Old 03-20-2013, 10:07 PM   #76
thotfulspot
Re: First Time Swapper
It's great to learn how to tune but do your research first and have someone experienced check you first couple tunes. I've seen some ugly results from people doing their own tunes on BMWs. They are more difficult since they are tuned pretty strong from the factory. A lot tougher than the LS motors, but when people start doing their own tunes for forced induction and end up with holes in pistons. Not trying to talk you out of it because it's nice to be able to do it on your own. An hour on a dyno with an experienced tuner will give you the biggest gain. You can make little tweaks after that.
I've got the BMW software and all I use it for is to change factory settings for windows and stuff like that. I have a local expert that does everything else for me.
thotfulspot is offline   Reply With Quote
Old 03-21-2013, 12:55 AM   #77
Billett
Billett's Avatar
I realize it is a large undertaking, but computer programming in general is second nature to me so I'm not that intimidated by the tuning itself. I have a friend that runs a company called SpeedCircuit that does parts and tunes for Mitsubishi Evo's so I'm going to talk to him about it. I'm wondering if he would be willing to let me buy the program myself so I can still mess with it whenever I want, but I'll pay him the shop hours for the initial tune and any problems I may have for him later down the road.
ls1nova, I've checked out your ls1tech build thread a ton. Very useful. THANK YOU!
No need to worry about me burning out. This is my DD and while it's down I'll have to drive my brothers honda civic. There is no better motivation than that. Good to know about the 4l80 wiring. Didn't realize they were different. TBSS manifolds may be where I'm heading right now unless I can find a set of 4th gen headers for around the same price. Trimming the frame or mounts a bit so they fit won't bother me. As for the harness, There's a complete one on CL I'm looking at, but I always like to have a backup plan so it's nice to know I can grab the ends from the junkyard if I get desperate. I looked into the engine stands a bit as well. Someone on here used those style stands with the dirty dingo slider mounts. Looks a lot easier, but for that price I can't do it. The stands and mounts though will be a breeze. There are plenty of those trucks in my local junkyard. I'll definitely need a new radiator, and overflow bottle for that matter haha and I'm hoping I can trim those fans to fit.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 03-21-2013, 01:11 AM   #78
thotfulspot
Use your friend as much as possible. At least at the beginning. Doing a tune is not typical development. I wrote code for 20 years and tuning is making adjustments to the various sensors. I'm not trying to talk you out of it. It's actually a lot of fun seeing what happens when you make changes. A lot of people just jump into it without realizing what it involves. I would have someone do a baseline with a dyno. Play to your hearts content and after you are done put it on the dyno to see what the difference is.
There are a couple people on CL in Chicago that modify and build harnesses for a couple hundred. One of them is on LS1TECH. Might be worth checking out. The one person says he can build a harness that all you need is the start connection.
Old 04-22-2013, 07:26 AM   #79
Billett
Billett's Avatar
Haven't been on in a while but I did pick up a 4l80 from a 95 van. Also got the engine torn down but not cleaned yet. Well torn down as far as I want to go. Heads are off but the crank is staying in. Pics coming soon
Will
2024 Toyota Sienna
Old 04-23-2013, 02:38 PM   #80
Hart_Rod
Hart_Rod's Avatar
Sweet! Are you changing the cam while you have it tore down? This is what I did to my 2013 L99 motor.....
Hart_Rod is offline   Reply With Quote
Old 04-30-2013, 09:29 PM   #81
Billett
Billett's Avatar
No, no cam. Gaskets are as far as I'm going.
These aren't the best, but I'm going to do a serious post on my build thread when I get a chance this weekend. Right now it's just a matter of what can I save on. Gonna keep my current radiator since it still works and just run the steam vent to the water pump. I was looking into motor mounts for a few days before I realized that my current engine is an '87 sbc so all I'll need is an adapter plate. I'm just going to cut one of those myself. Bought all the gaskets, and I'm trying to decide on fuel lines right now. I'm leaning towards bending some hardlines with a few short teflon/rubber sections in between. Gonna buy the wix filter, but my engine has the built in regulator on the rail.
Also, just a quick teaser. I had been planning on shaving the truck intake and cleaning up the hoses and wiring, but now I won't have to my brother brought me home a sweet TBSS engine cover. Plan is to paint it white with red stripes and I took the SS sticker off and I'm going to paint the Texaco logo in the center. Should look sweet with the rest of the truck.
Will
2024 Toyota Sienna
Old 05-01-2013, 11:21 AM   #82
Wasted Income
Boosted Member
Wasted Income's Avatar
I would put a "normal" fuel filter in line, and use the truck rails with the regulator...not the corvette setup that everybody seems to use. It's a little more work to run the return line, but worth the work if you ever plan on really turning up the wick on it.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 06-02-2013, 08:37 PM   #83
Billett
Billett's Avatar
Another quick question. I was talking to my brother and we're thinking that I should be able to use this PS pump as long as I get an external reservoir, otherwise I'd need a new pump. Anyone use one of these before?
Also, here's what she looks like right now! I'll be a little over budget at about $4k instead of 3 like I really wanted, but the places I put in a bit of extra money make me feel confident about the reliability of this engine. I'll probably start tearing out the 350 this week.
Will
2024 Toyota Sienna
Old 06-02-2013, 09:02 PM   #84
truckdude239
truckdude239's Avatar
i used the stock pump that came with my ls 4.8 just changed the fitting in the back of it to use the 71 lines
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-02-2013, 11:01 PM   #85
Bennett68C10
Bennett68C10's Avatar
Motor looks great, nice job
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 06-03-2013, 12:45 AM   #86
ls1nova71
ls1nova71's Avatar
You have a van PS pump, you just need a reservoir and you'll be good to go.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 06-03-2013, 11:05 AM   #87
Billett
Billett's Avatar
Thanks for the info. I'm going to use a Jack Daniels bottle as a coolant overflow, so I suppose I can work something else out for a PS reservoir. I also need to find something cool to put the PCM in... Few more questions I thought of.*
1) I need to take a look at my wiring harness to figure out which o2 sensors I need, but do the MAF sensors have different plugs? I was looking up part numbers for the lq4 maf and apparently there is an old and new version. Anyone know what the difference is? The old one is a lot cheaper. A list of o2 and MAF part numbers or at least a link would be super as well. The maf I looked into is listed as*AF10043.
2) I've decided that I have enough on my plate right now besides learning to tune. I would like to learn in the future but now isn't the time. I'm between TexasSpeed, BlackBear, and wait4me mail order tunes. I'm leaning towards wait4me, but every time I remember to look on their site I only have my phone on me, and the site requires flash... What I'm wondering is, when these places tune the PCM are they for a specific octane rating or will the pcm realize you filled up with a different octane and adjust accordingly? I know some tuners do that I just wasn't sure about these specifically.
3) I know this has been asked a million times before, but I can't seem to find my calipers at home, and I don't have the time atm moment to look it up, so if any of you know off the top of your head I would appreciate it. What sizes are the inlets to the LS water pumps, and the inlets to the stock radiator? If I recall the top of the LS matches the bottom of the radiator, but I can't remember if they are 1-1/4" or 1-1/2" and I think the other is only 1/4" larger but I can't remember exactly.*
Will
2024 Toyota Sienna
Old 06-05-2013, 10:36 AM   #88
Billett
Billett's Avatar
Solved 2 and 3 bit any help with the maf?
Will
2024 Toyota Sienna
Old 06-05-2013, 11:19 AM   #89
ls1nova71
ls1nova71's Avatar
The AF10043 MAF will work on 99 to at least 06. The newer GenIV engines are different. Vans use a smaller MAF, but the plug is the same as a truck so the are a plug in and go deal.
Old 06-05-2013, 12:18 PM   #90
Billett
Billett's Avatar
Awesome thanks!
Will
2024 Toyota Sienna
Old 06-07-2013, 12:27 PM   #91
Billett
Billett's Avatar
Hit another snag. I have most of the original van harness and when I bought the trans I was given a harness with that as well. The engine harness has the blue/green or blue/red, (can't remember which atm), plugs on it for the pcm, but I don't have the one larger plug for the other row of the pcm. Can this plug be purchased separately? It would be cheaper to re-pin it than to buy an uncut harness. If not I guess I'll pony up for a custom drop in from painless or somewhere.
Will
2024 Toyota Sienna
Old 06-10-2013, 01:38 PM   #92
solidaxel
solidaxel's Avatar
Engine looks great................. would you detail mine for me !!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-11-2013, 07:37 AM   #93
Billett
Billett's Avatar
Thanks but it really looks much worse in person. I was too impatient to paint the block and heads. I might not do the trans either. I did clean the hell out of it though.
Will
2024 Toyota Sienna
Old 06-11-2013, 02:12 PM   #94
thotfulspot
What did you paint the valve covers with? It almost looks like a candy paint.
Old 06-13-2013, 08:03 AM   #95
Billett
Billett's Avatar
For those that need it here is where you can find the pcm connectors as well as terminals for the pins.
http://www.eficonnection.com/eficonn...spx?ItemId=286
Valve covers were painted with duplicolor metalcast. I'll get some pics up around lunch time.
Will
2024 Toyota Sienna
Old 06-24-2013, 12:11 PM   #96
Billett
Billett's Avatar
Sorry about the valve cover pics. Been busy with work and the swap. Did get the old 350 out. Working on the trans cross member so I can pull the np435 out and then I'll start putting it all back together. Fuel lines look like the next item in line
Will
2024 Toyota Sienna
Old 06-24-2013, 12:52 PM   #97
Blackpony
Blackpony's Avatar
What headers are those? I have '10 camaro manifolds right now and looking to do a set of headers soon. those look pretty good!
Also not sure what route you went, but on the adapter plates, I have a set that i am selling. they have been powdercoated a wrinkle black color. Ill let them go for $30 shipped if you are interested...
Blackpony is offline   Reply With Quote
Old 06-24-2013, 06:03 PM   #98
Billett
Billett's Avatar
Headers are Doug thorleys, 1-7/8" primaries. Adapter plates were from eBay with prothane mounts.
Also, thanks for the offer, but only subscribed members can sell parts on the site. Just a heads up. Your post may or may not be edited by a mod.
Will
2024 Toyota Sienna
Old 06-25-2013, 09:20 PM   #99
Blackpony
Blackpony's Avatar
Oh really? i dont venture around the site much.. haha good luck with the build! I am going to have to check out those headers!
Old 06-28-2013, 12:51 PM   #100
Billett
Billett's Avatar
$200 for a black bear mail in or $500 for a dyno tune from Race Proven. Thoughts? $300 is a lot. Will I get that much more drivability, power, etc out of the dyno over a mail in?
Will
2024 Toyota Sienna
