Old 05-23-2018, 10:11 AM   #51
RADustin
Re: 1976 CCSB Duramax Project #trucknamedsue
Originally Posted by Indyfab View Post
After going through your build a third time or so, what are you thinking for towing mirrors? I have 81 cc I’m building, and want very usable towing mirrors that don’t look out of place, that aren’t west coast/camper style. I’d like something that functions like a late model but looks right on these trucks.
I'm the same. I want a two piece tow mirror, like the newerish ones with the standard mirror glass at the top and a lower curved at the bottom. I refuse to use new mirrors though, although some guys have. I'll probably end up with the mini camper style, the tripods or whatever. I really want the blinker in the mirror glass, so I have to think about it some more.
1949 Chevy 3100 P/U
http://67-72chevytrucks.com/vboard/s...d.php?t=302780
1976 GMC Sierra Classic C35 CCSB
http://67-72chevytrucks.com/vboard/s...25#post8188825
RADustin is offline   Reply With Quote
Old 05-23-2018, 12:33 PM   #52
Indyfab
Indyfab's Avatar
I’ve had the tri-pod style and I hated how they destroyed the doors, and that you couldn’t fold them tight. The pre ‘81 can pull them off looks wise better than the later style in my opinion.
Indyfab is offline   Reply With Quote
Old 05-23-2018, 01:15 PM   #53
RADustin
yeah my current un-restored doors are all torn up from the mirrors over the years.
The tripods and bigger ones really point load the door where its not supported.
I'm not sure if they are west coast or not, but I have seen some smaller versions of the ones that bolt at the top and bottom of the windows. I'll have to try and find pics.
1949 Chevy 3100 P/U
Old 07-05-2018, 01:05 PM   #54
RADustin
a little update to catch everything up to current.
kept working on the core support, it's mostly done.
welded out the vertical supports.
knocked them smooth and planished back flat
bent up a lower pan. had to do 2 pieces and weld together because my brake is short.
the pan actually passes up the top of the body bushing, I had to do this because of the height of the intercooler.
dimpled it for strength.
my plan is to use the stock battery mounts for the '76, so I had make that work with the cutting I've done. kinda cool for the 2nd battery tray the core support is center punched for the holes but they aren't drilled.
made pieces to finish off the bottoms of the vertical supports.
also made caps to finish the very bottoms
top IC mounts are machined and welded in the top of the core support bar.
got everything welded up and did a test fit.
had to modify the top header panel
lengthen the grill mounts
reshape the bottom of the hood latch support
I could get everything put on the truck now, so I shifted focus back to the front suspension. I needed to make the truck a roller so the shop floor could be painted.
The front coil bucket laser parts can in so I got them bent, fit, and welded up.
installed
1949 Chevy 3100 P/U
Old 07-05-2018, 01:14 PM   #55
tinydb84
tinydb84's Avatar
Everything about this is impressive.
David
Instagram: myfabguy
Old 07-05-2018, 01:20 PM   #56
SCOTI
SCOTI's Avatar
Loving this. Thanks again for sharing your build details.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-05-2018, 01:53 PM   #57
RADustin
thanks!
fighting the pictures sizing but it looks better now.
I'll keep going..
1949 Chevy 3100 P/U
Old 07-05-2018, 02:10 PM   #58
RADustin
with the coil buckets done I moved to rebuild the front axle. All new seals, modified brackets, warn hubs, brakes, paint, etc... ready to go. also installed the Reid Racing high steer knuckle.
what I started with-
axle needed a rebuild. hubs were leaking water.
disassembled- diff cover cleaned up. welded up some scarring.
swapped out the stock panhard bracket for one I made.
also added the sway bar mounts
wire wheeled everything
washed off
painted
painting knuckles
finally reassembled
I was able to toss the finished axle underneath and bolt up the coil overs and had a roller for the first time.
since I had to move for a little while I loaded most my tools in the truck. It held the weight fine- probably around 1500lbs of stuff.
while I was displaced I went ahead and reamed the pitman and machined a spacer for the TRE.
also planned out all my trailer hitch stuff.
the front hitch has recovery padeye on each end. then a standard receiver in the center. padeyes are 5/8" plate to 3/8" mounts. much heavier than I'm used to working with but I made it work.
rear hitch is a late model GM hitch cut down width wise. Made the frame brackets from some scrap 6x6x1/4" material I had laying around the shop.
I have a little bit of work left on the rear hitch then I'll be working on a steering brace/crossmember for the front.
I'll try to update more frequently to keep things manageable.
1949 Chevy 3100 P/U
Old 07-05-2018, 04:23 PM   #59
aggie91
I'm just glad to be here!
aggie91's Avatar
Awesome fabrication work. Really enjoying your build.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 07-05-2018, 07:20 PM   #60
Devilman
Yay!!!!!!! Truck Porn!!!!!!!!!!!
Devilman is offline   Reply With Quote
Old 07-05-2018, 07:42 PM   #61
rharris
rharris's Avatar
Geez. I was proud of myself for putting on an intake, lowering springs, and a power brake booster. Then guys like RADustin gotta come along.
Amazing work. You have got to be a fabrication Genius. Girlfriend is a square body and Duramax nut - can't wait to see this one done. Beautiful work
72 Cheyenne Super C10 SWB
2001 Silverado 1500HD Crew
2011 Silverado 2500HD Crew Duramax (Hers)
rharris is offline   Reply With Quote
Old 07-06-2018, 08:23 AM   #62
RADustin
Thanks guys- glad yall are enjoying the progress.
1949 Chevy 3100 P/U
Old 07-06-2018, 08:27 PM   #63
Advanced Design
Advanced Design's Avatar
Impressive design and fabrication....great welds too!
Advanced Design is offline   Reply With Quote
Old 07-07-2018, 08:52 AM   #64
Wraith
Unbelievable work, can't wait for more updates!
Wraith is offline   Reply With Quote
Old 07-07-2018, 02:18 PM   #65
Old 07-08-2018, 09:05 PM   #66
cruizin01
super awesome.
'78 C10 Build
cruizin01 is offline   Reply With Quote
Old 08-10-2018, 02:22 PM   #67
Devilman
Bump!!!! It's time for some updates!! Hopefully you're done with my copy of your suspension
Old 08-10-2018, 05:20 PM   #68
83GMCK2500
I've seen some cool updates on instagram! Hoping they make it here...
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 08-10-2018, 06:24 PM   #69
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Amazing work you're doing here! I'm really jealous of the 3d scanning and the planning it all in solid works. You are doing an awesome job and your fab work is excellent! Do you work in a body shop full time?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 08-15-2018, 03:27 PM   #70
RADustin
I'll get an update put up. Been working off the list everyone hates- all the small detail/odds/ends parts.
Thanks! No I have access to a body shop(my fathers) but I don't work there. I worked summers growing up but my day to day is design engineering.
I treat fabrication as a craft and a hobby. It's something I'll never be good enough at and always push to get better. At the same time, I'm not sure yet how to sustain my current income and do it as a job- so it remains a hobby.
1949 Chevy 3100 P/U
Old 08-15-2018, 06:07 PM   #71
Dieselwrencher
By looking at your work I'd beg to differ that you couldn't do it for a living. But I know all to well what you mean. The costs of equipment to get going is no cheap deal nor a small feat. Either way, keep up the great work!
Ryan
Old 08-22-2018, 09:18 AM   #72
SBTork
Garage wrench
SBTork's Avatar
Awesome work! Love the fab work
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 08-22-2018, 02:53 PM   #73
daddyjeep
daddyjeep's Avatar
I will certainly follow along with this one. That is the suspension that I will build some day. I am sure mine will net be as pretty though.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 08-27-2018, 02:00 PM   #74
Low Elco
Fantastic update! I love this build.
Low Elco is offline   Reply With Quote
Old 08-31-2018, 03:02 PM   #75
RADustin
yep! and I have a certain way I'd want to do things- and being picky costs even more $$.
thanks
you may be able to buy this exact setup, with instructions on the installation
1949 Chevy 3100 P/U
