#1201 |
I know the pieces fit
Re: Slosh Tubz new company project "Square Peg" frame laying 1987 GMC Jimmy
Slick, slick slick - even the f'up repairs look good!
#1202 |
67cheby
![]() Join Date: Sep 2008
LOL, thanks man, stinks to have to re-do something like that but oh well It's just metal ! Now to figure out how to drill my hole for the bar and keep it straight through all 4 layers ! anyone have any tips on that ?
#1203 | |
![]() Join Date: Dec 2012
I think I'd employ a laser somehow. Posted via Mobile Device
JK |
#1204 | |
67cheby
#1205 |
Use a magnetic drill press mounted to side of frame. Drill thru two layers on one side. Then make a template or use a laser to mark other side and use drill press again on the other side.
"WIDER IS BETTER" (TRUCKS ONLY) |
#1206 |
think the drill press to keep it straight on through the first holes and use that hole to center the laser (maibe a gunsight calibraion laser ?) and centerpunch it on the laserpoint acros on the other side and use the drillpress again but from the inside out
either that or level the frame and make some sort of guide rail under where you need youre holes thats exactly level and at a 45 degree angle to the frame where you can mount the drill on doing it that way you can drill the holes from all 4 sides but it prolly takes a lot of time to make and set up
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#1207 |
That, or drill the two inner holes, then figure out a way to project a straight line from those two to the inside of the outer wall on one side; then do the same thing on the outer wall on the other side.
No matter how you do it, I'd use a small bit, because in the end, you'll end up reaming it to make all 4 line up! Posted via Mobile Device
JK Last edited by jkeating1; 04-26-2013 at 02:54 PM. |
#1208 |
67cheby
yep, pretty tough to figure out the best route !
#1209 |
Yup, mag-drill and a Hougen rotabroach. I would think that after you got one side done you could run your bar or a pipe through there, get it straight and locate the other hole. Isn't it just a clearance hole or does it support the bar?
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 ![]() |
#1210 |
67cheby
just in time to get the body mocked up , Energy Suspension comes through with some new bushings !
#1211 |
Sweet!
-Rus |
#1212 |
here is an idea that is pretty easy, and ends up looking pretty good as well
![]() here is the other side mounting the skidplate thingy ![]() i did this on my jeep to mount the trans/transfer skid. you make a fishplate with the hole size you need exactly and use a plasma or whole saw to make the holes in the frame close to what you need. then you can adjust the plates in the hole to get everything located exactly where it needs to go. i actually drilled the frame to the exact size for the sleeves but it would have been just as good to oversize the holes in the frame and adjust with the fishplates Ryan |
#1213 |
67cheby
Great idea !
Posted via Mobile Device |
#1214 |
he could do that if he cant alighn the holes , he just needs to drill them out and make fishplates
thought of a cheaper idea to the laserpointer : drill the first side put a verry good fitting 4 foot long pipe trough it to the other side sit the frame up side ways and drop a piece of heavy and good fitting roundbar with a point machined on it down the pipe , it should leave a pretty exact crater/divet for the other side to center the drill on
#1215 |
Coming along sweet. Congrats on the parts haul.
LIFTED OR LOW THE ONLY WAY TO GO!!!! Check out my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=517346 Projects 56 Chevy pickup Porterbuilt FR/RR dropmembers |
#1216 |
chevy only
![]() Join Date: Sep 2006
cool stuff!
CHEVY ONLY... Nothin Else ! |
#1217 |
67cheby
thanks guys ! OK finally back on track , fixed my screw up , frame is on the ground ! Motor going in tonight ! What redneck doesn't do mockup with Studded snow tires ????? LOL, that's just how we roll !
#1218 |
Very nice sir!
-Rus |
#1219 |
It's beautiful!!! The craftsmanship on "Sqaure Peg" is just mouth dropping!
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
#1220 |
67cheby
thanks guys, I appreciate that !
#1221 |
/bows to the master. All Hail the Man (with his snow shoe mock up....) lol
Looking great bud! Cant wait to see the Square rollin.
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase 1955 Chevy Stepside "Dudley" My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288 1972 Chevy C10, Project "Chevro~Layed out" Nether Storm Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523 |
#1222 |
![]() Join Date: Mar 2011
Looks sweeeet...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#1223 | |
67cheby
thanks Jim |
#1224 |
Snow tires. Awesome. Looks terrific! Off to Oklahoma?
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#1225 |
Your comment about using studded tires for mock-up reminded me of this article about building your own ice racing tires...
http://www.jpmagazine.com/featuredve.../photo_02.html Maybe the next build? ![]() |
