02-16-2011, 01:33 PM | #101 |
Truck and auto performance nut
Re: LS engine swap info
if thats what you want........ why pay when you can gut them?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
02-16-2011, 01:42 PM | #102 |
LSX addict
because LS cats are worth nearly double what them cost.
-1982 C10 SWB GMC Sierra [undergoing 6.0/4L80E swap with mild restoration] |
02-16-2011, 01:44 PM | #103 |
is that for visual inspection!?!? why would these old trucks go thru a visual inpsection? sorry, in SC we do not have inspections right now...
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
02-16-2011, 01:48 PM | #104 |
LSX addict
yes, its hit and miss around here (ETX), some places dont, some do depending on where you go but it is getting worse and worse. 24+ year old vehicles do not have to undergo the sniffer, but a "visual exhaust/emission equipment" inspection for anything newer than 1968.
02-16-2011, 01:49 PM | #105 | |
02-16-2011, 01:56 PM | #106 |
LSX addict
actually maybe it was 1975. somewhere in that time frame, i dont know when they started installing them.
02-16-2011, 02:57 PM | #107 |
I've got a set of LS Cats if someone is interested.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-16-2011, 08:53 PM | #108 |
Turning Wrenches Daily
1973-1974 was when they started installing cats on vehicles right during the gas crunch era. In texas and I got this from the DMV if it was not installed as a factory item it does not need to be present on the vehicle at the time of inspection. So if it is 78 for sure or newer at least one set of cats has to be in place on the vehicle. Went through this with the inspections station on my pontiac firebird. They did check to make sure that all required vacum lines were in place on the engine. What few there were lol. Working on getting that car back through inspection for the year having some brake issues that are holding me back atm. Sean
Work! Play! Work work work! Money to play with. 64 GMC, 66 burb 4x4, and now 64 1ton money pits......ahhh life is good. Upcoming move back to Texas Dallas bound we are this september!!! 1964 GMC I1500 2wd (my baby) 8.1 allison 6 spd conversion Aka Smurf http://67-72chevytrucks.com/vboard/s...d.php?t=438342 2016 Ram Big Horn 4WD parts hauler 2010 Chevy HHR wife new car after the circled problem blew up!!! 1981 Ram D150 /6 auto Wife's sunday driver Living outside Gladewater Texas now working in Longview at the hospital there future project toys: 1966 Chevy K14 carryall aka Smurfette future project 283/auto overdrive http://67-72chevytrucks.com/vboard/s...d.php?t=551867 |
02-17-2011, 10:17 AM | #109 |
wasn't it the 1975 models? At least for GM?
02-17-2011, 12:02 PM | #110 |
what about throttle cable setups.....1999 5.3 in 84 shorty??
my build http://67-72chevytrucks.com/vboard/s...d.php?t=367330 84 short-wide 2wd. 99 5.3 vortec, built 4l60E, schoenfelds, bubb tune, cyber grey metallic 10 camaro ss/rs, 6spd manual, leather, loaded, cyber grey metallic |
02-17-2011, 12:14 PM | #111 |
68 custom,
You might be right IO know it was within that times range. Cable setups for a 5.3 you will probably need an 04 or earlier engine unless you want to piece it together I know lokar and a couple of other companies make cable setups for that and ls series engines. I have one for an unused tpi conversion atm. Let me look around I might have the ls lokar setup laying around somewhere. Sean
02-17-2011, 12:38 PM | #112 |
yeah my motor is a 99
02-17-2011, 01:40 PM | #113 |
After checking out the above mentioned straight pipe that looks like a catalytic converter, I read the disclaimer at the bottom. Hilarious!
"The product description above is for entertainment purposes only. This product does not perform the exhaust cleansing function of a catalytic converter in any way. Use of this product on or off the road violates countless laws and may prevent your car from passing emissions. It is unlawful to install this product in any vehicle in the United States, ever. If you wish to return this product at any time in the future, a full refund will be issued. This product should only be purchased by lawyers with pre-1975 vehicles or purpose built off-road vehicles that did not come with catalytic converters from the factory who know for a fact that it is legal to use in their vehicle in their jurisdiction for aesthetic reasons only. If you are not one of those lawyers, this product should only be hung on your wall to express your rebellious nature, never installed in a vehicle. This product may cause cancer." |
02-17-2011, 06:47 PM | #114 |
dave
Hey thealien, thanks for helping out here....i'm havin a problem with my lq4 motor it has the single fuel rail system u speak of (2005) from a gmc savannah went to napa, thought the oem fuel filter would have a return, but it's just 1 in 1out so now i'm so confused...it wont start unless you are spraying starter fluid in the intake -----& i dont have the mass air hooked up any help would be very appreciated thx dave
=Thealien;3686299]Fuel system (any chance a mod can move this post up?) The LS engines require 58-60 pounds pressure at the fuel rails. Older fuel rails had a regulator on the rails and there is a feed and return on these engines. On the later fuel rails there is only the feed on the rail. You need to have something like the filter regulator shown below to return the excess fuel to the tank. Some of the tanks these engines came with did this internally in the tank. Corvette filter/regulator I don't know how long this will last but a decent deal on the regulator/filter and he will take offers for less I am told GF822 Lots of people use Walbro external pumps Walbro external pumps and fittings Dorman quick disconnects for GM fuel line Dorman 5/16ths Dorman 3/8ths Russel AN quick disconnects Russel 3/8ths Russel 5/16ths Don't have a way to make the GM quick disconnect? Try one of these Dorman flare to quick disconnect Fuel pump tank adapter F-body LS1 fuel pump adapter kit here is an installation tutorial of the adapter kit Tutorial of adapter kit Another gas tank modification EFI pump tank mod Dual tank info Compliments of Glock35ipsc[/QUOTE]
check out my build "DIRTY BURB" |
02-17-2011, 06:55 PM | #115 |
dave
yes yes i can use your help big time i'm reachin out to anybody i'm puttin n a 6.0 2005 lq4 in my 72 burb has the single in fuel rail no return i'm told on here somewhere i need a fuel filter with a return built in so hit napa and the oem is only 1 in 1 out,,,? it won't start unless sprayin starter fluid in the intake i dint have the throttle canle of mass air flow hooked up yet either...just tryin to start it first....do i need the others first??? the smell of gas in my garage is soooo overpowering like its tryin to run on only gas....Please help thX Dave
02-17-2011, 08:33 PM | #116 | |
LSX addict
02-17-2011, 09:26 PM | #117 |
dave
still confused! what part number is this for? fuel filter? & y is the stock filter only no return, and 1 more do i need return....im not really an engine guy so help explain please something doesnt make sense in my pee brain
02-17-2011, 10:20 PM | #118 |
That part number I am guessing is the filter with return line attachment to work with your engine. The return line routes fuel back to the gas tank when the fuel injection rails have reached full pressure. Helps to save the fuel pump from too high of pressures. And other things as well. Not a boned up on these items yet working on it quickly tho since I will be buying my new gas tank this fall and installing it after the bed is completely repainted with new oak wood. late 2004 and early 2005 they simplfied the fuel rails due one part problems with the regulators plus high pressure requirements. So what you probably grabbed a hold of was one of the early 2004 models that still had the rail regulator in place rather than the newer filter regulator assembly.
Sean
Work! Play! Work work work! Money to play with. 64 GMC, 66 burb 4x4, and now 64 1ton money pits......ahhh life is good. Upcoming move back to Texas Dallas bound we are this september!!! 1964 GMC I1500 2wd (my baby) 8.1 allison 6 spd conversion Aka Smurf http://67-72chevytrucks.com/vboard/s...d.php?t=438342 2016 Ram Big Horn 4WD parts hauler 2010 Chevy HHR wife new car after the circled problem blew up!!! 1981 Ram D150 /6 auto Wife's sunday driver Living outside Gladewater Texas now working in Longview at the hospital there future project toys: 1966 Chevy K14 carryall aka Smurfette future project 283/auto overdrive http://67-72chevytrucks.com/vboard/s...d.php?t=551867 Last edited by sdwolff98; 02-17-2011 at 10:22 PM. |
02-17-2011, 11:36 PM | #119 |
dave
sdwolff98 so to clarify...i need that filter with the in/out and return to the gas tank?? if so, then ok but i dont understand why my set up is just like the van it came out of single line fuel rail(inlet) single in and out filter no return
02-17-2011, 11:45 PM | #120 | |
LSX addict
but yes you need that.
-1982 C10 SWB GMC Sierra [undergoing 6.0/4L80E swap with mild restoration] Last edited by kSStamp0182; 02-17-2011 at 11:46 PM. |
02-18-2011, 12:48 AM | #121 |
Yeah you need the filter with the return line like i said it was early or mid 2004 they changed the filters to the new ones. So yes definitely need it. It is one of the parts I am working on getting later this year when my fuell system goes in and online in my truck
Ksstamp is doubtlessly right in it being the wrong part they gave you. I have had that happen more than once at oreilly's myself on something I am working on. Let me see ifn I can find the link to the part you need so you can show them a picture of what you need should fix the problem. here is the link this one has been modified but it is identical to what you jneed they just fancied this one up with an fittings. http://www.speedinc.com/cont.cfm?cid=C0000896 take that to your parts house and they should be able to find the right one for you. Sean
Work! Play! Work work work! Money to play with. 64 GMC, 66 burb 4x4, and now 64 1ton money pits......ahhh life is good. Upcoming move back to Texas Dallas bound we are this september!!! 1964 GMC I1500 2wd (my baby) 8.1 allison 6 spd conversion Aka Smurf http://67-72chevytrucks.com/vboard/s...d.php?t=438342 2016 Ram Big Horn 4WD parts hauler 2010 Chevy HHR wife new car after the circled problem blew up!!! 1981 Ram D150 /6 auto Wife's sunday driver Living outside Gladewater Texas now working in Longview at the hospital there future project toys: 1966 Chevy K14 carryall aka Smurfette future project 283/auto overdrive http://67-72chevytrucks.com/vboard/s...d.php?t=551867 Last edited by sdwolff98; 02-18-2011 at 12:52 AM. |
02-18-2011, 01:12 AM | #122 |
dave
thanks for all the help boys....once i saw a picture of the filter, i remembered that i had something simular in a box somewhere (a member on this site that WAS helping me and disappeared,told me to get it) i found it,installed it,waaaaa llaaaaaa still no go...got pressure at the fuel rails but it just turns over, even the mass air is hooked up NOW WHAT?????
02-18-2011, 07:13 AM | #123 |
ok here is where to start have you checked to make sure your fuel injectors are getting power? if they are y our next step would be to make sure the computer is working properly in driving the injectors next. Easiest power check on injectors is use a volt meter and see if there is any ppower at each injector unit. What kind of wiring harness are you using? Also are all of your sensorsd hooked up on this engine?
Sean
Work! Play! Work work work! Money to play with. 64 GMC, 66 burb 4x4, and now 64 1ton money pits......ahhh life is good. Upcoming move back to Texas Dallas bound we are this september!!! 1964 GMC I1500 2wd (my baby) 8.1 allison 6 spd conversion Aka Smurf http://67-72chevytrucks.com/vboard/s...d.php?t=438342 2016 Ram Big Horn 4WD parts hauler 2010 Chevy HHR wife new car after the circled problem blew up!!! 1981 Ram D150 /6 auto Wife's sunday driver Living outside Gladewater Texas now working in Longview at the hospital there future project toys: 1966 Chevy K14 carryall aka Smurfette future project 283/auto overdrive http://67-72chevytrucks.com/vboard/s...d.php?t=551867 Last edited by sdwolff98; 02-18-2011 at 07:14 AM. |
02-18-2011, 09:46 AM | #124 |
I was reading your other posts on the engine. you say you smell strong odors of fuel? is that when you are trying to start the engine? if so have you tried to find out where it is coming from at all? if it is leaking from the rail or injectors might also explain the no start issue as well.
sean Posted via Mobile Device
02-18-2011, 10:08 AM | #125 |
dave
Wolff, not leaking fuel anywhere checked everywhere, nothing the smell is mostly after i've tryed to start it....i checked my oil, doesnt seem like gas but i have extra oil now....so i think gas is just passing by the injectors gonna drain oil, put in new...my friend has the "noids" to check the injecters, try that tonight and oil pressure is still a big question mark....at the sharder valve, it seems pretty good visually...& the wire harness is the stock on outta the van, with improvements thx in advance
