Old 01-27-2015, 04:24 PM   #101
Kim57
Kim57's Avatar
Re: Dunce's 59 Fleetside build
Repairs are looking good.
Tire looks good to me.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 01-27-2015, 07:24 PM   #102
RockinKees
RockinKees's Avatar
Wheel is perfectly centered for me!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 01-27-2015, 08:13 PM   #103
oldman3
oldman3's Avatar
Counting you that's four for four on tire centered...Jim
oldman3 is offline   Reply With Quote
Old 02-02-2015, 12:13 PM   #104
dunce79
While my rear end and front sub are out getting worked on decided to work on the rest of the to-do list.
- removed all the crap from the dash and firewall. Huge ass rats nest up on top of the glove box. very nasty
-added 1/8 steel rod to the bottom section of both doors to even out the gaps. something slightly incorrect with the new rear panel caused this I think. I could get the doors to lined up everywhere else. So at one point I decided I'd just add to the doors if I had to. Hard to tell in the before pic but I had 3/16 gap or slightly less on the top half and 1/4 or slightly more on the bottom half. Welded the rod on both the front and back sides and then grind everything smooth. Shave off some the rod where needed. Virtually undetectable.
dunce79 is offline   Reply With Quote
Old 02-02-2015, 01:10 PM   #105
oldman3
oldman3's Avatar
Nice job on the door gap, and alignment of the panels...Jim
Old 02-02-2015, 03:42 PM   #106
Advanced Design
Advanced Design's Avatar
I agree with Jim! Well done on the gaps!
Advanced Design is offline   Reply With Quote
Old 02-17-2015, 01:16 PM   #107
dunce79
Making a little progress...
-got my gas tank mocked up. Used one from Tanks and relocated a couple frame rails to frame it in. Added plates on top and used straps connected to the cross members to hold it in place. Plan to have the filler right it in the bed floor.
-Did some work on the wheel tubs. Out of 4 I had one decent one and 1 that was a candidate for repair. Blasted, tried to knock out the bigger dents, fixed some holes and replaced the flange one of them.
-Decided to go with a roll pan on the rear instead of bumper. My plan is to route the exhaust out the back through the pan on the bottom. The roll pan needs something else.. pretty bland but beats the ugly ass bumper as far as I'm concerned.
-Started mocking up my camaro clip. I'm close now.. few more tweaks and I'll tack it in.
Old 02-17-2015, 04:55 PM   #108
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice work!
Here's an idea for you, don't know any details on it, but it looks nice!
ChuckDriver is offline   Reply With Quote
Old 02-17-2015, 05:01 PM   #109
Kim57
Kim57's Avatar
Looking real nice.
Kim
My build thread
Old 02-17-2015, 06:25 PM   #110
OneOffStroker
Originally Posted by ChuckDriver View Post
Nice work!
Look like a '67 Camaro rear bumper. Those look pretty nice on fleetsides.
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292
1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987
Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker
OneOffStroker is offline   Reply With Quote
Old 02-17-2015, 06:35 PM   #111
dunce79
Yeah, thats interesting. I don't know if I'd wrap it around but def an idea worth playing with.
Old 02-17-2015, 07:07 PM   #112
RockinKees
RockinKees's Avatar
Nice repairs on the tubs!
And I do like the bumpers too, great idea, I keep that in mind
Cheers!! Kees.
Kool Guyz CC
Old 02-23-2015, 03:47 PM   #113
dunce79
Did a little presto change-o on the dash. Decided to go with an original style radio with the ipod hookup ect so I bought the repair panel. I never liked all the freakin knobs on this dash so removed the vent controls and wiper control holes. Deleted the heater control and ashtry. I originally planned on removing the far left hole which is headlights and just keeping the two next to the gauge cluster but It looks kind of balanced as is. I'll put the vintage air controls above the radio I think. My get a column with wiper controls built in.. not sure yet though.
Started filling in the cowl vents..
Had someone with a lot more experience than I check to make sure my subframe was square. I nailed it so will be burning it in this week.
Old 02-23-2015, 04:12 PM   #114
octanejunkie
octanejunkie's Avatar
Looks awesome!
Yes the dash does look more balanced with the two holes left of the cluster.
I was toying with the idea of converting the cowl into a vent to blast cool/road air into the engine compartment... wonder if anyone ever attempted that. There should be great downforce at the cowl.
Déjà vu. It's that feeling you get when you hit your thumb with the hammer a second time
'59 Chevy 3100 Stepside
octanejunkie is offline   Reply With Quote
Old 02-23-2015, 04:13 PM   #115
octanejunkie
Oops. Double post!
Old 02-23-2015, 05:38 PM   #116
Kim57
Kim57's Avatar
Looks real good.
Kim
My build thread
Old 02-23-2015, 05:48 PM   #117
Advanced Design
Really nice work on the dash and cowl!
Old 02-23-2015, 05:54 PM   #118
ChuckDriver
Nice job!
Old 03-18-2015, 05:46 PM   #119
dunce79
Been awhile since the last update. Still plugging away though.
-filled a billion firewall holes
-fitting the engine, making mounts, notching frame
-posi and brake put in the rearend
-trans cross member created
-modify doors for one piece glass
-subframe partially welded in
-fit all front sheet metal
-removed front suspension and blasted a arms, spindles ect.
up next is boxing the frame and blasting it, then getting the front suspension back together.
Old 03-18-2015, 06:22 PM   #120
RockinKees
RockinKees's Avatar
Looking great, as always!!
Cheers!! Kees.
Kool Guyz CC
Old 03-18-2015, 11:01 PM   #121
oldman3
oldman3's Avatar
Nice job...Jim
Old 03-19-2015, 08:37 AM   #122
Kim57
Kim57's Avatar
Nice progress. Looking real good.
Kim
My build thread
Old 04-07-2015, 12:09 PM   #123
dunce79
-narrowed a 70s chevy seat by 3 inches to fit the cab
-shifter, throttle pedal mocked up
-firewall mounted brake booster mocked up
-started modifying trans tunnel
-steering column and shaft mocked up
-steering wheel selected, like the classic look
-got my wheels, had to put longer studs on the back to use 3/4 spacers and get the wheels outboard a bit. gunna have to widen the wheel tubs by about 2.5 inches
-almost done boxing the frame, por15 on it, bottom of cab cleaned up and painted
-small repair on both inner front fenders
-blasted the entire frame (thats the wife blasting an inner fender)
Old 04-07-2015, 12:59 PM   #124
Advanced Design
Wow, great progress! Looking really good.
Old 04-07-2015, 02:37 PM   #125
RockinKees
RockinKees's Avatar
Frame is looking real good!!
You're going pretty fast!
Cheers!! Kees.
Kool Guyz CC
