Old 09-17-2013, 08:27 PM   #76
theastronaut
theastronaut's Avatar
Re: How To Restore and Detail an Original Gauge Cluster
Originally Posted by Acksman View Post
This is a great guide. I have been following it step by step. There was only a couple of places I changed things.
On the intermediate plate I was able to soda blast and came out without any warping or pitting. Did a nice job.
Also on the back of the intermediate plate I used Krylon Glowz to see if that will help with a brighter cluster. Here is the Glowz http://www.krylon.com/products/glowz/
Still waiting on a few parts to finish, but will post some pics once I'm done.
I didn't try soda blasting, great to know that works well on the thin aluminum! The glow in the dark paint will keep the cluster illuminated even after you turn the switch off at night, pretty neat.
theastronaut is offline   Reply With Quote
Old 09-17-2013, 08:35 PM   #77
theastronaut
I picked up a 60-63 cluster to restore, does anyone know if the tach needle is supposed to be below the backing plate at rest? I'm thinking it's broken. I know that 64-66 tachs are visible at rest, but those are a different model tach.
It doesn't have a pin to rest on like the air pressure gauge does.
Old 09-17-2013, 08:44 PM   #78
duallyjams
duallyjams's Avatar
Another cool one to watch.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 09-17-2013, 09:44 PM   #79
1963c-10
1963c-10's Avatar
great idea on the turn signal tubes
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 09-17-2013, 09:46 PM   #80
1963c-10
1963c-10's Avatar
& tach needle looks broke....mine stops at 0
Went out this a.m., my tach needle holds about 1/4" below zero if it helps any.
Old 09-18-2013, 03:28 AM   #81
scum1
scum1's Avatar
Does anyone know the ac delco part number for the speedometer GEARS..mine are broken and no one seems to be able to replace them. i just need the gear inside. one guy said if i find the part number he can most likely get it, but not without it. any help?? thanks!
scum1 is offline   Reply With Quote
Old 09-18-2013, 11:44 AM   #82
Budman56
Budman56's Avatar
theastronaut take a look at the gage when you get it out it should stop on the 0 or real close the needle may have come loose from the magnet. I had one that did that and I used a little super glue to reglue it to the magnet.
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 09-18-2013, 11:46 AM   #83
theastronaut
Thanks, hopefully it can be fixed. It is certainly well below the zero mark.
*Edit*, checked it and it was broken loose at the magnet like you posted. Just needs gluing back together. Thanks for the tip!
Old 09-18-2013, 11:51 AM   #84
Budman56
Budman56's Avatar
did the glow in the dark paint come in jade green? what was the part number on the can?
MY 65 C20 BUILD
Old 09-18-2013, 11:55 AM   #85
1963c-10
1963c-10's Avatar
the astronaut, I think I have a delete plate for the factory gauges if you decide not to use the air guage or a vacuum guage.
Old 09-24-2013, 01:49 PM   #86
burbluv
burbluv's Avatar
Anyone know what black spray was used for the interior?
Thx
burbluv is offline   Reply With Quote
Old 09-24-2013, 05:07 PM   #87
theastronaut
Thx
Krylon Satin Black.
Old 10-30-2013, 09:59 PM   #88
blazer719
blazer719's Avatar
Astronaut, nice cluster restore. Last one I did was a 1938 chevy. The 60's trucks have a lot more parts. Very Nice documentation for sure!
blazer719 is offline   Reply With Quote
Old 10-31-2013, 04:21 PM   #89
Old Bleu
Old Bleu's Avatar
This thread gave me the confidence to tear into my cluster. But does anyone have a tip for getting a stuck bulb out of a rusty socket? I was able to work all of them out but one. This last one does not want to push in or turn at all...
Old Bleu is offline   Reply With Quote
Old 10-31-2013, 04:54 PM   #90
NEWFISHER
NEWFISHER's Avatar
Soak it with penetrating oil overnight
NEWFISHER is offline   Reply With Quote
Old 10-31-2013, 06:57 PM   #91
Old Bleu
Old Bleu's Avatar
Thanks Newfisher. After I posted I actually did soak it with PB Blaster. Then after dinner I got some needle nose pliers down on the base under the glass, and was able to get it moving and out.
These old trucks sure teach you patience!
Old 11-04-2013, 09:34 PM   #92
theastronaut
Finished a 60-63 tach/air cluster a couple weeks ago.
Old 11-04-2013, 09:44 PM   #93
Budman56
Budman56's Avatar
looks good, FYI I have the decals for this 60 to 63
MY 65 C20 BUILD
Old 12-17-2013, 09:55 PM   #94
JWheeler331
JWheeler331's Avatar
I am redoing one that does not have any of the control knobs on the bezel. When I look in LMC or other catalogs the wiper knob does not appear to have the part in the middle of the knob that I see in some of the photos.
I don't know what that part is for so I guess im wondering what it is and also wondering that if I order those parts from someone will they come with the right knobs.
Our 1965 Build
http://67-72chevytrucks.com/vboard/s...79#post6204879
JWheeler331 is offline   Reply With Quote
Old 12-17-2013, 10:04 PM   #95
Lugnutz65
Lugnutz65's Avatar
Some trucks came with a washer fluid squirt button like this one I have from a 66 parts truck.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 12-18-2013, 12:00 AM   #96
JWheeler331
Oh okay. I didn't know what that was for. I just seen some with and some without. I don't even know what line came with but I think prob without. Don't recall seeing a reservoir under the hood.
Our 1965 Build
Old 01-07-2014, 06:08 PM   #97
lenguini
lenguini's Avatar
Just want to say fantastic work here ! Thank you for sharing.
Subscribed.
Always a place in my heart for old Chevy trucks:
My build thread-project truck dream 65"
http://67-72chevytrucks.com/vboard/s...d.php?t=510863
lenguini is offline   Reply With Quote
Old 01-07-2014, 06:56 PM   #98
theastronaut
Subscribed.
Thanks!
Old 01-07-2014, 09:07 PM   #99
64shortc10
64shortc10's Avatar
How much you charge for a 64-66 cluster with tach, and clock installed? The tachs work with hei distributor don't they? You do such nice work!Thanks
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 01-07-2014, 09:28 PM   #100
VonDog
VonDog's Avatar
Hey astronaut, thanks soooo much for this thread!!! I rebuilt mine in my 60 K-20 about a month ago and it's Awesome! Now the speedo and odometer work and the fluorescent red is spot on! This site is so fricken cool!!! Thanks again!
VonDog is offline   Reply With Quote
