Old 08-12-2016, 08:29 PM   #76
MMcMasters
MMcMasters's Avatar
Re: Project: Boosted Blucille. '70 C10 SWB PB Fab, LS2 S475
Man that rolling chassis is sexy!
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
Old 08-14-2016, 12:28 PM   #77
shores6
shores6's Avatar
Originally Posted by tommys72 View Post
Good lord!! How'd i miss this build? I'm in now. Great build
Thank ya sir!
Ha it's almost a shame to even put a body on it and cover it. Almost lol
Todd
https://www.instagram.com/shores6/
Project: Boosted Blucille. '70 C10 SWB PB Fab, LS2 S480 - http://67-72chevytrucks.com/vboard/s...d.php?t=700419
shores6 is offline   Reply With Quote
Old 08-14-2016, 01:12 PM   #78
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice build, love the patina!
ChuckDriver is offline   Reply With Quote
Old 08-16-2016, 07:46 PM   #79
shores6
shores6's Avatar
Thank ya sir. The patina was exactly what I was wanting!
Todd
Old 08-16-2016, 08:05 PM   #80
shores6
shores6's Avatar
Alright, back to the bed floor. When it came time to cut the bed floor out for the hinged section, Im not gonna lie I was scared **** less lol But it went according to plan.
For the hinged section, I just built another frame out of 1" square tubing that fit inside the 1.5" tubing. The hinges are around 7" long, 5/8" diameter barrel weld on hinges.
When it came to mounting the hinged section, I got some tabs and welded them to the 1" square tubing and put nut serts in the crossmembers in the bed. The struts were definitely trial and error. I ended up with struts that are almost 21" long extended with 70 lbs of force each. Mounted some trick tabs in a couple different spots until I was happy with where the hatch shut. When the hatch was open, I wanted it to be the same angle as the hood when its open. So I put one of my Porterbuilt hinges together and put an angle finder on it and it was around 45*. Also got some chub tubz from Rob. These things are awesome. I ended up with the CT44s for a 12" wide wheel in case I decide to make a wheel change in the future. The chub tubz are just mounted with 4 bolts in each corner with nutserts in the bed floor.
I looked at about a million latches for this thing. I want something that was going to latch but also be able to be used as a pull. Easy enough, right? Wrong. While finding a latch that meet that criteria is pretty simple, finding one that also met the dimensions I needed was a bit of a chore. The problem was the ribs in the bed floor only being an inch and half wide. Most latch pulls were 2.5" in diameter. Would look a little dumb in my opinion. I ended up with a compression lever latch from southco. While it wasn't my first choice, it was definitely my best choice. Then it was off to get some more powder coat
Todd
Old 08-17-2016, 08:11 AM   #81
mcbassin
Still Learning
mcbassin's Avatar
Excellent work on the bed modification. I like the latch too. Keep up the good work!
mcbassin is offline   Reply With Quote
Old 08-17-2016, 08:15 AM   #82
Bennett68C10
Bennett68C10's Avatar
Awesome job on the bed floor. I'm going to steal some ideas when I get to this point
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 08-17-2016, 08:58 AM   #83
Hart_Rod
Hart_Rod's Avatar
Can't wait to see the bed when you're done, you're killing it!
Hart_Rod is offline   Reply With Quote
Old 08-19-2016, 03:15 PM   #84
shores6
shores6's Avatar
Thanks guys! Steal away. Not gonna lie I've stolen plenty of ideas from some of yall
Todd
Old 08-19-2016, 03:23 PM   #85
shores6
shores6's Avatar
The bed floor is all mocked up and finished for the most part. I struggled with what to do with the underside of the bed floor. I thought if I left it rusty it would look out of place when I had the hatch open. Then I just went with the mentality of old on the outside, new on the inside. Then it came down to painting it or having it bed lined. I ended up having it bed lined for fear of the painting chipping with rocks flying up from underneath. Also had the underside of the chub tubz bed lined.
Todd
Old 08-19-2016, 10:53 PM   #86
ChuckDriver
Nice!
Old 09-01-2016, 07:11 PM   #87
shores6
shores6's Avatar
Alright guys for the first time since I started this build thread, I'm finally on real time with my updates. I've been building this pile since around December of 2014. This is the first truck I've ever built. Why not go all in on the first one lol I've learned a lot from the start to where I am now. A lot of that knowledge come from a ton of reading on this site and watching yall's build threads. So thank yall.
Anyways, back to your regular scheduled program. I got the bed frame back from the powdercoater. Went with the same millennium black as I did with the chassis.
Also got the rear bumper brackets put on. Minor I know but at this point any progress is good progress.
Got a start on the accessory drive as well. While I would love to have a front runner kit, I just cant bring myself to drop $2800 for one. So I went with Dirty Dingo brackets with new accessories. I'm still trying to find an AC bracket thats going to work. That part is a pain in the rear. Wouldn't be that big of a deal but the turbo is in the way of a regular mount and the porterbuilt stuff is in the way of a lower mount. So I might have to get creative with that.
Todd
Old 09-01-2016, 07:22 PM   #88
Hart_Rod
Hart_Rod's Avatar
That's !
Old 09-04-2016, 07:51 PM   #89
shores6
shores6's Avatar
That's !
Thank ya sir! The burb is lookin awesome by the way!
Todd
Old 09-04-2016, 08:00 PM   #90
69restomod
Cool Re: Project: Boosted Blucille. '70 C10 SWB PB Fab, LS2 S475
The bed floor turned out super slick! Love the build 🤘🤘
69restomod is offline   Reply With Quote
Old 09-05-2016, 11:29 PM   #91
shores6
shores6's Avatar
Thanks, man!
Todd
Old 09-06-2016, 08:58 AM   #92
Woodnears
im totally diggin that bed frame ya got going on. Its crazy how similar to mine it is only mine goes full length of the bed. Mine isnt fully built yet. Is yours pretty stable so far.
My Build Thread Here http://67-72chevytrucks.com/vboard/s...d.php?t=457417
Woodnears is offline   Reply With Quote
Old 09-06-2016, 02:41 PM   #93
shores6
shores6's Avatar
Thanks! Yeah so far it's solid as can be. I wanted it to go full length but still wanted to be able to put an ice chest or something else back there when I had the hatch open. I'm pretty happy with how it turned out.
Todd
Old 09-06-2016, 06:05 PM   #94
7wolf
looking good! can't wait to see the engine built up and the cab back on.
7wolf is offline   Reply With Quote
Old 09-06-2016, 07:53 PM   #95
shores6
shores6's Avatar
You and me both! You'll probably hear me all the way from Georgia when I get the cab put back on lol
Todd
Old 09-07-2016, 09:44 AM   #96
Rednwhitec20
Rednwhitec20's Avatar
I love that patina.
1971 C20 Daily, Built 350/700R4
1971 K20 Project, LLY Duramax, 5 speed Allison, and 8 in lift on 37x13.50s
K20 Build
Rednwhitec20 is offline   Reply With Quote
Old 09-07-2016, 10:14 AM   #97
Bennett68C10
Very nice!!!
Keith
66 Suburban
IG: bennett68c10
Old 09-14-2016, 04:43 PM   #98
shores6
shores6's Avatar
Originally Posted by Rednwhitec20 View Post
I love that patina.
Very nice!!!
Thanks, fellas.
Stay tuned.
Todd
Old 09-14-2016, 05:53 PM   #99
gringoloco
A guy with a truck
gringoloco's Avatar
Progress looks killer! Got your PM, sent you a text.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-16-2016, 08:15 AM   #100
Bennett68C10
Thanks, fellas.
Stay tuned.
Couldn't resist huh
Keith
66 Suburban
IG: bennett68c10
