Old 02-23-2012, 06:56 AM   #51
mooseknuckles
mooseknuckles's Avatar
Re: PSI Conversions
Originally Posted by mcmlxix View Post
Are you all getting the DBW pedal and TAC module from PSI as well?
nope....I don't need one....mines dbc.
mooseknuckles is offline   Reply With Quote
Old 02-23-2012, 09:39 AM   #52
terrylgreenjr
Re: PSI Conversions
My engine was DBW but I choose to skip the cruise control and pedal wiring headache and changed to cable
terrylgreenjr is offline   Reply With Quote
Old 02-23-2012, 10:36 AM   #53
Kim57
Kim57's Avatar
Re: PSI Conversions
I was thinking of mounting the battery on the driver side and mount the computer under it.... I think the fuse box ends up on the driver side....
I got my pedal from them but I'm ignorant as to what a TAC is.
I may need to get one.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-23-2012, 10:44 AM   #54
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: PSI Conversions
Kim
GM "TAC" Module (Throttle Actuator Control) For Drive By Wire Applications... but I dont think its needed on your E38 computer...
Rich
1972 K5 Blazer CST Click HERE
Old 02-23-2012, 11:47 AM   #55
Kim57
Kim57's Avatar
Re: PSI Conversions
Thanks.
Jon at PSI recommended the E38 over the computer that came with the engine.
Kim
My build thread
Old 02-28-2012, 06:39 PM   #56
truckzilla
truckzilla's Avatar
Re: PSI Conversions
Looks like you guys talked me into a PSI motor loom as well!
truckzilla is offline   Reply With Quote
Old 02-28-2012, 09:11 PM   #57
mooseknuckles
Re: PSI Conversions
tell 'em john from ontario sent ya!
Old 02-29-2012, 01:20 PM   #58
truckzilla
truckzilla's Avatar
Talking Re: PSI Conversions
I sure will since you're just up the street in what we call Far North Texas! I hope to talk to them today and get the ball rolling.
Old 03-03-2012, 01:01 AM   #59
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: PSI Conversions
I'm using there harness for dbw with the 4l80e I had #3 injector wire and the driver side coil pack wire pull out of the terminal so I called them up and they apologized for what happened if I remembered right I could of sent the harness off and had it checked and repaired but I already had installed so they sent me a packet of terminals and fixed them my self,
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 03-03-2012, 01:35 PM   #60
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: PSI Conversions
Yes, thats all it is. You will still have the neutral safety switch on your steering column hooked up.
--Josh
Old 03-05-2012, 11:48 AM   #61
truckzilla
truckzilla's Avatar
Re: PSI Conversions
Hey Aaron, I had forgotten that you had said you were using a PSI Harness as well. I am probably years away from needing it, but I figured I better get it now while I still had a little money left from the IRS savings account.
Old 03-11-2012, 11:53 AM   #62
mooseknuckles
Re: PSI Conversions
the only thing that I have found that I dont like about the PSI harness is that the wire for the MAF isnt going to be long enough to work with my cold air intake......
Old 03-11-2012, 12:03 PM   #63
flamingbig10
6.0 powered square
Re: PSI Conversions
Larry that's correct, John the MAF wires on my harness are the same way, I going to lengthen the harness, I'll just need to get the factory piece that mounts the air filter to MAF
Aaron
Old 03-11-2012, 12:10 PM   #64
mooseknuckles
Re: PSI Conversions
I have a k&n and the maf mounts to the cone and its about 16" away from the throttle body....so I guess I'll do the same as you...or maybe there a pigtail to extend it?
Old 03-11-2012, 06:49 PM   #65
52 Rat
52 Rat's Avatar
Re: PSI Conversions
Guys, Jon at PSI can make you an MAF extension or you can buy from someone else. Do a Google search for MAF extension and you will see vendors on ebay and other outlets.
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671
52 Rat is offline   Reply With Quote
Old 03-12-2012, 10:03 AM   #66
truckzilla
truckzilla's Avatar
Re: PSI Conversions
Thanks Rat. If you guys find a good price on one, please let the rest of us know. I'm guessing I'll probably be needing one as well. I checked with PSI's online store and while they don't have one listed, I'd have to agree in that Jon could probably whip one up.
Old 03-12-2012, 10:12 AM   #67
52 Rat
52 Rat's Avatar
Re: PSI Conversions
Yes, you will need to contact Jon (PSI) directly for this.
Old 03-12-2012, 10:15 AM   #68
truckzilla
truckzilla's Avatar
Re: PSI Conversions
I'll have to remember to ask him about that when I call Jon back with the details to get a E38 ECM ordered from him.
Old 03-12-2012, 01:20 PM   #69
farmtrucks
farmtrucks's Avatar
Re: PSI Conversions
Very pleased with my PSI harness - I've installed 2 of these without any problem - I lengthened the maf wires
farmtrucks is offline   Reply With Quote
Old 10-31-2014, 01:49 PM   #70
KMC3420
KMC3420's Avatar
Re: PSI Conversions
For those who got the PSI harness, did you get the AC recognition for $15? Jon at PSI said it adjusts the idle when the AC is engaged.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 11-01-2014, 11:14 AM   #71
kevmac
kevmac's Avatar
Re: PSI Conversions
I got the a/c lead, ended up not using it. I have vintage air and wasn't sure which wire to connect. Nice harness
kevmac is offline   Reply With Quote
Old 11-01-2014, 11:27 AM   #72
KMC3420
KMC3420's Avatar
Re: PSI Conversions
Thanks for the info. I passed on the wire. Jon said I would most likely not need it. I plan on going after market ac as well.
Keagan
