01-20-2017, 07:14 PM | #676 |
Re: 75 Dually build
Got the tailgate trim panel finished. I like this grey better than the first go around. It will be a good accent color.
At least this is something I can check off my list of to do's! Now on to harder items... Stay tuned! |
01-20-2017, 10:00 PM | #677 |
6>8 Plugless........
Re: 75 Dually build
That looks great!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
01-26-2017, 12:13 AM | #678 |
Re: 75 Dually build
OK here is a big announcement!
I have been working on getting this truck ready for paint for quite some time, most of you who have been following my build already know this. The big thing is that I'm not going to paint it. I'm going to wrap it. The list of reasons is actually fairly long, and I'm going to give this a try. In the last picture I posted the tailgate trim was wrapped. I bet most of you thought it was paint. The results are really good in my opinion. So as soon as I am done with all the body work it will get wrapped. The picture below shows several samples I laid out on the hood. I chose the blue that is in the circle. You can also see a piece of the rear cab trim that I have done in the same grey as the tailgate panel. The blue is going to be my primary color and the grey the accent color. The blue is a Porsche GT3 blue, and the grey they call Elephant Grey. The brand I chose was Vvivid vinyl. They are rated very high and so far I have liked the way it applies and it is very easy to work with. Unlike paint if you mess it up, you simply pull it back up, heat it up, and it will take all the wrinkles out and you go at it once again. This is an amazing substance to work with, much higher tech than you would think. I know you are going to have a ton of questions. I will try my best to answer them as always, but understand I'm in a time crunch for LST so I will do the best I can. I hope to log this portion of the build fairly closely. For those guys out there on a budget this is a super way to finish out your ride and not break the bank like paint can. Stay tuned! |
01-26-2017, 03:06 AM | #679 |
Re: 75 Dually build
Almost close to the original suburban blue u started with.
94 ls swap silverado 65 Pontiac 78 c30 crew cab dually (parted and gone) 82 c30 crew cab dually ( now building ) 91 r30 crew cab dually (parted and gone) 69 swb-sold 71 lab sold all in progress......__ ..........._______ |__\__ ..........|__(O)______(O)] ........................ |
01-26-2017, 12:27 PM | #680 |
Re: 75 Dually build
01-26-2017, 12:34 PM | #681 | |
67-72 parts collector,…
Re: 75 Dually build
Or do you need a base coat of paint under the wrap to seal out moisture? I had a '68 Camaro years ago that had a vinyl top put on over primer. When I removed the vinyl top the roof was solid RUST! So bad,... I had to replace to roof skin.
01-26-2017, 01:45 PM | #682 |
Re: 75 Dually build
Awesome, I will definitely be watching closely. Vinyl has come a long way in recent years.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
01-26-2017, 03:55 PM | #683 |
I'm just glad to be here!
Re: 75 Dually build
I would like to know what the total cost is for a truck that big...
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
01-26-2017, 04:33 PM | #684 |
Re: 75 Dually build
I'll be watching the wrap progress for sure. I've priced them but they are about the same cost to have done as a decent paint job. I've looked and the rolls of vinyl arent to expensive so it is something I've kicked around to try myself....
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
01-26-2017, 05:07 PM | #685 | |
Re: 75 Dually build
My buddy has a collision shop that also does occasional customs & opted to wrap his CC dually. He knocked out the bodywork to get it straight & had it wrapped. The guy had it done in a day & that was w/multi-colored graphics & writing. My buddy sold that dually a year or so ago & the wrap was 4-5yrs old @ that point.
01-26-2017, 10:44 PM | #686 | |||
Re: 75 Dually build
I hope all this helps! |
01-26-2017, 11:54 PM | #687 |
Re: 75 Dually build
I like the idea, but to me I would think the jams and inside of the doors will be a bear to do. I'm interested to see how this comes out. And if you use epoxy primer, shouldn't that not allow moisture in and rust not to form?
01-27-2017, 08:30 AM | #688 | |
Re: 75 Dually build
Regardless, I'm interested to see the outcome here, please share any tips/tricks that you learn during the process when you have a chance.
01-27-2017, 11:20 AM | #689 |
Re: 75 Dually build
The costs seem very reasonable for the vinyl and doing the wrapping yourself will save a bunch of labor $$'s. I painted a CC Dually 20 years ago, 2 tone in PPG single stage, I had over $1500 in materials alone...NOT including the materials used for the body work and primers.
Another plus to the wrap is that if you start say a rear door, but you don't have time to finish, its not a big deal to stop. With paint, once you mix the materials, you got to spray it on something. Otherwise you are throwing money away.
01-27-2017, 04:42 PM | #690 | |||
Re: 75 Dually build
Special note: Something for you guys to think about, and I have been giving it considerable thought as to how to do the roof and rear panel that holds the rear window. Think about this, the vinyl is only 5' wide. now the roof is fairly wide, and the rear panel is even wider than that. They have a product out there called knifeless tape. So I don't have to describe the product and how to use it go pull it up on YouTube it will really help with this discussion. It is 1/8" wide fine tape with a Kevlar string in the middle of it. Basically you put this tape down first then the vinyl goes over it, and then you pull the string through the vinyl to cut it. The cool thing is you can make butt joints between two pieces of vinyl that are very hard to see. Again go see the stuff on YouTube it will do a better job showing you it than I can. I have some of this tape that I plan on using for this portion of the layout. Basically what I want you to think about is how to solve this 3D puzzle. Where should you place material and where to place cut lines so they are as little noticeable to the eye as possible. For the roof I plan on using the roof ribs as a place to hide the cut lines. It's when you get on the back panel that things become somewhat interesting. You will have the material covering the sides and doors of the truck, plus the material coming off the roof to deal with. That material will have to wrap around the sides and over the top somehow and come in contact with the rear panel material. Where those cut lines are and where the material contacts is a fun puzzle to solve. If this was your truck how would you go about laying this out. This is what I meant when I say I enjoy this stuff. Solving problems like this is interesting to me, and if I or you can come up with a good solution then we all benefit. So your assignment is to think about how to integrate all the 5' panels of material covering the sides/rear panel/roof area. This might sound easy in some respects, but go out to your truck and think "I can't show any cut lines if at all possible, and yet I still have to cover the area". Don't tell me this stuff ain't fun! Have fun with it and let me know your thoughts! |
01-27-2017, 05:03 PM | #691 |
Re: 75 Dually build
Homework......what???? The knife tape is pretty cool. I haven't come across it yet, but it makes a lot of sense. I watched a few videos at lunch today and was running through the same challenges in my head. I haven't thought too much about it since I need some measurements from my truck to fully wrap my head around it. The tape changes things for me since I am doing a two tone with a third color seperating the main two. I was going to layer the vinyl, but the tape will allow me to keep it all 1 layer, thus saving vinyl and money.
02-01-2017, 06:03 PM | #692 |
Re: 75 Dually build
Well it's Wednesday now and no update. Must be busy laying down the vinyl.....or still planning it out. Can't wait to see how it unfolds!
"It's never been a simple thing to see the world with a young man's brain; with an old man's heart and restless soul" _______________________________________________ |
02-01-2017, 08:36 PM | #693 |
Re: 75 Dually build
Yes I was laying it down until 11:30 last night. I should have some first pics later.
02-02-2017, 12:35 AM | #694 |
Re: 75 Dually build
So tonight was not as late in the shop as yesterday was, yesterday lasted until 11:30! So far I have wrapped the front panel for the bed, and as you can see below the tailgate is done. Now don't forget the stainless trim is also done in that grey wrap too. I really like this blue color, and I think the accent grey works well with the blue.
I am learning a ton with the first few pieces. First you have to keep everything as clean as possible, just like you would with window tint. If you keep that sort of thought process in mind it will be a big help if you try this in the future. This is such a cool material to work with. If you mess up and wrinkle the film you just simply heat it up and it will flatten right back out. I'm using a heat gun and I am using only the low setting because you can burn this stuff. If you do that you have to start all over again. Second be patient because if you rush this you results will suffer. I'll keep the pics coming as I get parts completed. Tomorrow night I am going to try and tackle the dually fenders. That is going to be one of the hard parts to cover. I just hope it is not too hard... Stay tuned! |
02-02-2017, 10:44 AM | #695 |
Re: 75 Dually build
I like it.
02-02-2017, 11:44 AM | #696 | |
Happy to be here
Re: 75 Dually build
The knifeless tape works excellent. A friend of a friend does wraps and I saw some of their work on the hood of a car. The did carbon fiber panels on a black car. The panels were in the center of the hood and did not extend over an edge. I assumed it was a decal with adhesive, but it was wrap and its very stable. You should be just fine cutting and seaming behind the roof ribs. Do you have an Instagram feed? Send me progress pics for a feature.
02-02-2017, 12:07 PM | #697 | |
Re: 75 Dually build
I quit using Instagram because I got hijacked a couple of months ago and just deleted it off my phone. I like the app, but I guess I will have to go back and start it again. Is there another way I can get the progress pictures to you? Maybe Facebook? Just let me know. |
02-02-2017, 03:11 PM | #698 |
Re: 75 Dually build
Keep it up- looks great!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
02-03-2017, 01:07 AM | #699 |
Re: 75 Dually build
Round 2! The passenger dually fender is done!! I knew this would be hard from the outset, but I'm a patient guy so I just worked on it little by little and it came out better than I thought it would. Once I did one side of the fender I figured out how to do the other side a little bit easier. Typical... Oh well... Tomorrow night is the drivers side dually fender. This weekend I hope to have the bed sides completed. That way at least the bed would be done.
I have some holes to weld up where the old trim went, and then I will primer the cab. Then the real fun begins! Lots to do! Stay tuned!! |
02-03-2017, 10:07 AM | #700 |
Re: 75 Dually build
WOW! Im impressed. Ill follow along to see how this goes.
Tags |
air bags, alcoas, chevy, dually, lowered |
