Old 11-01-2013, 11:39 PM   #76
lynnfield
The Waco Kid
lynnfield's Avatar
Re: First Steps LS Swap......
Then the bracket for the pedal and the pedal itself. Cut and replaced some of the padding and done. The last pics makes it look farther to the right that it actually is, just the angle of the camera.
lynnfield is offline   Reply With Quote
Old 11-01-2013, 11:42 PM   #77
lynnfield
The Waco Kid
lynnfield's Avatar
The placement and travel is good and none of the work done to attach the 72' pedal can be seen. Unless you face plant the floor board for some reason………..
Old 11-01-2013, 11:51 PM   #78
lynnfield
The Waco Kid
lynnfield's Avatar
I have ordered my harness from BP Automotive, it should be here in a few weeks. Gauges have been ordered from Classic Instruments, I'll be in Vegas next week at the SEMA show, going to pick them up there and save a little on shipping. Also they do a 10% military/ veteran discount, but you have to call and ask for it.
Old 11-01-2013, 11:59 PM   #79
lynnfield
The Waco Kid
lynnfield's Avatar
Looks like I will have to go with a high mount compressor. The engine plates and mounts are all over the compressor bracket. I'm ok with it though, it probably needed to be moved for several reasons. I can get around the frame and the hooking up of the lines, just kept wondering if I ever need to replace the compressor that would be a pain. Seems like too many obstacles and would be better off being moved.
Old 11-02-2013, 08:41 AM   #80
Hart_Rod
Hart_Rod's Avatar
Nice job on the pedal. If you have any questions about the Holley brackets let me know.
Hart_Rod is offline   Reply With Quote
Old 11-02-2013, 09:21 AM   #81
solidaxel
solidaxel's Avatar
How is the price of the Holley Vs Dirty Dingo brackets?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 11-02-2013, 09:56 AM   #82
Hart_Rod
Hart_Rod's Avatar
I think they are similar and they both work equally as well. I like the Holley ones because they are cast and look like factory OEM brackets.
You can get a complete kit, just AC or just ALT/PS.
http://www.summitracing.com/parts/hly-20-132/overview/
You have to buy a spacer kit for your engine. There are 3 types, Corvette, Fbody, truck and 2010+ Camaro's.
http://www.summitracing.com/search/b...t%20Components
Old 11-02-2013, 10:08 AM   #83
solidaxel
solidaxel's Avatar
I don't remember if the Holley was offered when I purchased my DD brackets, but I do like the holley set up
LS 3 4L70E
Old 11-02-2013, 10:11 AM   #84
Hart_Rod
Hart_Rod's Avatar
I think they have only been out for around a year. Like I said, they both function equally is well, I just prefer the looks of the Holley ones, and for full disclosure, I'm NOT getting any KICKBACKS from Holley.....
Old 11-02-2013, 11:35 PM   #85
lynnfield
The Waco Kid
lynnfield's Avatar
I looked at them last night, the Holley ones are about $149 from Summit for just the A/C side. Looking at the instructions they can be run on one side like the Dirty Dingo. Not 100% sure which one I will use yet.
Old 11-02-2013, 11:38 PM   #86
lynnfield
The Waco Kid
lynnfield's Avatar
Rob, your projects always look awesome. I am doing the truck to kinda get my feet wet. There's a rolled 34,000 mile 06' GTO out here with an LS2 that's waiting to go in my 68' Camaro.
Old 11-02-2013, 11:49 PM   #87
lynnfield
The Waco Kid
lynnfield's Avatar
When I get back after next week the bed is going to come off the truck and I have to start on the fuel system. I saved all the fuel lines from the donor truck and I plan on using as much of those as I can. It's the kind with the return lines, and there's no inline fuel filter. Do I need to add one? I also looked it the tool in "the alien's" post for doing the fuel lines (push connect ends). The tool is $290, anyone used one? Any helpful hints/ suggestions? Thanks Greg
Old 11-15-2013, 01:20 PM   #88
lynnfield
The Waco Kid
lynnfield's Avatar
Bed is off, crossmember out. Having an issue with the tank….
Old 11-15-2013, 01:30 PM   #89
lynnfield
The Waco Kid
lynnfield's Avatar
Since the rear crossmember had to be removed, I may slide the mounting tabs inside the frame rails. That would raise the filler neck a bit. Any thoughts??
Old 11-15-2013, 08:51 PM   #90
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
If my rear cross member wasn't riveted anymore I'd mount the tank with the tabs inside the frame channel.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-17-2013, 02:06 AM   #91
boynton
boynton's Avatar
I am planning on doing this with my long bed soon. This is great info. I should just come set up a camera in your shop!
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 01-17-2014, 08:26 PM   #92
lynnfield
The Waco Kid
lynnfield's Avatar
I have been away a while, but still making a little progress here and there…...
Old 01-17-2014, 08:28 PM   #93
lynnfield
The Waco Kid
lynnfield's Avatar
I snagged this F body pan from a buddy of mine, he had it laying around
Old 01-17-2014, 08:33 PM   #94
lynnfield
The Waco Kid
lynnfield's Avatar
Test fit everything to make sure the pan and exhaust manifolds worked with the engine mounts I used. It's all good, everything fits on the stock trans crossmember and clears my low hump cab! Pinion angle is good also.
Old 01-17-2014, 08:37 PM   #95
lynnfield
The Waco Kid
lynnfield's Avatar
I pulled it all back out to torque the manifolds and pan. Measured the driveshaft while it was in, had to get it shortened 1/2". Currently working on cover plates for the fire wall. Greg
Old 01-17-2014, 09:07 PM   #96
truckdude239
truckdude239's Avatar
Lucky i had almost 6 inches taken out of mine lol
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-18-2014, 07:24 AM   #97
lynnfield
The Waco Kid
lynnfield's Avatar
I had taken about 3" out of it already for the 700R4 I was running. The hope was that it would work as it was, but I guess it's better than being too short. Greg
Old 01-18-2014, 10:39 AM   #98
truckdude239
you never know i known people who have done the swap and not had to shortern theirs at all
David fuller
2000 Tahoe 5.3l 378
Old 01-19-2014, 01:26 AM   #99
68c10airstream
68c10airstream's Avatar
Hi Greg, in post #87 you asked if anyone has used the $290.00 mastercool hydralic flaring tool? I'm a past ase mechanic and it's the greatest tool. I make brake lines and a few fuel lines for friends (i live in the salt belt), and the tool is a breeze. If you plan on making your own lines of any kind just buy it, you won't regret it. On another prior post you asked about the 2 lines from the tank? Quick connect goes to fuel rail, black plastic ended line is tank vapor line to canister purge solenoid most likely on the forward top location on intake manifold. Good luck, Brian F.
68c10airstream is offline   Reply With Quote
Old 01-26-2014, 10:24 PM   #100
lynnfield
The Waco Kid
lynnfield's Avatar
I have the cover plates done and the engine sitting back in place. I'm not too worried about these, they won't be seen anyway just wanted to cover up the holes in the firewall.
