Old 06-01-2020, 10:19 PM   #826
arkracing
Weekend Warrior
Re: How about some pics of Static Dropped C-10's
Thanks for the responses guys. If Bagging it doesn't really achive better results unless you use AM front xmember etc, then Im perfectly fine with static.
I understand that the lower you go the more you comprise in ride quality, but I'm still slighlty confused I guess. I see alot of guys running 5/7 and seem to be ok, but who knows for sure. I had a 69 shorty step about 15 years ago with just a ece 2/4. It handled good, just still looked high lol.
Problem fo me is, the look that I like is this pickup.
I messaged the owner...6/8 static and claims it rides good. I guess ride quality is all relative to whos driving.
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 06-01-2020, 11:26 PM   #827
SCOTI
SCOTI's Avatar
The statement "it rides good" is very subjective.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-02-2020, 08:00 AM   #828
66clow
66clow's Avatar
Probably rides good until your on a rough road or need to avoid some dips or pot holes. 😁 But it's a matter of what you are willing to deal with.
66clow is offline   Reply With Quote
Old 06-02-2020, 09:18 AM   #829
SCOTI
SCOTI's Avatar
Originally Posted by 66clow View Post
Probably rides good until your on a rough road or need to avoid some dips or pot holes. �� But it's a matter of what you are willing to deal with.
This.
I bet most people use this statement because on a nice smooth road surface a truck that's <3" off the ground will do just fine. But as soon as the irregularities start, that 'rides good' statement goes out the window. Some will say "it's all part of it" (it being the experience of owning/driving a lowered classic truck).
I've driven my 'classics' daily. I've only had 2 or 3 vehicles along my journey that weren't hot-rodded or lowered but they were temporary rides. After tolerating the constant collisions caused between a lowered truck & common road surfaces I started building w/the mandatory clearance requirements (4" min ground clearance; 3" compression travel/clearance). That made a big difference in the driving experience.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-02-2020, 10:11 AM   #830
blazer2007
I have one static and one bagged. The static one can be embarrassing in the spring when road construction starts and I can,t make it over a deep cut out on the asphalt ,out comes the 2x4,s.It,s not too low, spindles and 1 cut coil but still run into the odd road. Air bag one, just push a button
blazer2007 is offline   Reply With Quote
Old 06-03-2020, 08:33 AM   #831
arkracing
Weekend Warrior
Again thanks guys. Basically what you are all saying is "buy the ride tech streetgrip setup" sacrifice a little bit of "the look" lol
-'66 C10 Suburban
Old 06-03-2020, 09:16 AM   #832
SCOTI
SCOTI's Avatar
You're going to get opinions all over the map on this. If you like putting miles on your 'hot rod' every chance you get, then whatever method you choose make sure its engineered for & offers adequate clearance to work.
Ridetech is a reputable source but it will come down to your set-up parameters if/where things are adjustable (settings things to their spec or setting things to "OMG that looks BA" can yield two distinctly different ride/driving quality experiences). The 'Street Grip' line of kits definitely seems a good choice.
Me personally? Their Street Grip would not be low enough because they build the set-up around the limitations of the lowest point on a C10.... the front x-member & a-arm pivots. In order to have good ride characteristics, that point needs to be ~5" off the ground which puts you @ about a 4/6 - 5/7 drop when cruising. Moving those pivot points higher up on the chassis/rails gets you lower w/the same amount of clearance. Of course, old school dropping the body over the chassis can yield a similar result.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-05-2020, 08:25 AM   #833
xabichin67
Junior Member
[QUOTE=SCOTI;8750093]When you get past 4/6 static drops using OE geometry/pick-up points, the driving experience diminishes quickly.
I drive my stuff low (5/7 or more). With no mods, it does suck on crappy roads. Static or air doesn't make a difference if you're bottoming out. To make it better, I use a modified factory or aftermarket raised front x-member. It allows for the more aggressive drop I like while provide additional ground clearance. The additional ground clearance is only part of it though. Once you have the aggressive drop w/a modified or raised x-member, you now will most likely need some raised fender wells so the tires don't constantly buzz.
SCOTI, What are you doing for steering on the raised factory X-Member
xabichin67 is offline   Reply With Quote
Old 06-05-2020, 09:04 AM   #834
SCOTI
SCOTI's Avatar
The box, pitman, & idler all remained in the stock positions. I've done the multiple combo u-joints/shaft on one & standard shafts on others w/the upper 63-72 drivers side a-arm c-notched for clearance. My dually has a standard straight shaft w/the a-arm notched.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-06-2020, 09:18 AM   #835
xabichin67
Junior Member
I've got one that is sectioned 2" but set it aside because I thought I would have to raise the steering box and mess with the idler arm.
Do you think I'd be okay with the 2" section and leaving the steering components in the stock location.
Old 06-06-2020, 12:32 PM   #836
SCOTI
SCOTI's Avatar
I know others have done the 2" amount. I've felt that a 1.5" sectioning is pushing things & never ventured beyond. If doing 2", I would personally switch to an aftermarket R&P or raise the steering box, idler, & notch the lower frame rail as needed for tie-rod clearance. This is what I would do if I had the tools for the job & was watching the budget:
http://67-72chevytrucks.com/vboard/s...d.php?t=799484
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-06-2020, 09:16 PM   #837
LS short box
Mine with a 4/6 drop. Ride is firm but very easy to live with as a summer cruiser. Nice part is speed bumps are no issue.
LS short box is offline   Reply With Quote
Old 06-07-2020, 05:42 AM   #838
Hart_Rod
Hart_Rod's Avatar
4.5/6, 15's with some sidewall make the ride pretty nice...
Hart_Rod is offline   Reply With Quote
Old 06-14-2020, 11:10 PM   #839
FarmTruckFred
3/5 drop.
1967 C10
1972 Monte Carlo
FarmTruckFred is offline   Reply With Quote
Old 12-21-2020, 02:22 PM   #840
Syclone3Mt
Syclone3Mt's Avatar
My 72' 2.5" / 4" drop. Not much of a drop but drives really nice.
Syclone3Mt is offline   Reply With Quote
Old 02-19-2021, 01:24 AM   #841
v8truckin
What’s your hub center to fender height? Trying to figure out if mine was lowered 3/4 or 4/6. Wanna lower her another 1” to fill the gap a bit with my new 22” on 30series rubber
v8truckin is offline   Reply With Quote
Old 02-19-2021, 06:11 PM   #842
KQQL IT
At the body shop.
KQQL IT's Avatar
My 73
Clipped 2 coils
And welded new axle pads on the bottom of a 3.25 tube 9 inch
No notch.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 03-31-2021, 01:38 AM   #843
70chevc10
70chevc10's Avatar
This is long overdue but I finally installed the ECE suspension I've had in the garage for about 4 years Here are some details:
ECE 4.5/6 drop with drum to disc conversion with (2.5" drop spindles and 2" drop springs) Rear has 6" drop springs, shock relocator kit, and super track bar kit. It's frustrating that they are unavailable for support as a number of small parts were missing (banjo bolts, prop valve mounting kit and lines, dust caps, etc.).
Tires are 255/55R18. I have since put different Nitto NT421Q tires on but no pictures yet. Wheels are Eagle Alloy 146s I'm guessing BS is 4.5 or 5.5. While the tires fit with very little clearance, I'd suggest a shorter tire.
Overall it's riding really well but the brakes are dragging so I'll need to figure that one out.
70chevc10 is offline   Reply With Quote
Old 03-31-2021, 07:55 AM   #844
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Forgot to add my old Farmer Truck here. ("Betty")
6" F ~ 3" Belltech Spindles, 1.5 rounds cut off stock coils
9" R ~ Is a TinWorks Rear Axle Flip / C-Notch Combo Kit
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 06-08-2021, 08:59 PM   #845
v8truckin
5.5” front & 7” rear
Old 07-07-2021, 06:47 PM   #846
bob arrington
Originally Posted by fastcam1 View Post
Anyone have pics of a static drop around 5/7 with 20's?
not pretty...yet...lol
bob arrington is offline   Reply With Quote
Old 08-30-2021, 02:48 AM   #847
cornfed
cornfed's Avatar
Maybe got a little carried away but I dig how it turned out. Cheap and low. Jaguar ifs up front, explorer 8.8 and suspension out back. 20x9.5 and 20x11.5. Rides great because both suspensions are totally stock.
68 blazer buggy
68 stepside
58 gmc
cornfed is offline   Reply With Quote
Old 08-30-2021, 01:26 PM   #848
MySons68C20
MySons68C20's Avatar
Hey cornfed, I like the interesting route you went with the suspension.
Do you have a build thread or? I can't view the pics in the link.
MySons68C20 is online now   Reply With Quote
Old 08-31-2021, 11:36 PM   #849
gringoloco
A guy with a truck
gringoloco's Avatar
Nice, and agree: need more pics!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-18-2021, 09:37 PM   #850
Ben IV
4.5/6+. Spindles and springs up front flipped axle in the back.
70 GMC custom short bed conversion
69 GMC panel truck
Ben IV is offline   Reply With Quote
