Old 02-27-2017, 04:39 PM   #1
bocephus79
bocephus79's Avatar
Eric's 1966 Turbo 6.0 build
New member here. Decided that if I were to start a build thread I could actually keep track of the project. wanted to keep the original body and just swap my new drivetrain in, but with all the rot looks like it just got more interesting.
bocephus79 is offline   Reply With Quote
Old 02-27-2017, 04:43 PM   #2
The1960APE
The1960APE's Avatar
Re: Eric's 1966 Turbo 6.0 build
Good to have you, I think you'll enjoy all the wonderful members here, they sure have been a ton of help for me! It is neat to keep a thread, I enjoy going back to the beginning of my build thread and looking at the progress, it keeps me motivated!
Good luck with your build!
1965 Olds 442 "Project Oldmobile"
1971 2wd GMC Jimmy..."The Orangutan"
1961 Apache "The Ape"
http://67-72chevytrucks.com/vboard/s...d.php?t=679735
The1960APE is offline   Reply With Quote
Old 02-28-2017, 12:01 AM   #3
siggyfreud
siggyfreud's Avatar
Looking forward to the build! Keeping it injected or doing a carb/turbo build?
siggyfreud is offline   Reply With Quote
Old 02-28-2017, 01:48 AM   #4
Captainfab
60-66 Nut
Welcome to the forum
Old 02-28-2017, 12:15 PM   #5
bocephus79
bocephus79's Avatar
drove it awhile last summer while working on the lq4. :stock crank polished, forged rods, .10 over pistons, head studs, PRC heads with upgraded springs and stainless valves.. Truck intake with 80lb deka injectors. PLan is to mate it to a 4l80e, using the stock ECM and a single turbo for some fairly reasonable street action.
Old 02-28-2017, 12:20 PM   #6
bocephus79
bocephus79's Avatar
Stripping it down, I realized the cab and fenders are way worse than I first thought. So I built a quick cab dolly and now starts the least fun part!
Old 02-28-2017, 01:31 PM   #7
66ChevyMax
66ChevyMax's Avatar
Welcome aboard...
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 03-11-2017, 04:38 PM   #8
bocephus79
bocephus79's Avatar
No body guy this week so I got to work on the frame. Stitch welded Captnfab's power steering bracket on. Install Was beyond easy with the template. Definitely happy with the purchase! Removed the 3 speed crossmember and wire-wheeled the frame. Used Eastwood rust encapsulator in a cheap HVLP gun.
Old 04-08-2017, 03:19 PM   #9
bocephus79
bocephus79's Avatar
Some slow but steady progress. Started grinding the spotwelds on the in cab tank mounts. Passenger rocker is welded in as well as the floor/ upper firewall patch
Old 04-08-2017, 03:22 PM   #10
bocephus79
bocephus79's Avatar
Decided to test fit the engine and trans. I'll be building a trans crossmember for the 4l80e, but need to situate the engine mounts first. The engine sits too low to use the Log turbo manifold so I will need to address that issue first.
Old 05-27-2017, 01:26 PM   #11
Notch1988
Notch1988's Avatar
I'll be watching this one...
66 GMC swb dropmember accuair
Link to my build:
My GMC Project
Notch1988 is offline   Reply With Quote
Old 05-29-2017, 12:11 PM   #12
Bomp
Bomp's Avatar
I'll follow along.
Bomp is offline   Reply With Quote
Old 06-13-2017, 08:04 AM   #13
bocephus79
bocephus79's Avatar
Work has had me slammed, so progress has been slow. Cab is ready for sandblast, inner fenders and fenders almost perfect. Before any body work starts I need to mock up the Hot side, turbo and components, intercooler and piping. plan is to run the exhaust through the inner fender and down the framerail to the back.
Old 06-13-2017, 08:47 AM   #14
aggie91
I'm just glad to be here!
aggie91's Avatar
Got to watch this one...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 06-19-2017, 02:53 PM   #15
bocephus79
bocephus79's Avatar
Used an Entropy radiator, HAd to move the bottom mounts inward 2 inches each to avoid the trans cooler fittings ( Made to fit right?) And modify the hold down slightly. Overall happy with the design, hope it cools as good as it looks. Guessed and ordered an intercooler, but it's too big. Heading to Summit Racing today to exchange it for one a few inches smaller.
Old 06-19-2017, 07:59 PM   #16
tinydb84
tinydb84's Avatar
Nice start. Love the turbo stuff. Cant wait to see more.
David
Instagram: myfabguy
Old 07-12-2017, 02:01 PM   #17
bocephus79
bocephus79's Avatar
SLOW progress lately but I got a smaller intercooler and re purposed the radiator support braces and made a mount for it. I had to cut and box some of the support but it will look like it was meant to be there. Spent way too much time getting the aftermarket panels to fit.Name:  20170624_102010.jpg
Old 07-12-2017, 02:03 PM   #18
bocephus79
bocephus79's Avatar
Old 08-09-2017, 02:29 PM   #19
bocephus79
bocephus79's Avatar
SO turbos are heavy so I came up with a contraption to position it while I figured out manifold angles. Once I was happy I tacked the manifold and 74 flange in place
Old 08-09-2017, 02:34 PM   #20
bocephus79
bocephus79's Avatar
SO I have about 3 weeks of tig welding experience, so it's like a trial by fire here. Some undercut and lack of filler, but for the most part it's coming out ok. I used a log manifold from Fahler Speed that has everything set except the last cylinder and upright for the turbo. This let me choose exactly where I wanted it mounted.
Old 08-09-2017, 02:41 PM   #21
tinydb84
tinydb84's Avatar
Do you have a tig finger? When welding tube I always use one and prop my torch hand on the tube. Makes it much easier to keep the torch angle correct. What size turbo do you have?
David
Instagram: myfabguy
Old 08-09-2017, 02:41 PM   #22
Bluelucille63
Very nice
Bluelucille63 is offline   Reply With Quote
Old 08-09-2017, 02:44 PM   #23
bocephus79
bocephus79's Avatar
I need one. My welding cart is too high for any stool i have so I'm finding that standing I'm really shakey and it's hard to stay in position. 78/75 .96 AR
Old 08-09-2017, 07:35 PM   #24
DPowers
DPowers's Avatar
Just ran across your build. Looks good. Where in Cleveland are you?
DPowers is offline   Reply With Quote
Old 08-09-2017, 07:52 PM   #25
tinydb84
tinydb84's Avatar
It makes it a lot easier with the tig finger. You can prop more and have better control all around. I actually weld standing up a lot. You'll get used to it with some more hood time. Looking way better than I was at 3 weeks in for sure.
David
Instagram: myfabguy
