Old 01-04-2016, 01:09 PM   #526
tlorber
tlorber's Avatar
Re: My version of the s10 swap
It has to be really gratifying to have her running.
After your recommendation I looked at some you tube videos as well to see how to clean the injectors. I'll probably use a combination of what I saw there.
tlorber is offline   Reply With Quote
Old 01-14-2016, 01:35 PM   #527
tlorber
tlorber's Avatar
Hey Blue, going back to post #252, what did you use to cut the hole for the filler neck grommet into the bedside?
Old 01-14-2016, 02:30 PM   #528
HUSSEY
HUSSEY's Avatar
Looking great! Did you custom order your gauges from New Vintage. I got the same set through Summit when the were on sale but mine didn't come with the turn signals, high beam, and check engine light.
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 01-14-2016, 07:33 PM   #529
BlueJeep
BlueJeep's Avatar
I have a little air saw that I like to use for curves like that. I started off with a smaller hole and made sure I was getting it where I wanted it, then cut the hole larger to fit the grommet. That way I still had a little wiggle room.
Kinda. I bought from Old Dog Street Rod or something like that, but I had already spoken with New Vintage so I'd arranged all the custom features. There was an extra artwork charge and then a small charge for the LED's they used. Hooked them up last weekend.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 01-28-2016, 01:52 PM   #530
72-c20
Packrat
72-c20's Avatar
gone: --'07 Tahoe LTZ 4WD
--'68 Firebird 400 Convertible
gone: --'72 Chevy K20
72-c20 is offline   Reply With Quote
Old 02-14-2016, 07:47 PM   #531
rollinrooster
rollinrooster's Avatar
Just finished looking thru your build and love the stand you built for the fenders so much I will be adding that to my to do list. Anyway keep up the good work truck looks good!!
rollinrooster is offline   Reply With Quote
Old 02-21-2016, 11:55 PM   #532
BlueJeep
BlueJeep's Avatar
I made some forward progress this weekend, but have to take a step back too. I've been waiting on nicer weather to be able to finish up my radiator support and this weekend was to be that weekend. I prepped a bunch of pieces and sprayed epoxy, then did some seam sealing, and then chassis black.
Here it is in epoxy with the seam sealer on it:
In black:
But...after 24 hours it all looks great EXCEPT where the paint is on top of the seam sealer, it isn't drying. I validated that the seam sealer (Lord Fusor 805) is OK to go on top of epoxy and can be painted in 30 minutes. I waited about 6 hours before top-coating it. I'm afraid now I have to dig it all back out and use some other brand of seam sealer, not happy about that. This impacts the radiator support and both inner fenders, so that'll be a good amount of work.
Rather than deal with that frustration, I started in on filler work. I'm a complete newbie to filler, so I pretended like I knew what I was doing and dove in. I'm pretty happy with where it ended up, smoothed out the seams and some dips and is good enough for some chassis black at this point. Will have to wait for another nice weekend to spray epoxy over them and then chassis black....hopefully I'll have my seam sealer debacle straightened out by then.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 02-22-2016, 10:41 AM   #533
99 to Life
99 to Life's Avatar
stuff is looking great, sux about the seam sealer. I'll def keep that in mind of not to do.
as for filler work, i'm no seasoned pro but have managed to do pretty good first few rounds. With body work, its like metal work. all about the highs and lows. easier to see with spraypaint or powders.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 02-23-2016, 09:10 PM   #534
lower50's
lower50's's Avatar
Even with the seam sealer problem your parts look good. I'm in the same boat with waiting for the right weather.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 02-24-2016, 11:08 AM   #535
joedoh
joedoh's Avatar
those inner tubs look great, it will be nice to keep water and grit out of everything including the headlights!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 02-25-2016, 12:27 AM   #536
BlueJeep
BlueJeep's Avatar
Yep, and next time it will be easier.
Thanks!
That was one of the driving forces behind the inners. Knowing where these all rust out (kick panels), it can't help but be from everything that the tires throw up there. Now those areas will stay clean and dry. Also bought a bunch of room for PCM, washer tank, overflow, MAF and air filter, etc. I thought about trying to start with s10 inners, but didn't get them with my donor.
How many 55-59's would still have their eyebrows if they had proper inner fenders......
New seam sealer went on tonight after spending 2 nights digging the old out. We'll see how it turns out this time.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 02-26-2016, 10:52 PM   #537
BlueJeep
BlueJeep's Avatar
I spent my free time this week digging out seam sealer....
I did manage to get it all out and replaced with a different brand, I hope to not have to do that again.
So then to put a positive spin on the week, I had these mounted up today!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 02-27-2016, 08:54 PM   #538
99 to Life
99 to Life's Avatar
luuuv the wheels, never gets old
Old 03-05-2016, 12:18 PM   #539
lower50's
lower50's's Avatar
Wheels look great!!
1951 MG TD
Old 03-24-2016, 09:59 AM   #540
72-c20
Packrat
72-c20's Avatar
nice wheels!
Old 03-27-2016, 09:13 PM   #541
BlueJeep
BlueJeep's Avatar
I drove it today!
Last weekend I topped off the fluids and hooked up the cooling system. This weekend finished up a bunch of wiring, hooked up some grounds and double checked everything. Today I put the new wheels and tires on, started it up and pulled it out of the garage, down the driveway and turned around in the street. Worked great on it's first trip under it's own power. I let it idle in the driveway for a long while, cooling fan isn't turning on so I need to look into that. Big steps forward, getting very excited!
Don't mind the junk in the back, that's what happens to anything that sits in my garage more than overnight!
Received word from my body man that the fenders were painted yesterday. He ran out of clear so he didn't get the hood done, hopefully soon. More progress will come!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 03-27-2016, 09:54 PM   #542
Advanced Design
Advanced Design's Avatar
Congratulations on the test run! Truck is looking good!
Advanced Design is offline   Reply With Quote
Old 03-28-2016, 12:42 AM   #543
iowaboynca
iowaboynca's Avatar
Warms my heart to see spring in the homeland!
You'll be driving by Memorial Day...as long as there isn't a late winter storm (remember i grew up in Iowa )
truck looks sweet!
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 03-28-2016, 12:50 AM   #544
lower50's
lower50's's Avatar
Congrats. Very exciting time. I hope you figure out the fan and get your fenders soon. My truck gets stuff piled on it too but it's all my stuff.
1951 MG TD
Old 03-28-2016, 10:29 AM   #545
99 to Life
99 to Life's Avatar
been in those shoes a couple times. great feeling. I too end up using the bed as storage! as for the efan, simple checks first. The fuse, believe it or not I'v had the fuse be the issue before. Then if that is ok, I'd take the ground trigger wire off your sending unit and ground it out. That is what makes the fan kick on. Easy way to check if your sending unit aka grounding unit is working. If you ground that wire out and its not working, could be a relay wiring issue. I'd check your fan power wire to make sure that gets power when you have your sending unit wire grounded. I do highly doubt your fan isn't working, but if you have power to that wire then it could be the case. also make sure you have enough fluid in the system as those sending units will not kick on if fluid isn't on them.
Old 03-28-2016, 06:06 PM   #546
52Fletch
I've spent the last few days reading on and off and you have done an awesome job! Your metal work is great. I'm excited to see it in all its' glory. Keep up the good work man.
52Fletch is offline   Reply With Quote
Old 03-28-2016, 09:41 PM   #547
BlueJeep
BlueJeep's Avatar
Thanks! Feeling good too.
truck looks sweet!
Thanks! Yes, green grass here but in NW Iowa they had 10" of snow on Thursday. I quit giving myself deadlines....but I am registered and have all my hotels for the Hot Rod Power Tour. Hope that didn't curse me....
Yep, my workbenches end up the same way. I do most my work off my Nomad welding table as a result....
I have a list of things to check, can't be anything major. Worst case is the tune in the ECM didn't include that, then I'll have to find someone to make that change.
Thanks!
Mirrors are mounted now. It is very satisfying to take parts out of boxes that were stored in the bed, install them, and throw the boxes in the recycle bin!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 04-10-2016, 11:28 PM   #548
BlueJeep
BlueJeep's Avatar
Picked up some parts this weekend:
Looks much better, and much more like a truck! It's not as far along as it looks though, the fenders are on so I can finish up the mounting of the inner fenders and then pull them back out to finish and paint. Then they along with the rear fenders will get Raptor liner on the bottom of them, and then they will be ready to go back on for good. I also managed to get the rear window in and mirrors on.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 04-11-2016, 12:56 AM   #549
Kabledawg
Beautiful looking truck.
I don't know if I missed it or over looked it, but how did you get the front to sit so low? Did you use drop spindles?
Thanks,
Sean
Kabledawg is offline   Reply With Quote
Old 04-11-2016, 07:38 AM   #550
lower50's
lower50's's Avatar
Yes looking really nice.
1951 MG TD
