Old 03-04-2017, 03:40 PM   #701
65sub
65sub's Avatar
Re: My suburban's Twisted Little Sister
I decided I needed some inner fenders so we dug out some old ones from my 67 pick up. I think with some cutting and patching we should be able to make these work.
Dale
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 03-04-2017, 05:10 PM   #702
Grizz1963
Grizz1963's Avatar
Always something happening ehhh Dale.
Rain here.
No progress on the truck yet, but the little Berlingo van is making me smile.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is online now   Reply With Quote
Old 03-04-2017, 10:29 PM   #703
piratexpress1369a
piratexpress1369a's Avatar
Now that is interesting.. Like the way you are going
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 03-05-2017, 12:43 PM   #704
Bomp
Bomp's Avatar
With your metal working skills this will be eazy~peezy.
Bomp is offline   Reply With Quote
Old 03-06-2017, 08:33 PM   #705
65sub
65sub's Avatar
Rain here.
Hi Rian. Ya we're always doing something.
Thanks Pirate.
Thanks Bomp. It's all just cutting and welding.
We spent most of the afternoon trying to center the front wheel. We decided that moving the fender forward 6 5/8" was about right. So we cut the back off a couple of old fenders. Next we'll clamp them in place and start welding.
Dale
Old 03-06-2017, 09:07 PM   #706
lower50's
lower50's's Avatar
Wow you guys rock!!
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 03-06-2017, 09:14 PM   #707
62stepside longbox
62stepside longbox's Avatar
Those fender extensions are gonna look great
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 03-07-2017, 05:21 PM   #708
ibrown50
ibrown50's Avatar
Originally Posted by lower50's View Post
Wow you guys rock!!
Yup what they said I love this thread
Getting old sucks.............but it sure beats the alternative
ibrown50 is offline   Reply With Quote
Old 03-07-2017, 08:26 PM   #709
piratexpress1369a
Love it
63
Old 03-08-2017, 08:27 PM   #710
65sub
65sub's Avatar
Wow you guys rock!!
Thanks Lower. We 're trying our best.
Thanks Nik Should be interesting when we get all the pieces welded together.
Thanks Ian. I'm glad you're enjoying it
Love it
Thanks Pirate. I'm glad you're enjoying it too.
We got one of the fender extensions on. It turned out pretty good. We also fixed the panel alignment issues where the fenders meet the grille surround.
Dale
Old 03-08-2017, 09:32 PM   #711
Bomp
Bomp's Avatar
Bravo, Nice, clean and straight. Perfect.
Old 03-08-2017, 11:58 PM   #712
62stepside longbox
Bravo to the metal magician!
Old 03-09-2017, 02:15 AM   #713
Grizz1963
Grizz1963's Avatar
Very Very Impressive.
I guess a bit of practice does help.
That looks like a no filler join.
Old 03-09-2017, 09:08 PM   #714
65sub
65sub's Avatar
Thanks Bomp. I'm quite happy with the way it turned out.
Thanks Nik. No magic just a lot of time.
Thanks Rain. It's a case of spend time now getting it strait or spend time later. And I hate sanding bondo.
We finished welding the second fender extension. Then we started making some brackets to mount the front sheetmetal. First two brackets with slots to mount the rad cradle. Then a bracket to weld to the inside of the fender and one to weld to the frame to attach the fender.
Dale
Old 03-09-2017, 11:17 PM   #715
Advanced Design
Advanced Design's Avatar
Love the creativity. The fender came out looking good!
Advanced Design is offline   Reply With Quote
Old 03-13-2017, 08:31 PM   #716
65sub
65sub's Avatar
Thanks Doug
We spent some time mounting brackets. We tacked the rad cradle brackets to the frame. Then we tacked the lower fender bracket to the frame but the placement was off so we'll have to try again later. We also started fixing the rust on the fender tops (hood sides )
Dale
Old 03-16-2017, 07:26 PM   #717
65sub
65sub's Avatar
We got the fender mounting brackets tacked in place and bolted the fenders on. We also finished one of the patches on fender tops and set it in position.
Dale
Old 03-16-2017, 11:38 PM   #718
62stepside longbox
Looking good
Old 03-17-2017, 03:44 AM   #719
Grizz1963
Grizz1963's Avatar
I continue to see a Hotwheels special edition with the lines you have created here Dale.
Looking good team.
Old 03-20-2017, 07:16 PM   #720
65sub
65sub's Avatar
Looking good
Thanks Nik.
Looking good team.
The team says thanks Rain.
We continued working on the front sheetmetal today. To start we made some brackets to temporarily hold the front of the hood in position.This piece will become part of the grille surround. We then set the fender top on to check the placement. We found that the fender top needs to move forward 2 3/4 inches to align properly. We decided to cut a slice off a spare set of cowl extensions. That was as far as we got today we'll start tacking next time.
Dale
Old 03-23-2017, 06:50 PM   #721
65sub
65sub's Avatar
We got some more of the welding done. Still a bunch more to do
Dale
Old 03-23-2017, 10:17 PM   #722
piratexpress1369a
Will the hood hinges be able to take the weight of the added Steel
63
Old 03-27-2017, 08:10 PM   #723
65sub
65sub's Avatar
Hey Pirate. The hood will just be the small section in the center. The sides will be part of the fenders and the front will be part of the grille surround.
Just a small update since we've been doing a bunch of welding. We did make a 27" plywood wheel to figure out back spacing and clearance.
Dale
Old 03-28-2017, 02:06 PM   #724
ibrown50
ibrown50's Avatar
Wooden wheel.....Yabba-Dabba Do!
Old 03-28-2017, 06:58 PM   #725
lower50's
lower50's's Avatar
Do you know of a shop to get it balanced?
1951 MG TD
