with a truck
It's a combination of both. C5 and CTSV upgrades have the same issues. Hoop clearance should be fine with 20s, but 17-18s have issues. The McGaughys kit uses the C4 HD rotor, which has a deeper offset than the C5 to help with spoke clearance. Unfortunately, the truck caliper is huge. I'm having the same issues with my Streeters, but the Coys should fit...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
07-23-2012, 10:18 AM | #505 |
Makes me a bit concerned about ordering billets..
07-23-2012, 10:22 AM | #506 |
Sometimes ordering wheels can be frustrating. Some billet manufacturers have wheels with larger rear pads, to clear brake systems with higher than usual caliper offsets. Some can adjust the pads to wherever you need.
I think you are right, it probably didn't fit due to spoke clearance. |
07-23-2012, 11:45 AM | #507 |
Wow this info could put a whole new spin on my plans for wheels and future brake upgrade on my 68
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
07-23-2012, 11:58 AM | #508 |
Glad I could help you..
(just kiddin .. ) Sigh .. Nothing wrong with Coys IMO, I may just do C5s so I know they fit and run the hub spacers, I don't have to grind anything, etc. It could still look really good.
07-23-2012, 02:52 PM | #509 |
A guy with a truck
With the McGaughys BBK, you may luck out and not have to grind the hub. The issue comes only with the HD 1.25" rotors- not sure what they use for a hub, but it MIGHT clear...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 07-23-2012 at 03:07 PM. |
07-23-2012, 05:25 PM | #510 |
VA72C10
It's not the end of the world running the coys The good thing is it will show the brakes nicely and of course we know they look great on our trucks
But I do like all the other options mentioned....as long as you can confirm fitment I think any of them are great choices!!!
Looking for a 67-72 swb or blazer project in or around VA. |
07-23-2012, 05:43 PM | #511 |
Noo.. the C5 is probably one of my all time favorites. I just want to make sure.
07-23-2012, 09:32 PM | #512 |
Chad I didn't have to grind the hubs to fit my Coys. The McGaugheys has a considerably smaller hub than stock rotors. Mine doesn't even stick out of the wheel.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
07-23-2012, 10:01 PM | #513 |
Hey Chad one thing I thought of if your concerned about the fitment of billet wheels take one of your Billet Specialties Daggers and see if they fit over the calipers. I know billet specialties have a 1" mounting pad. If those fit you should be good with most billet wheels. Plus this would help me out too cause I have the same front brakes and have something up my sleeve lol
07-23-2012, 11:53 PM | #514 |
A guy with a truck
Do you have a measurement from the mounting surface to the caliper face? How far does it stick out? Wish McGaughys provided a fitment template...
07-24-2012, 01:49 AM | #515 |
Collector of Projects
There are two wheels from Schott that you may like, just not sure on the price range...
Schott Modsport Schott Octane |
07-24-2012, 09:22 AM | #516 |
I am going to install my drop stuff and just measure before I do anything else. Wheels or no wheels .. I want them to be right.
It will be a few weeks before I can drive it anyway as I can't mount my seats just yet. The covers are on backorder. I think I have a plan to modify the brackets and drop them about 1". My black buckets sit really nice in this truck but I think if they were about an inch lower it would be perfect. (for my height)
07-24-2012, 10:53 AM | #517 | |
Very interested to see what you come up with for mounting your seats. I thought you looked stylin sitting on the floor peeking over the dash.
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
07-24-2012, 10:59 AM | #518 |
One of the forum members PM'ed me and said Centerline would make that Bolevard wheel in a soft lip. I am intregued .. but I want it all at ride height first to measure center bore, backspacing, caliper, etc.
07-26-2012, 12:18 PM | #519 |
Some pics of the progress in he bed.
When I bought the truck it had some type of bedliner in it? Not sure what it was exactly but it was peeling up and rusty underneath it. Dad and I are in the process of removing it to scuff and repaint it black. I'm going to knock a majority of it off with a DA and 80/120 and re-epoxy, prime, etc. Just bring it back as best I can. Anything will look better than the silver flaky stuff. Post #120 has more pics. Here's where we are now. And the before picture. .. The bedsides look really good on the edges, and the black paint looks original to me. It's coming along but man this stuff is a pain.
07-26-2012, 12:23 PM | #520 |
How nice is the steel bed floor?
I'd like to have it if you weren't so far away,...
07-26-2012, 12:31 PM | #521 |
It is really bad at the front edge and back pass side near the tailgate. (Baseball size holes) It's pretty rusty around the wheel well bolt holes too. ..
By far, my least favorite part of the truck. I hate even looking at it.
07-26-2012, 12:41 PM | #522 | |
C/10 junkie
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
07-27-2012, 11:04 AM | #523 |
Okay , .. ok..
Intro Flow ? Likey or no ?
07-27-2012, 11:06 AM | #524 |
67cheby
its OK...dont love it , dont hate it !
07-27-2012, 11:51 AM | #525 |
I second that.
