Old 12-30-2014, 04:49 PM   #526
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: My daily driver/beater : How I turned lemons in lemonade
Right out of the box before I even installed them they felt kind of crunchy when you moved them. An o ring seal in an aluminum bore shouldn't feel crunchy so I kind of knew there might be problems. I just need to remove them from the truck and take it all apart. I'll get good quality o rings and rebuild them with lots of care and lube. Let's hope the machining work is not the problem.
Old 12-30-2014, 05:08 PM   #527
mcbassin
Still Learning
mcbassin's Avatar
It sucks to read about the valve issues. Looking forward to another update when the weather warms. I completely understand, I would rather soak up heat inside than freeze in the cold shop....
mcbassin is offline   Reply With Quote
Old 12-30-2014, 06:22 PM   #528
SCOTI
SCOTI's Avatar
His 'debut' deadline won't allow for the weather warm-up. Usually our areas cold period is Jan - end of Feb which is when he wants to drive it into the Decatur Swap Meet.
TX..... bummer to hear about the valve block on top of the cold temps curbing the enthusiasm. I look forward to our next Meet & Greet to see Lemonade in person.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-30-2014, 06:52 PM   #529
lolife99
67-72 parts collector,…
lolife99's Avatar
Ever consider just using the manual paddle valves?
Build a panel for the same location and send the Larry valves down the road,...
Keith
Convert to disc brakes.
Old 12-30-2014, 10:27 PM   #530
aggie91
I'm just glad to be here!
aggie91's Avatar
What did the mfg of the LL valve have to say about it? It sucks you have to get inside it to correct what could be a manufacturing problem.
I talked with my boys last night about the Decatur Swap Meet, it is the same weekend as LST down in Conroe. Looks like we are going to attend the Swap Meet. Hope to get together and meet you and the truck in person.
Don't loose hope...I agree the current weather does not help your motivation when you have a shop like ours...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-08-2015, 12:01 AM   #531
JakeDW
JakeDW's Avatar
Not to go back to something you have already gone a different direction on but when you set that pan hard bar up to you set it up level and centered at ride height that is the only way it works right.So when it goes up or down it only move 1/2 as much side to side as if you set it up all the way down level or all the way up level if you follow what I am saying.
The pan hard bar on my buddy's 77 only moves about 1/2 inch side to side with 22 in rear wheels 2600 bags with the bag on bar set up.And it's pretty short and I was not fond of that.
Single leaves will break its just a matter of time.
Cool truck .
Jake
JakeDW is offline   Reply With Quote
Old 01-08-2015, 12:12 AM   #532
JakeDW
JakeDW's Avatar
Check how the pan hard bar is at an angle all the way down when the truck is at ride height it will be level and you can see the shock on this is standard not side mounted.
Jake
Old 01-08-2015, 01:18 AM   #533
JakeDW
JakeDW's Avatar
http://youtu.be/Onc6P6fHnfo
2 link
Jake
Old 01-09-2015, 12:29 PM   #534
Hankster
Hankster's Avatar
Where is the swap meet at? I may blow off LST to see your truck TX .
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 01-14-2015, 01:02 AM   #535
Hutch
Hutch's Avatar
Hankster
40th Annual
Decatur Swap Meet
February 19-22, 2015
http://www.wcaac.com/dsm.htm
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 01-14-2015, 10:44 PM   #536
OutlawDrifter
quite the build, enjoyed reading through this one as with all of your stuff tx!
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 01-18-2015, 02:36 PM   #537
Strider
Strider's Avatar
Powdercoated the original 6 inch wide steel wheels and installed the 5 dollar swap meet hubcaps. The rear tires were already on the truck. I just turned them around to be white letter in. The fronts are from Discount Tire and were 140 dollars per pair out the door. Remember this has to be cheap.
A bit of a revival here perhaps but I was curious as to who or what you used for powdercoating? If this is asked elsewhere in the thread sorry but just reading through now and love your work for the quality and do it yourself spirit as well as budget conciousness!
1967 C-10 250 I6 w/ TH350 3.08 10 bolt HUGGER ORANGE aka "The General"
'57 GMC short step REGINA SPECIAL
2013 CREW CAB SILVERADO 5.3 6 SPEED Z71 WHITE DAILY DRIVER
"When you have eliminated the impossible, whatever remains, however improbable, must be the truth." ~Sherlock Holmes
"Deeds will not be less valliant because they are unpraised." ~ Aragorn
Strider is offline   Reply With Quote
Old 01-18-2015, 11:19 PM   #538
Primered_69
Primered_69's Avatar
He does his own powdercoating
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 01-24-2015, 09:25 PM   #539
68Timber
I know the pieces fit
68Timber's Avatar
Are we far from an update?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-25-2015, 09:56 PM   #540
bigblock73
yeller
bigblock73's Avatar
Kevin, why all the FB love, but none here? Truck is looking great!
bigblock73 is offline   Reply With Quote
Old 01-25-2015, 10:29 PM   #541
83swb
I found his Instagram page unknowingly, he put an old cattlecatcher style grille guard on it. Still black and white.
83swb is offline   Reply With Quote
Old 01-26-2015, 12:41 PM   #542
68Timber
68Timber's Avatar
Link?
John
74 Honda Z50 build
Old 01-26-2015, 01:44 PM   #543
Low Elco
Hector someone is throwin' it up on FB.
Low Elco is offline   Reply With Quote
Old 01-26-2015, 02:46 PM   #544
mcbassin
Still Learning
mcbassin's Avatar
Originally Posted by BRUISER View Post
Link?
@hector_salamanca_90
Old 01-26-2015, 02:58 PM   #545
68Timber
68Timber's Avatar
Got it, thanks man. Good timing I guess, I finally joined FB and Instagram last week...
John
74 Honda Z50 build
Old 01-26-2015, 03:34 PM   #546
Cashed
Cashed's Avatar
Isnt Hector Salamanca a Breaking Bad character? Haha
70 SWB - 514 Red Patina, Ridetech airride, LSx/T56, gray 20" Coy C44’s
77 2wd Blazer - Red Patina and OG graphics, 350/400, Lowered, 20” USMags
98 2door 2wd Tahoe - 3/4 drop, 20" Coy C57's, ProPerformance Revelator big brake kit, Don Hardy 416 LSx/4l80e
IG: @chdcsh
Cashed is offline   Reply With Quote
Old 01-26-2015, 04:28 PM   #547
Eraser475
Eraser475's Avatar
Ding ding ding! We have a winner ^
Dad's: 1973 Chevy C-60 Grain Truck 366 Big Block
Dad's: 1982 Chevy Silverado 6.2L Diesel K-10
Dad's: 1987 Chevy Silverado TBI 350 R-10
Dad's: 2007 GMC Sierra Classic 2500HD SLT
Mine: 1982 Chevy Silverado 6.2L Diesel K-10
Eraser475 is offline   Reply With Quote
Old 01-26-2015, 05:12 PM   #548
mcbassin
Still Learning
mcbassin's Avatar
Ding ding ding ding.....no pun intended
Sorry Kevin, I couldn't resist.
Old 01-26-2015, 05:28 PM   #549
rusty76
rusty76's Avatar
Funny
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 01-27-2015, 10:48 PM   #550
Primered_69
i hope telling another mans business and how he posts elsewhere makes yall happy. Where I come from fronting a man out like that is not how we operAte. No Bueno
