Old 06-04-2018, 04:01 PM   #51
bbluma
Re: Eric's 1966 Turbo 6.0 build
any updates on the truck? Love the build, and ill be going turbo at some point, so any more pics would be great! The truck is looking awesome!
bbluma is offline   Reply With Quote
Old 06-14-2018, 08:45 AM   #52
Android04
Android04's Avatar
We need updates!
Android04 is offline   Reply With Quote
Old 06-14-2018, 09:09 AM   #53
bocephus79
bocephus79's Avatar
Picture dump in progress! Final hood, doors mockup done. Disassembled the bed. I planned on re using the cross members and front panel, but decided to replace them when Brother's Trucks had their spring sale going on.
bocephus79 is offline   Reply With Quote
Old 06-14-2018, 11:08 AM   #54
bocephus79
bocephus79's Avatar
So far the hood has been Primered and Blocked twice. we ended up finding some imperfections after the first coat. Beyond time consuming but knowing that most body shops would have stopped 2 steps earlier keeps me going. I'm gonna be afraid to drive this thing!
Old 06-14-2018, 11:27 AM   #55
bocephus79
bocephus79's Avatar
This is the bed assembled. perfectly squared and front panel DP epoxied and bolted in for good. The rear crossmember is also bolted, welded and epoxied.
I modified the tailgate with parts from s chevy colorado. I modified the tailgate to accept the half circle part that makes it so you can remove the tailgate without taking the hinges off. ( like the newer trucks). Added Mar-k stainless straps and latches. Filled the holes in the gate where the chains were before.
Old 06-18-2018, 11:11 PM   #56
Red66C10
Awesome! Im building my 66 with an LQ9 turbo. I just joined and will start a build thread. Keep up the good work!!
Red66C10 is offline   Reply With Quote
Old 03-13-2019, 04:26 PM   #57
bocephus79
bocephus79's Avatar
Back From my Long Hiatus. Gotta get this thing caught back up! cut and reinforced the core support for the intercooler and piping
Old 03-13-2019, 04:36 PM   #58
tinydb84
tinydb84's Avatar
Perfect timing! I was planning to do the same this weekend. Thanks for the idea.
David
Instagram: myfabguy
Old 03-13-2019, 05:10 PM   #59
bocephus79
bocephus79's Avatar
Mocked up my boost gauge/ heater control panel. Also rebuilt the 12 bolt. 3.73 auburn posi. bigger yoke for the 1 piece drive shaft
Old 03-13-2019, 05:13 PM   #60
bocephus79
bocephus79's Avatar
Had someone come to my shop and Sandblast the cab. Luckily we found no more rust!! I then Epoxy primed, seam sealed some of it and used Defender bedliner on the bottom and lower firewall
Old 03-22-2019, 02:29 PM   #61
Android04
Android04's Avatar
Looks killer!
Old 03-22-2019, 02:41 PM   #62
bocephus79
bocephus79's Avatar
Got my frame back! Poly bushings in the trailing arms, Some CPP control arms. I also bought a rattlecan of the paint I want to use and just had to test out how it's gonna look on the cab.
Old 07-18-2019, 11:39 AM   #63
bocephus79
bocephus79's Avatar
Summer Stinks. Too Many weddings, Family functions to get any C10 work done. I did get the Cab Coated on the inside. Inside is also blocked and ready for paint!!!! As a side note I'm doing some work for a friend's truck. He pulled it our of a field in Georgia so I'm trying to make it drive able for the summer.
Old 07-18-2019, 11:35 PM   #64
Captainfab
60-66 Nut
Looks good. What brand of bedliner did you use?
Old 07-19-2019, 02:07 PM   #65
bocephus79
bocephus79's Avatar
USC Defender Pro From my autobody supply place. Shot really well and seems super durable, definitely not the cheap stuff!
https://www.autobodytoolmart.com/usc...r-p-19147.aspx
Old 07-19-2019, 04:03 PM   #66
SkinnyG
SkinnyG's Avatar
Is the turbo exhaust going to run outside the frame and out back, or a hater pipe through the fender, or what?
I've got to plan out the same on my '61, and I'm looking for ideas. Thanks!
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 07-19-2019, 04:29 PM   #67
bocephus79
bocephus79's Avatar
goes through inner fender and planned on running down outside of frame and just dumping it out the side
Old 01-02-2020, 11:45 AM   #68
bocephus79
bocephus79's Avatar
New Year, New Update. Long Story Short, WE found out my shop Dog Charlie has ( had) cancer in his jaw. As we prepared for the surgery and many months of taking care of him, I decided I wanted to give him a great summer just in case. Sold My lifted K20 and picked up a 73 c10. Not the prettiest, but solid for Ohio. 383 th350. Did tons of burnouts and went to all the car shows this dog could handle.Name:  20190803_194910.jpg
Old 01-02-2020, 11:48 AM   #69
bocephus79
bocephus79's Avatar
Once 5 teeth and the upper jaw were removed, and we had him stitched up 3 times ( Stubborn Dog) he was given a clean bill of health. SO I got busy the last few weeks......
Old 01-02-2020, 11:52 AM   #70
bocephus79
bocephus79's Avatar
AS of Now I'm fighting decision paralysis. I can finally start assembling and the " where do I even Start" Mentality is kicking in. So I'm taking lots of small bites and taking my time and hoping it adds up to progress. Next big job is the American Autowire harness and The Holley Terminator to wire.
Old 01-10-2020, 03:59 PM   #71
aggie91
I'm just glad to be here!
aggie91's Avatar
Sounds like Charlie had a very cool summer! Good to hear he got a clean bill of health.
Small steps always is a good way to move a project forward. Pick a task and complete it, even if it is just putting in a light bulb or two.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-10-2020, 04:31 PM   #72
J Williams
J Williams's Avatar
Great build man. Definitely follow this one.
J Williams is offline   Reply With Quote
Old 01-15-2020, 10:09 PM   #73
bocephus79
bocephus79's Avatar
Little Bit of Progress: Made a mount for the Aux Trans cooler and started on some Hardlines
Battery installed
radiator installed ( coming back out)
Intercooler
Gotta change my crank pulley to a smaller under drive to fit my turbo oil drain. I swear I checked clearance the million years ago it seems I mocked it up... 2 steps forward one back I guess!!
Old 01-27-2020, 11:33 AM   #74
timmytimm3
Looks good! Its so annoying that this forum doesn't straighten out the pictures (iPhone?)
http://67-72chevytrucks.com/vboard/s...d.php?t=742865
66 SWB, C4 Dropmember
timmytimm3 on IG
"If you don't have time to do it right the first time, when will you?" -Dad
timmytimm3 is offline   Reply With Quote
Old 02-02-2020, 06:23 PM   #75
bocephus79
bocephus79's Avatar
Progress so far:
Sound deadening and high hump installed
Made an overly complicated bracket for mounting the Dakota digital stuff and slapped on some fancy blue plug wires
