11-28-2022, 08:37 AM | #751 | |
Re: Bench Seats, Having them Reupholstered
Seat belts are another matter. Not something you want to trust to just anyone. With the hit and miss quality of LMC, it's probably better to just have oem restored or go with someone with a reputation for high quality. |
11-28-2022, 09:08 AM | #752 | |
Seatbelts, I haven’t found an aftermarket place that has good working seatbelts yet. Sure they are new, but if they don’t function well, then why waste the money.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
01-16-2023, 03:39 PM | #753 |
Need some advice . I’m doing my seat in my 68 and the foam is perfect but the new cover is loose and if I try to stretch it the pleat fold under the seat seems to need more padding . Looking at high density foam but not sure of thickness . Also what’s the best way to fix a broken spring the frame is in in incredible condition still shines black with no rust . Any advice would be greatly appreciated.
01-16-2023, 03:41 PM | #754 |
The seat back still has the jute covered in cloth should I put the foam under it ? I’ve done a lot of seats but with all new foam .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 01-16-2023 at 04:06 PM. |
01-16-2023, 06:52 PM | #755 | |
It’s hard to say on the foam thickness, 1/2”-1” maybe. I actually use jute as a filler. I use it between the springs and foam.
01-17-2023, 04:01 PM | #756 |
Thanks . I picked up some cushion wrap didn’t think of using jute under the foam might go pick some up as it will help protect the foam from the springs the burlap is rotted away . The foam is in great shape but I’m sure it’s compressed that’s why it’s loose . I have an old box spring that I can steal some springs off . Just need to heat and normalize the steel , shape then harden/temper again just like making a knife
02-26-2023, 02:14 PM | #757 |
I can tell it’s getting closer to Spring, I’ve had a couple of seats to do.
Here are a couple of Blue Velour Deluxe, 1981-1987.
03-13-2023, 05:28 PM | #758 |
1981-1987 Black Velour Silverado Deluxe. This is fully restored and will be picked up later this week.
03-16-2023, 09:26 AM | #759 |
What's your timeframe and price? I need a seat redon3 for my 84 Silverado. It is currently covered in vinyl, I want to convert it to cloth. Whay are my options? You can PM me if you don't want to discuss in this thread. Thanks,
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-16-2023, 11:52 AM | #760 |
PM sent with contact info.
03-21-2023, 07:28 PM | #761 |
Took advantage of the somewhat milder weather and got some seat frames back from the sandblaster, and got those repainted and repaired. Replaced the broken End Springs on the 73 seat frame. Also got the tracks for the same seat restored and installed a new knob for the one that was missing.
The 81-87 frames, some of the springs were replaced. A few of the other frames received all new Grids & Springs. Before Pics
03-21-2023, 07:33 PM | #762 |
After Pics
03-29-2023, 09:52 PM | #763 |
1981-1987 fully restored Black Velour Deluxe Benchseat. New Grid and Springs also.
04-23-2023, 02:26 PM | #764 |
Just completed a fully restored bench seat in Burgundy Velour. This will be used for a front seat in a Suburban. Will be picked up later this week.
05-04-2023, 06:48 PM | #765 |
Here’s a fully restored bench seat that was done for someone. 1981-1987 Blue Velour Silverado Deluxe.
05-05-2023, 07:03 PM | #766 |
Another Burgundy for someone local
05-25-2023, 10:09 PM | #767 |
1981-1987 Black Velour Custom Deluxe. Fully restored, using a new foam, Gris and springs.
06-11-2023, 12:53 AM | #768 |
Well crap. Discovered today my 85 seat is literally falling apart. The lower horizontal bar has detached. Also noticed the back foam seems to be attached to the frame. How is this replaceable? @TKCR, is this fixable? If not, can you PM me. I have questions on getting a rebuilt unit from you. Looking to change to black. Thanks
06-11-2023, 09:46 AM | #769 | |
The foam on the back, since it’s attached, would just need repaired versus replaced. What you found, is typical on almost every seat I repair & restore. That why I restore the seats the way I do. Most upholstery shops wouldn’t care about this stuff. Most people were never even aware that their bar was even broken. Last pic shows the typical GM weld missing on the backside of the seat sack bar.
06-23-2023, 10:17 PM | #770 |
Re: Bench Seat, Having it Reupholstered
I am reupholstering a 72 GMC C15 bench seat. I have new foam on and the new cover was a tight fit after putting it on in the Arizona sun. After reattaching the seat together, I have a 2-3 inch gap in the middle. Any tips to remedy that? Thanks for any help you can provide!
07-11-2023, 08:24 PM | #771 |
NOT For Sale
Got another seat restored and built for someone. This is a 1981-1987 Black Velour Deluxe. Fully restored. Will be picked up later this month. Gettin down to the nitty gritty on the seat cores I have left to use. Once they are used up, I will no longer be doing anymore seats. I will mainly be restoring the seatbelts only.
09-04-2023, 10:04 AM | #772 |
Been getting the last of seats done for people. These have all been picked up.
This is my new RECORD. Came from Texas, 16.5 hrs one way!
09-04-2023, 10:05 AM | #773 |
Picked up from Wisconsin! I did drive about an hour to meet, to save a little drive time.
09-04-2023, 10:10 AM | #774 |
And this one drove from the St. Louis, MO area. 7 hrs one way!
09-07-2023, 08:13 PM | #775 |
1981-1987 Black Vinyl. Fully restored with New Foam, new grid and all new springs. Being picked up this weekend.
