#101 | |
![]() Join Date: Mar 2011
Re: My 4/6" ECE lowering install thread - 72 Shorty
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#102 | |
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#103 |
laying low
![]() Join Date: Mar 2001
You can use a comealong or ratchet strap to move it over.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#104 |
RAT1968 '68 Cab/'71 Parts
Call Stan at ECE. He has a "no tool" method I used to center everything.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#105 | |
Moderator
![]() Join Date: May 2007
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#106 |
I just unbolted one end (the lower end) turned it a couple threads, tapped the rear axel over slightly to line up with the panhard bar bolt hole and rebolted it on, then remeasured for center. For anyone who says they can adjust the panhard bar without removing it from the lower bolt mount, I don't know how this is possible, but it only took a few tries using the description above.
#107 | |
#108 |
Ekliptix. ...did you end up installing the 1/2 blocks on rear?
Stance looks great....hoping to do my son's truck next weekend.... |
#109 |
I did not until I measured the right side and it was slightly higher then the left side, so I installed a 1/2" block on the right to even it out, courtesy of member original-71.
#110 |
Can anyone tell me what size the nuts on the u bolts are. I tried a 1" and a 1 1/8 " wrench and neither fit so I need to Go shopping for the right size tomorrow
#111 |
Just take the nut with you.
1970 SWB Build |
#112 |
I need a wrench/impact socket to get it off the truck.
#113 |
I think jmking9 meant to just take the *back* part of the truck shopping with you.
#114 |
Ekliptix, nice looking Jeep. Can you tell me about the lift and tire size, thanks. Lee.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#115 | |
![]() It's probably a 1 1/16"
1970 SWB Build |
#116 | |
One of the best trucks.... and best build threads on the Forum. And, all owner built. ![]()
#117 | ||
#118 |
Loved my Jeep, too. Put a ton of money in her *after* this pic.
Then sold at a substantial loss. ![]() Typical of me.
#119 |
The 70 is out back and I'm crawlin under tonight, but the 63 has 1 1/16 socket nuts. probably the same.
#120 |
Thanks, killer stance. I'm going for a 2 door Rubicon this summer. I've done a lot of research on lifts and tire size. Looks like I'm leaning toward 2 1/2 metal cloak or teraflex with 33 inch tires. Will also more than likely go for the life time warranty.
#121 |
I believe it was 1 1/16"
1961 Biscayne http://67-72chevytrucks.com/vboard/s...90#post6978790 SOLD 1971 C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=656258SOLD 1966 Suburban http://67-72chevytrucks.com/vboard/s...85#post7323885 |
#122 | |
Junior Member
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Gold White Fleetsides/Saddle |
#123 | |
#124 | |
#125 |
all the way down on bump stops
