Old 03-24-2016, 05:04 PM   #1051
Donnie Lee
Re: 48 Burb, bagged, 5.3, 20 year wait
Hi AD, I am reading & enjoying your build, got to page 38 post #946 & you show a face shield I haven't seen before. Where can I find this shield and do you remember the model or stock #?
Donnie Lee is offline   Reply With Quote
Old 03-24-2016, 06:44 PM   #1052
Advanced Design
Advanced Design's Avatar
Hi Donnie Lee,
Cool, it is a marathon to make it through this thread. I saw the face shield on another thread and ordered mine from Amazon. Light weight, doesn't fog and comfortable to wear.
Here is a link...Uvex S8510 Bionic Shield, Black Matte Face... Uvex S8510 Bionic Shield, Black Matte Face...
Advanced Design is offline   Reply With Quote
Old 03-24-2016, 08:28 PM   #1053
Donnie Lee
Hey Doug, thanks for the link, I'm placing order tonite. I haven't got all the way thru your build, I'm re-reading a lot as all of this is new to me. I look forward to keeping up as you continue the build. Next month the 2nd Goodguys event takes place in Raleigh, NC at the fairgrounds. I went last year and the Ad's & Burbs. were represented well, probably 30-35 trucks & 10-12 Burbs. Only a couple were local, some from the Charlotte area, most from out of state. That's when my son & I got the bug and he bought the truck in our build thread.
Thanks Again
Donnie
Old 03-25-2016, 06:53 PM   #1054
Advanced Design
Thanks Again
Donnie
Very welcome Donnie. Good luck with your build and have fun. I will be tagging along.
Fuel tank install is done. So I moved up front for a moment to clearance the right frame rail for the Hooker exhaust manifold. I will reinforce the rail with a plate inside once it comes apart again.
Old 03-25-2016, 06:56 PM   #1055
Advanced Design
Can anyone guess what bullet I didn't dodge here? I thought it would be good...and it isn't.
Old 03-25-2016, 08:42 PM   #1056
joedoh
joedoh's Avatar
well do you have it set at dropped height and the axle center at half your wheel diameter? you may not need it to drop all the way and it might clear the driveshaft.
but a simple notch will clear it.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 03-25-2016, 11:03 PM   #1057
Advanced Design
You know, good point Joedoh....the rear is up against the bump stop and it may not drop that low depending on wheels.
Probably will do a notch, and at my fab speed it should only take me a month.
Old 03-25-2016, 11:44 PM   #1058
Possmguts
Possmguts's Avatar
Isnt that what the big hammer is for??
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 03-26-2016, 08:20 AM   #1059
Advanced Design
Yeah, bfh...and sawzall.
There is a build on here somewhere I am following, where he made a nice little hoop or channel in the crossmember for driveshaft clearance. Gotta find that again for inspiration.
Found it, oldnslows awesome build...post 66....http://67-72chevytrucks.com/vboard/s...=437066&page=3
Old 03-26-2016, 09:34 AM   #1060
reaper71
reaper71's Avatar
Had to do the same cut out on the frame for Blake's as well Doug!
A hoop should work just fine...A little cut,grind & weld and good to go!!
Mark...
reaper71 is offline   Reply With Quote
Old 03-26-2016, 09:44 PM   #1061
Iceburgh
Iceburgh's Avatar
I thought the same thing . I had to cut and notch as well, it looks like yours will be lower so cut away
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 03-26-2016, 10:16 PM   #1062
Advanced Design
Hey Mark and Iceburgh, yeah a hoop or reinforced notch will get the clearance needed. Going to wait for the driveshaft to come in first to get a good look at what will work.
Hopefully a notch will work to keep the flat on top since that is where I fabbed the mount for the air valve blocks. And not a big deal if I have to move it.
Been studying on exhaust and exiting through running board is best option I can see. Just not enough room to go up and over the axle. So, I will need to move the battery to open up that space. Didn't think ahead enough on that one...doh!
Old 03-28-2016, 04:33 AM   #1063
lower50's
lower50's's Avatar
A little hump will give you lots of clearance.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 03-28-2016, 09:36 AM   #1064
Advanced Design
Yeah, I too think it will make a lot of difference. Don't want to hoop above too much to stay away from the body. There was enough clearance for the valve block so some hoop above will clear.
Been studying on exhaust. Marc and IIslow went out through the boards so hope to see what they did at exit to not have to reinvent...
Ordered an x pipe and flex joints from Jegs then will figure out the rest.
The adapter / down pipes Hooker has for their LS swap in 73 - 87 C10 might work for this one. Before ordering them I am trying to find out the pipe dimensions for best guess if it will work.
Old 03-28-2016, 09:37 AM   #1065
reaper71
reaper71's Avatar
We've ALL been there Doug I am no different!
It is something we have to deal with in the best way possible, as they say(If it was easy everybody would do it!) good thing is it's metal and it can be cut out,welded and ground down and never know it was changed!
Mark..
Old 03-28-2016, 02:57 PM   #1066
Advanced Design
Mark..
You mean I am not the only one to make mistakes? . Even with it is all good for me...and I can poke fun at myself. Like my first rear floor...ugh..
Love metal, never good with wood.
Old 03-28-2016, 03:02 PM   #1067
Advanced Design
Originally Posted by toddoky View Post
The approximate dimensions measured in reference from the rear-most hole located on the machined outlet surface of the manifolds to the bottom of the outlets of the adapter tubes are as follows;
Driver side- 9.25"
Passenger side- 9.75"
More great customer service from Todd at Holley. He is the development engineer for the Holley LS swap kits and has a thread here on the development of the 73 - 87 C10. He is also posting development updates on LS1Tech.
Thanks again Todd!
Old 03-28-2016, 08:21 PM   #1068
Advanced Design
So I had some good help today. He said "Grandpa, it sure does take a long time to build these projects. I can remember I was pretty little when you started on the 56 Chevy. When will this one be done?"
Old 03-28-2016, 08:24 PM   #1069
Advanced Design
Due to the 4 link bars on the outside I moved the runningboard bracket and mount forward a few inches. Reused this one since I carefully ground out the spot welds.
Old 03-28-2016, 08:27 PM   #1070
Advanced Design
Drilled the holes for the bracket in the new location. Of course the top ones came out onto an edge of the crossmember. So I welded in nuts.
Planned to get both sides done and only finished this one.
Old 03-28-2016, 08:30 PM   #1071
Advanced Design
Instead we had some fun with our Grandsons playing shop badmitten.
Old 03-30-2016, 09:04 PM   #1072
Advanced Design
Some exhaust parts have arrived and the downpipes are on back order.
Relocated the right side rear bracket and simplified installation by drilling the top two holes 3/4 inch lower. Way easier than the left side and don't know why I didn't think before...
Looking for rectangular exhaust tips for exit through the running board and all I am finding are t304 stainless so far. If anyone knows of mild steel or 409 stainless rectangular exhaust tips appreciate a heads up.
Old 03-30-2016, 09:06 PM   #1073
Advanced Design
Stopped by a friends shop to see how he is making out with his 52 Buick.
Old 03-30-2016, 09:19 PM   #1074
Valarius_Starchaser
Valarius_Starchaser's Avatar
Nice work on the other side running board sometimes we need to take a step back to see an easier way
"Orange Crush"
Valarius_Starchaser is offline   Reply With Quote
Old 03-30-2016, 11:29 PM   #1075
lower50's
lower50's's Avatar
Why not use 304? Wow twin turbo!!
1951 MG TD
