07-28-2010, 12:58 PM | #51 |
Re: project " Blue-Ray"
lol, that pic was taken at 3am, and i was using a drop light, so those shadows dont help, ill get one in the daylight
07-28-2010, 04:57 PM | #52 |
still looks awesome! they sit at the right angle too
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
07-28-2010, 10:47 PM | #53 |
I'd pimp it!
R.I.P. Killer 71 10/26/07 |
07-30-2010, 09:49 PM | #54 |
I'm sure i will looking at the road more than the gauges but they are cool so far. I like them. Will the back drop light up blue or white? or is it to much trouble to hook up 12v. to it temp> to light it up.keep it up don.
07-30-2010, 09:59 PM | #55 | |
07-31-2010, 07:25 PM | #56 |
ill get some pics of it light up...and i can have the backlighting, either white or blue, just let me know....
07-31-2010, 07:29 PM | #57 |
getting the firewall back together again, got the booster assy., wiper motor, and A/C box, cleaned up and painted....
07-31-2010, 08:01 PM | #58 |
Still Learning
Great work as always! this thing is going to be like new when you get it done!
07-31-2010, 08:25 PM | #59 |
Getting Old; Going Broke
Lookin' slick there. Can't wait to see the cluster lit up.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
08-01-2010, 09:26 AM | #60 |
Happy to be here
I think it's going to be much better than new. It should rival the late model trucks in comfort and performance, and it certainly will look better.
08-01-2010, 03:03 PM | #61 |
Formerly- 1972SuperCheyenne
^^ Thats for sure. The late model stuff doesn't even come close in the looks department!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
08-01-2010, 08:12 PM | #62 |
Still Learning
Yep, my bad I should have said way more reliable and comfortable than new, not to mention way cooler!
08-08-2010, 07:34 PM | #63 |
some more progress this weekend.....
installed the water/oil sending units, istallled the wiring harness to the engine/trans, bolted the torque converter up, bolted the starter on, and installed the engine/trans for the final time....i also started to intagrate the two harnessess.... |
08-08-2010, 07:38 PM | #64 |
and some misc cool pics
08-08-2010, 08:15 PM | #65 |
thats awesome! i love how everything in the shop has an LS motor in it
nice progress buddy. kinda off subject but what yeAr truck is the brake master cylinder out of?
08-08-2010, 09:31 PM | #66 |
The brake system is the original one that came with the 1984' truck, He just added some paint to to it. This truck you see here was in the condition you see pre-before I did all the other work to it besides body work and interior. Hardley no rust except on exterior panels roof and fender. Surface rust that is. No rotted out rockers or anything to speak of. I found this truck 1 mile from my home and bought it from a friend. It had 47,000 plus original miles on a In-line 6 when bought. Motor frozen up completely. I knew motor was shot and was going to rebuild anyway. It had been sitting at his home for over 12 years outside with no cover whatso ever on it. And it is as clean as you see now when it came home. I guess I got lucky there. Please keep up the good work don.
08-15-2010, 10:08 AM | #67 | |
08-15-2010, 11:21 PM | #68 |
drilled and tapped the pass side head to a 1/4"NPT.. there is a plug on the pass side head, near the rear, remove it, then take it up with a 7/16" drill, then tap it to a 1/4" NPT....done it many many times, with no issues
08-16-2010, 12:13 AM | #69 |
thank you. i already set the cab on so i'm not going to try and tap it. i did happen to find an adaptor from autometer today that will work
09-01-2010, 01:09 PM | #70 |
got a bit more progress done...i mounted the PCM/TCM on the firewall with some vibration isolaters...then i made a adaptor bracket for the gas pedal, so it could mount in the factory location. also made the gas pedal to computer harness .. then i turned to the fuel system, got a sending unit for a 87 c10 with a intank pump, and combinded that with a high pressure walbro pump, and then added the AN adaptor fittings...i have the fuel filter regulator, to mount with the AN fittings as well....
and of coarse im still working on intigrating the 2 harness... |
09-01-2010, 01:15 PM | #71 |
i also mounted up a mock-up A/C compressor and fittings to see if there is any clearence issues, but it fit like a glove...deffently, looks like it belongs there, and could of came from the factory like that...here are a few pics of the fitment...also sandblasted and painted the exhaust manifolds...
09-01-2010, 02:38 PM | #72 |
Looks sweet! That computer setup is so much nicer than the big one.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
09-01-2010, 03:15 PM | #73 |
whats the Manifolds off of? It looks like one would have to add the a/c after the engine is set in place or can you have it on the engine when it goes in? I cant tell from the pics..
Thanks, Greg Last edited by 71'tahoe; 09-01-2010 at 03:16 PM. |
09-01-2010, 10:06 PM | #74 |
Can you put that 1/4" npt anywhere on the head or just in that location?
09-01-2010, 10:14 PM | #75 |
Is that the a/c that you will use or is that just for mock-up ? I'm gonna ask but did you use the 87' fuel set-up because thats the first year they put feul injected on those style trucks that would fit that style tank ? And you needed that for this set-up of motor? Where does the gas pedal wiring hook up at? sorry so many questions, thats why your the man.
