Old 06-22-2012, 05:27 PM   #101
Dinos63
chevy only
Dinos63's Avatar
Re: Another Dropmember version???? :)
very nice, makes me want to build one with this set up
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 06-26-2012, 11:46 PM   #102
gringoloco
A guy with a truck
gringoloco's Avatar
I thought I had seen you mention it somewhere before, but never anything come of it: any chance of you guys using a coil spring like pictured below? (that's a TCI setup for reference)
Basically, instead of coilovers, an option to run factory style coil springs with the mild version Dropmember. It could use the 'bag style shock mounting bracketry for design simplicity, instead of the through-the-coil setup like the TCI pictured. Your lower control arms (as well as CPP and others) are already coil-capable, so it would just require building a new upper 'coil hat' mount, like the pic (*I think*).
Sure, you lose the ride height adjust-ability, but that's only a half inch or so while remaining 'in the sweet spot' of the suspension's intended geometry. Conversely, this could save customers hundreds in coilover costs and may have a certain appeal to those that don't want to stray TOO far from factory components/layout, but upgrade to R&P, with better geometry and ground clearance, under the stock inner fenders, all while using C10 truck parts.
Is this a crazy idea? Seems too simple to me...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-27-2012, 09:07 AM   #103
Wasted Income
Boosted Member
Wasted Income's Avatar
I like it, GringoLoco.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 06-27-2012, 11:41 AM   #104
PBFAB.COM
PBFAB.COM's Avatar
It's definitely doable.... hasn't been much interest in it though. A better option in my opinion is to run an air bag with a schrader valve. You can run it static (set height without the expense of an air management system) and still have the ability to adjust or fine tune. Not to mention the ride quality.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 06-27-2012, 01:58 PM   #105
gringoloco
A guy with a truck
gringoloco's Avatar
Agreed on the benefits of 'bags, as I run a schrader setup on the rear of my truck. The problems with it, in my experience, are the inherent fluctuations in pressure, and therefore height, due to temperature, leaks, etc.
While this is acceptable to some degree on the rear, these changes in the front suspension will lead to alignment, handling, and tire wear issues. Without some way to positively gauge your set ride height, such as a pressure or height sensor, there's no way of knowing. I envision breaking out the tape measure or yard stick at every stop to ensure your truck is still aligned, or worse yet, driving down the highway slowly leaking air and ruining an expensive 20" tire before you realize your 'bags are leaking...
Coil springs are simple, cheap, reliable and capable. For these reasons, I still run factory coils up front-- guess I just wanna have my cake (improved geometry and ground clearance) and eat it too (affordably and reliably).
-Chris
Old 06-27-2012, 02:25 PM   #106
PBFAB.COM
PBFAB.COM's Avatar
Definietley good points to consider, and we can always find pros and cons to every set-up. Just have to weigh all the options and make the decision that's best for you.
I would raise the eyebrow a little to the pressure change argument due to temperature and barometric pressure. It is fact that the pressure will change due to this outside influences.... but I would make the argument that the changes would be negligeable at best.
The pressure changes in reference to a leak is much more practical, and a simple set of gauges would keep those of us suffering from ADD and OCD from breaking out the yardstick at every intersection.
We have made several "custom" or modified Dropmembers over the years, and are always open to discussing possibilities.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 06-27-2012, 04:45 PM   #107
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by porterbuilt View Post
...We have made several "custom" or modified Dropmembers over the years, and are always open to discussing possibilities. ...
W3rd. I'll be in contact
-Chris
Old 07-04-2012, 12:32 PM   #108
PBFAB.COM
PBFAB.COM's Avatar
Few more pics of the four-link.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 07-04-2012, 04:32 PM   #109
Hart_Rod
Hart_Rod's Avatar
Whats the widest tire that will be able to be run with that setup?
Hart_Rod is offline   Reply With Quote
Old 07-04-2012, 05:20 PM   #110
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by Nate Porter on porterbuiltstreetrods.com
12" wide wheel will fit with sufficient clearance.
http://www.porterbuiltfabrication.co...ull=1#post3832
For the green '68, or the gold '68? Loving this setup- hope to get mine soon-ish...
-Chris
Old 07-04-2012, 05:25 PM   #111
SCOTI
SCOTI's Avatar
Previous versions allowed a 10" wide wheel because of the bag mounting location. This looks like it places the 4-bars in approx the same location. The difference would be the location of the CO's vs bags so a 12" wheel might fit. Curious as well....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-04-2012, 08:50 PM   #112
duallyjams
duallyjams's Avatar
What size rim do you need to run for the srcub line on the rear.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 07-09-2012, 08:31 PM   #113
PBFAB.COM
PBFAB.COM's Avatar
Measurements confirm 12" wide wheel is the max you can run with the four-link and coil-overs outboard. 10" wide wheel will fit with plenty of room.
On this set-up, the lowest point of the coil-over bracket hangs down 9" below the center of the axle tube. That would equate to an 18" wide wheel.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 07-09-2012, 08:33 PM   #114
PBFAB.COM
PBFAB.COM's Avatar
Some more pics:
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 07-09-2012, 08:34 PM   #115
PBFAB.COM
PBFAB.COM's Avatar
More:
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 07-09-2012, 10:40 PM   #116
Wasted Income
Boosted Member
How long until that center x-brace is available?
Turbo diesel
Old 07-09-2012, 10:48 PM   #117
67cheby
67cheby
67cheby's Avatar
That is beautiful !
67cheby is offline   Reply With Quote
Old 07-09-2012, 10:55 PM   #118
N2TRUX
Happy to be here
N2TRUX's Avatar
Very pretty!
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-09-2012, 11:12 PM   #119
PBFAB.COM
PBFAB.COM's Avatar
Probably gonna be a few months until it would be a production piece. We can always sell the pre-bent tubing and the plates for those who are ambitious.
Originally Posted by 67cheby View Post
That is beautiful !
Thanks Mike!
Originally Posted by N2TRUX View Post
Very pretty!
Thanks Ken! I think it came out alright.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 07-11-2012, 01:21 PM   #120
Dinos63
chevy only
Dinos63's Avatar
sweet!!
Old 07-11-2012, 02:36 PM   #121
texastrendz
10...10....10....10 muthafin 10...10....10
texastrendz is offline   Reply With Quote
Old 07-11-2012, 05:22 PM   #122
kvn1011
Kvn1011
kvn1011's Avatar
That looks awesome nate!!
kvn1011 is offline   Reply With Quote
Old 07-23-2012, 01:20 AM   #123
65Pickup
65Pickup's Avatar
Anybody got pics of completed trucks??
65Pickup is offline   Reply With Quote
Old 07-23-2012, 09:30 AM   #124
gringoloco
A guy with a truck
gringoloco's Avatar
Only one I've seen is the Hills Blazer
-Chris
Old 07-23-2012, 01:31 PM   #125
65Pickup
65Pickup's Avatar
Is that the AutoCross Tahoe, or Jason Hill Blazer?? Any build threads? Thanks
