03-06-2014, 12:40 AM | #76 |
Re: My 4/6" ECE lowering install thread - 72 Shorty
Very good job!
James B. 1967 Chevy Fleetside Shortbed 4X2 (Black & Beautiful) 1971 Chevy Fleetside Shortbed 4X4 (White & Rough) |
03-06-2014, 10:42 AM | #77 |
what a difference a stance will make. lookin good.
03-06-2014, 11:23 AM | #78 |
That makes an awesome truck look more awesome! Nice work!!
03-06-2014, 02:28 PM | #79 |
Easy Does It
Love ECE parts, perfect for these trucks, did this on my 63' and went together sweet, looking Good!! nice truck
03-06-2014, 03:07 PM | #80 |
I love everything about this truck.
08-25-2014, 11:25 AM | #81 |
Now that you've had some time to drive it around, do you plan to add a c-notch? Any bottoming out? Do you still have the factory bump stops in the rear or did you trim/remove them?
Also, have you had any issues with the drop spindles or a-arms rubbing the inside edge of your rims? |
08-25-2014, 12:02 PM | #82 |
I've put some good miles on it since the drop. I don't plan to install a c-notch. I've never heard or felt the rear axle hitting. I did cut 1/2 off the rear bump stops for some additional clearance.
In the front, I have not looked to see if there is any rubbing inside the rim against the spindle or a-arm. There is certainly no noise. The only rubbing that occurs is the tires touch the inner fender over some bumps. I've come to the conclusion that it's because I'm running 275 tires all around. Less wide tires up front would likely resolve this. With the springs and new swaybar, the truck corners much better and flatter. In general, it feels much tighter. |
08-25-2014, 01:05 PM | #83 |
Truck looks GREAT!!!! Perfect Stance...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
08-25-2014, 08:25 PM | #84 |
Truck looks awesome! I've got 2 1/2" ECE spindles and 2" springs for the front of my '69 short step. I'm going to do an axle flip on the leafs in the rear, and would be STOKED if it sits as well as yours. Nice work.
08-25-2014, 10:44 PM | #85 |
Spot on!!!!
'68 SWB Fleetside '98 K1500 Silverado |
01-08-2015, 11:16 AM | #86 |
I am getting ready to do the same install in about a week.
Any pre-advice? Truck looks awesome.
1961 Biscayne http://67-72chevytrucks.com/vboard/s...90#post6978790 SOLD 1971 C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=656258SOLD 1966 Suburban http://67-72chevytrucks.com/vboard/s...85#post7323885 |
01-08-2015, 02:19 PM | #87 |
That's the best kit from ece
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
01-08-2015, 11:32 PM | #88 |
interesting that this thread got reserected today ...because i was talking to a freind TODAY about installing my ECE kit actually i bought a bag set up recently ( from another board member)so in the rear at least I'm gonna use bags instead of the 6 inch drop springs any advice on this would be appreciated. Can someone also tell me do the top ECE shock relocater brackets bolt into the rivet wholes that the originals where in....i should mention i bought my kit from another board member about 2 years ago and have not even opened those boxes to look for directions
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
01-09-2015, 07:19 PM | #89 |
Looks awesome! Would love to make my '68 the same
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
01-09-2015, 07:55 PM | #90 |
It turned out great. What size tires are you running?
01-10-2015, 06:05 PM | #91 | ||
If you get stuck or find the instructions leaving out details, feel free to post here and I'll share my input. Quote:
BFG 275/60/15. I believe the front tires are a bit too wide and rub on the inner fender over some bumps. I'd go a bit more narrow on the fronts next time. |
01-18-2015, 06:35 PM | #92 |
Nice Stance you got there now!
Think I will do the same with my -67! I have drop spindels in the front and some 5" CPP springs in the Rear. No shock relocations! So ECE kit with 2" front springs, 6" rear and all the other stuff will be great for mine truck! Just have to check if that kit is possible to get without drop-spindels! How is the ride now with this kit?
MY -67 Chevrolet C-10, http://67-72chevytrucks.com/vboard/s...d.php?t=622636 Other Cars -69 VW 1600 Variant, 82 VW Polo G40, - 96 Subaru Impreza GT Turbo, -01 BMW 316ti |
01-18-2015, 11:14 PM | #93 |
It's firm. I've used bilstein shocks on sports cars in the past with great results, but I think the shocks with the ECE kit are on the lower end. A higher end set of shocks intended for short shock travel may provide a less firm ride.
02-01-2015, 02:25 PM | #94 |
02-01-2015, 02:30 PM | #95 |
Like bottom pic on my truck. See your thread...
02-01-2015, 02:41 PM | #96 |
67-72 parts collector,…
I think it depends on the amount lowered and if you still have the stock frame stand, lowered ECE style frame stands or no frame stands at all.
I always just look at ride height and see how it would fit the best. I've long forgot which direction the factory installed them. Ha
02-01-2015, 02:50 PM | #97 |
I have found that an air chisel makes short work of those pesky factory rivets.
02-01-2015, 06:03 PM | #98 |
yes yes indeed! its spot on man, now put the tools down and don't touch it again!
"They Don't write songs about Hondas " 1972 C10 "Ole Red--blood, sweet & beers" USMC 1989-1997 1st Anglico |
02-16-2015, 05:19 PM | #99 | |
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
02-16-2015, 06:14 PM | #100 |
The alignment of the panhard bar was easy. I installed it, measured the distance from the rear drum to the fender on each side, it wasn't even so I adjusted the panhard bar via the threads that make up its ends until the rear axle was centered.
For shocks I'm using the ones included in the ECE kit, KYB shocks. They are ok but if they had an upgrade option for the shocks, I'd get them. |
