12-24-2015, 12:09 AM | #851 | |
Re: 48 Burb, bagged, 5.3, 20 year wait
I tried just about everything out there. All had pros and cons. I decided on vps they are now making systems for lmc. But a little pricey |
12-24-2015, 12:21 AM | #852 |
AD...planning on putting a ls with carb in the 56 post I picked up. Looks like more room. Any problems when you put one in your 56?
12-24-2015, 02:45 AM | #853 | |
CPP small block stands and mount to the LS plate, Camaro exhaust manifolds, GMPP CTS-V accessory drive, KWIK for high mount Sanden (before Holley brackets) and it was pretty well bolt together. Lot more room under the hood than an AD truck. Before you go carb, maybe check out FITech. From what I've been seeing around here, it is a high quality and very affordable throttle body style injection system. Here is a build with one starting at post 392... http://67-72chevytrucks.com/vboard/s...605736&page=16 Be cool if you did a build thread under alternate tinkerings. Accessory drives...I am following your lead on engine setback and looked at the front runner system you used. Yep pricey. Are you happy with the system? Do you remember how much room you have from front of block to radiator mounting flange? Are you still happy with the R and D radiator?
Doug Advanced Design’s 1977 Blazer Build Advanced Design's '48 'Burb Build Mrs Advanced Design's '72 Suburban Advanced Design's 56 BelAir LS swap Last edited by Advanced Design; 12-24-2015 at 02:50 AM. |
12-24-2015, 01:11 PM | #854 |
Side note, not to deter from the pullies, but that FItech looks awesome. I'll def be keeping them in mind.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
12-24-2015, 05:35 PM | #855 | |
Ok, after standing around with a measuring stick and staring at it for awhile yesterday I did go ahead and move the engine back 1 1/2 inches. You know the drill...remove engine and transmission, cut tabs off of frame, grind smooth, reinstall to position and mark new tab for drilling, tack tab in, remove engine and trans so you can weld the tab, reinstall....folks that don't do this don't know how much work it takes. Heavy work keeps me alert too just in case the hydraulic cylinder on the engine hoist lets go. Anyway, I now have and inch from the snout on the truck water pump to the back of the fan on the R and D radiator...assuming the dimensions they gave me are accurate. And I have 9 inches from the block face to the back of the fan which should leave room for a front drive system in the event I decide to go that way. Based on advice from Iceburgh over on Youngrodders Burb build, I am leaving the recess cut outs open until I decide for certain what I am doing for an intake. His fuel rail on the new intake intersected the firewall. Bummer, especially since he has really nice paint. |
12-24-2015, 05:39 PM | #856 |
Comparison, before set back.
12-24-2015, 10:48 PM | #857 |
nice progress and pics. I think if I have this problem, I'm going to cut out the firewall recess, widen it and reinstall, so it looks factory just much wider.
12-24-2015, 11:42 PM | #858 | |
So, rather than figure out if that would work spacewise under the dash or not, I just went this route. |
12-25-2015, 12:16 AM | #859 |
haha great minds think alike, but you guys had me beat as I wasn't thinking that far ahead! I suppose you could get VA dimensions and make it up out of cardboard, put it in and figure out if it would interfere.
12-25-2015, 12:49 AM | #860 |
Agreed $1000 is a great price all others are in the $2200 range. Might go this route in the '56.
12-25-2015, 12:58 AM | #861 | |
If you look at what I have it works and it is compact. The alternator need a bracket made for it to give it more support. Easy fix. This came out after and about the same price and looks a little better I think.http://www.lmctruck.com/icatalog/ca/full.aspx?Page=79 Any way lots of trial and error or $$$ or both |
12-25-2015, 10:12 AM | #862 | |
Iceburgh, thanks for the link. This looks a little beefier than what is on their website and I like it is now available in black. While pricey, it is less than the VA package at @ $2,900. My engine is back far enough now I think this will fit. |
12-25-2015, 03:29 PM | #863 |
It will still fit. I just went out and looked at mine. I have lots of room between the VA and the dash, and I mounted mine so that it hugs the firewall pretty tight. You could easily bump it back another inch and have all the room you'd need to for your inset extension.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
12-25-2015, 07:38 PM | #864 | |
12-27-2015, 11:39 AM | #865 |
There is one important element I didn't remember about accessory drive fitment when going through this.
Where is the back of the fan in the vertical plane in relation to the water pump pulley snout? Looking at Tessone's build, I notice the back of the fan is above the snout. So, before moving the engine back into the firewall, I should have bought the radiator package and tried it to see. Of course I could pretend I really cleverly planned this so a front runner would fit. 99, maybe this will save you some work on yours. |
12-27-2015, 11:45 AM | #866 |
Had a lot of fun with friends yesterday painting the frame on his 65 Pontiac wagon.
12-27-2015, 11:48 AM | #867 |
Engine and frame back in place. You can get so much more done with four guys than working along.
12-27-2015, 12:13 PM | #868 | |
Mine is above it as well. One more thing to think about is where the air inlet for the intake will route. I wanted fresh air so it comes out and does a 90 through the fender. It fits between the alt and fan but it is a tight fit. |
12-27-2015, 12:18 PM | #869 | |
One more family Christmas then hopefully good shop time rest of this week. |
12-27-2015, 09:20 PM | #870 | |
http://www.vintageair.com/2015%20Cat...atalog%206.pdf |
12-27-2015, 11:26 PM | #871 |
Keep at it Doug. Push past that last party and hit the garage. I have been making some progress the past few days.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
12-28-2015, 12:20 AM | #872 |
On it....multi-tasking!
12-28-2015, 12:10 PM | #873 |
good pics, yeah def am getting radiator and headers for when I moch up engine. Ordering them soon.
12-28-2015, 05:07 PM | #874 |
What if you only went about half way up with the widening and fan it into the curve at the top? That could leave you enough room for both the VA and leave it looking oem. Nice progress, I am at this point also and having everything you will be using in the final build sure helps alot!
My Build: 57 Chevy Pro-Street |
12-28-2015, 05:31 PM | #875 |
been slowing going through the build thread per your PM, this is going to be one cool project!
