#601 |
Re: "Project Orangepeel" 52 A.D
Unfortunately, This has been done on these trucks before...I love the way it looks,so that's why I chose them.
Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
#602 |
Nice!
I think they look great your truck!!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#603 |
That is going to look really cool!! I have a hard enough time just repairing back to original. You have great skill and motivation.
Ryan. |
#604 |
![]() Join Date: Mar 2007
I have always liked the way those buckets look on trucks, plus it give you a place to mount the turn signal besides in the grille.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#605 |
Kees,Ryan and Marc,Thank's Guy's now I just need to get the time to work on it!!
Mark...
#606 |
Cool idea!! The rings look pretty good for $60
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#607 |
Yeah, they aren't to bad kinda fit's the look of the truck I have seen these go as high as $400.00! for a set that are super nice and the average price is around $145.00 so the $60.00 I paid was a steal as far as I'm concerned.
Marc, as far as the blinker goes I had the same thought maybe something vintage looking for that. Mark...
#608 |
I could use those buick fenders for my buick
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#609 |
Sorry 99...I know these are hard to come by,if it helps you can have the leftovers after I cut the headlight openings out.
![]() Mark...
#610 |
mark, sure we can talk when you are done with the fenders. I know mine are pretty gone up front and I believe some in the back too.
#611 |
You Got it..I'll keep you posted.
Mark...
#612 |
![]() Join Date: Jun 2007
A truck that I see all the time that has the same headlight treatment.
1966 427 biscayne with a 5 spd tremec on old school torque thrusts. 1972 Cheyenne Short Bed 1958 Apache short fleet 1980 Chevy short bed http://67-72chevytrucks.com/vboard/s...d.php?t=761005 1959 "Henry" http://67-72chevytrucks.com/vboard/s...d.php?t=670461 1966 Biscayne http://67-72chevytrucks.com/vboard/s...d.php?t=444419 1972 Suburban http://67-72chevytrucks.com/vboard/s...d.php?t=478828 |
#613 |
I kinda like the '49 Olds headlights too.
#614 |
Awesome. I really dig those headlight rings.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
#615 |
Thank's Guy's..
Dean, Yes I was also looking for those and couldn't track a set down,and almost made my own till I found this set. Mark...
#616 |
Mark, on the topic of rust or bubbling under the clear coat on bare metal....I used a combination of half Penetrol and half polyurethane. It's goes on very clear. About 20% of my truck is bare metal, 30% rust, & 50% original factory 65 year old paint. It's been 6 months and no sign of any rust or bubbling anywhere. Of course it has been inside the whole time but temps have been as high as 105 and as low as 40.
#617 |
Awesome...Thank's for the tip!
I still haven't made up my mind of what I'm going to do when I get back on this thing. I have been kicking around some ideas, but until it's back in the shop they are only thoughts. ![]() What kind of Poly did you use BTW? Mark...
#618 |
They make various versions in satins and water based. Only use the clear gloss oil based. It is very glossy. Mixed with Penetrol it becomes slow drying. It sets up in a couple of hours but continues hardening for a week. Mixing a pint of each will do one coat. I put on two coats but went over again on certain areas that were less smooth to start with. I wouldn't go over two coats for fear of thicker being more prone to chipping.
#619 |
Nice Thank's again!
Mark...
#620 | |
![]() Join Date: Jul 2012
In this post, you were showing the column mount as shown below. Do you happen to have a picture of the brake pedal assembly mounting? I did order the same set up from Speedway and would be real happy to follow your lead for installation. Thanks Mark. |
#621 |
I went through my pics I have I couldn't find anything.
Will check on Dad's computer. Are you using a booster with the pedal and master? I ask this because I'm running manual brakes with 4 wheel disk and the pedal is mounted a bit different than if you use the booster. since the booster has studs on it the new pedal assembly will just bolt to it (hole in firewall for the pushrod ) Figure out the height of the pedal from the floor and mark and drill your holes I know this sounds vague but wel can kick around some ideas if need be. Mark...
#622 | |
#623 |
Ok, just went and looked at mine in my shop.
step #1. Measure up from floor to bottom of pedal from a (factory unit) or daily driver for reference and and sit in the seat and try out the height for comfort. #2. if this all checks out, using masking tape on firewall mark all holes and drill the 3/8 holes for either the booster studs or bolts (like mine with No booster) and the large hole for the booster rod or pushrod for master. #3. slide booster through 3/8 holes and bolt the pedal mount to the studs followed by master. Or use 4 3/8 button head cap screws through firewall and bolt the pedal mount to these bolts then bolt the master to the firewall. In total for NO booster you will have 6 3/8 holes 4 for the mount and 2 for the master. Using booster only 4 3/8 holes for the mount. Hope this helps! Mark...
#624 |
Just as I posted I saw your reply I made a Plate that was welded to the Top of my mount that goes upto the stock column mount that is bolted to this for removal
#625 | |
And thanks for the description on the tie in with the column bracing. I will go for the same. |
