Old 05-12-2017, 05:10 PM   #1201
_Ogre
_Ogre's Avatar
Re: My 50 roadster pickup build
wow! had to go back 12 pages to see why you were doing this rebuild.
sucks big time but glad to see it's going back together
don't you hate that green spot putty???
supper fast set no matter how little hardener you apply
shop air compressor timer
Old 05-12-2017, 11:08 PM   #1202
oldman3
oldman3's Avatar
Ogre, appreciate it. Haven't had to much problem with the spot putty, but yes you are correct, it can be hard to get it right...Jim
oldman3 is offline   Reply With Quote
Old 05-13-2017, 03:31 PM   #1203
RockinKees
RockinKees's Avatar
Jim, by no means I would hurry you
Take your time, that's the best thing!
Nice to see you put so much love in truck, with every update it's going to be better and better!!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 05-13-2017, 11:30 PM   #1204
oldman3
oldman3's Avatar
Kees, no problem , I need someone to kick me in the backside , only have a week and a half to get it done...Jim
Old 05-15-2017, 07:13 PM   #1205
oldman3
oldman3's Avatar
Hey everyone, back for a little update. On Saturday, after getting #1 up to TDC, we pulled the old distributor, and installed the new. From the two pics you can see the caps are different. So my current plug wires won't work, with the new, so I will buy new wires.
Old 05-15-2017, 07:24 PM   #1206
oldman3
oldman3's Avatar
Sunday being Mother's day, Mark and I were at the nursing home for awhile.
After I got home I removed the wires from the coil. Also cut the grass (about 4-1/2 acres)
Old 05-15-2017, 07:40 PM   #1207
oldman3
oldman3's Avatar
Todays update: After visiting with wife, I stopped an bought new plug wires. When I got home Mark had removed the old coil and installed the new. Got all wires hooked up to new coil.
Mark ran the new plug wires AND IT NEVER FAILS THE NEW WIRES WERE TO SHORT ON A COUPLE PLUGS, SO HAD TO REMOVE MY WIRE HOLDERS TO MAKE THEM WORK.
Once everything was hooked up, hit the key and it fired right up. I could tell the timing was off, so we hooked up the light and brought it up to 12 deg initial timing, which is what it was before we removed the old distributor. Sounds exactly like it did before the change. Mark did almost all the work today, I just did some small stuff.
Pic 1 New coil in position and all wired up.
Pic 2 New Distributor and plug wires installed.
Pic 3 Old Mallory dist., coil, and resistor ready for swap meet. (Good stuff, just FiTech didn't like the resistor).
Mark and I have a couple things to check and then we will start installing on the sheet metal.
Old 05-16-2017, 12:22 PM   #1208
lower50's
lower50's's Avatar
Nice glad its running good
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 05-16-2017, 01:47 PM   #1209
Indian113
Indian113's Avatar
WOO HOO! won't be long NOW
Indian113 is offline   Reply With Quote
Old 05-16-2017, 08:01 PM   #1210
oldman3
oldman3's Avatar
Thanks lower...Jim
Old 05-16-2017, 08:01 PM   #1211
oldman3
oldman3's Avatar
Thanks Ray, it's getting closer...Jim
Old 05-16-2017, 08:10 PM   #1212
oldman3
oldman3's Avatar
Tuesday's update: Mark and I reinstalled the seat and top.
Then we did a water test on the windshield, last trip in the rain I had a small leak, and thought now was a good time to fix. Found the leak, removed the old rubber from around the windshield, cleaned out the old sealant. Bought new rubber at local windshield place and their sealant. Installed new sealant, installed new rubber and will let it sit till tomorrow, and it should be good to go. Here's a couple pics...Jim
Old 05-16-2017, 08:54 PM   #1213
Advanced Design
Advanced Design's Avatar
FiTech still performing well Jim? Appreciate the example you set for us with your fixes...windshield leak, new seals and sealant....rather than trying to seal it up.
Advanced Design is offline   Reply With Quote
Old 05-16-2017, 11:11 PM   #1214
oldman3
oldman3's Avatar
Hey Doug, Fitech is great, it starts so easy no matter how long you let it sit. Can't wait to get truck back together, so I can take it for a shake down run.
Hope our fix took care of the problem.
How's things going on your end. I know you've had problems with water like us. I stayed nice and dry, but not the city...Jim
Old 05-16-2017, 11:28 PM   #1215
joedoh
joedoh's Avatar
yep, my last one leaked like a sieve right at the center piece of tape in your picture. I ended up putting silcone in between the gasket and the glass AND between the gasket and the steel.
cant wait to see you get on the road again!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 05-17-2017, 08:41 AM   #1216
oldman3
oldman3's Avatar
Thanks joedoh, hope to get some work done today, I'm ready, miss not being able to just jump in and go...Jim
Old 05-17-2017, 12:01 PM   #1217
lower50's
lower50's's Avatar
Mine leaked in the same spot I fixed it the same way but with urethane. Kind of glad to hear it is a common problem.
1951 MG TD
Old 05-17-2017, 11:06 PM   #1218
oldman3
oldman3's Avatar
Lower, mine was also a urethane sealant, I think it was made by Dow. Will get a pic tomorrow.
Old 05-18-2017, 09:28 AM   #1219
reaper71
reaper71's Avatar
Update:
We worked on the truck all day yesterday and were able to get it all assembled.
Here are some shots of it going back together.
reaper71 is offline   Reply With Quote
Old 05-18-2017, 10:06 AM   #1220
lower50's
lower50's's Avatar
Nice!! Are you going to be able to get it painted and back together before your first show?
1951 MG TD
Old 05-18-2017, 07:15 PM   #1221
oldman3
oldman3's Avatar
Hey lower, I will not paint before the nats in Springfield, MO 5/26 thr 5/29. Will wait till later, Mark has to much going on in the shop right now. Beside I will enjoy driving it again for awhile...Jim
Old 05-18-2017, 07:53 PM   #1222
oldman3
oldman3's Avatar
Lower, here's the pic I promised of my sealant I used...Jim
Old 05-18-2017, 08:12 PM   #1223
oldman3
oldman3's Avatar
Ok here's my Thursday update: I took the truck for a shake down run this morning, truck ran great, but my cruise control would not work. During the accident two wires got cut, we put them back together, so this may be the problem. (More on this later). Since I sometime got over the speed limit my gas milage wasn't the best about 15 miles per gallon. (More on this later)
Pic 1 Taken last night before the guys came over.
Pic 2 Taken at gas station, filled up and reset to 0.
Pic 3 Drove to Mt. Grove, MO, about 42 miles up the road.
Pic 4 Back at gas station, filled up. Drove 85.9 miles. Top speed 80. Avg 61 (including city). Drive time 1 hr 23 mins.
Old 05-18-2017, 08:21 PM   #1224
oldman3
oldman3's Avatar
Cruise problem, not sure Mark and I did a diagnostic test and everything works as it should.
Green light when turned on, yellow light when set, red when brake is hit and back to yellow with resume. Yet when going down the road, green light is working, but nothing changes on hitting the buttons. Will have to do more checking.
When I got back from trip I noticed brake pad smell, and dust on the wheel. Turns out I have a caliper not returning all the way. So I'm just going to buy two new calipers and change them out. Maybe this will help my gas milage...Jim
Old 05-18-2017, 09:02 PM   #1225
Indian113
Indian113's Avatar
Oh Boy! good to see that thing moving under it's own power again. I have a feeling your debt to Mark is getting higher. Maybe a Large Steak and a Ice Cold Beer would lower it a little?
