Old 12-25-2015, 04:37 PM   #151
RRR18
RRR18's Avatar
Re: Blood Sweat and Tears.. 67 Build Thread
That just flat out sucks.
When I read it I was exactly like this
That's what they make beer for
I hope it get better before it gets any worse.
Merry Christmas to you and your family.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 12-25-2015, 04:41 PM   #152
Possmguts
Possmguts's Avatar
Rum and Coke... Beer is not gonna work right now...
It ran so good too. I have no idea how the heads didnt just fall off... I dont understand how they felt so tight when I took them out.
Oh well... looks like that 383 stroker is coming sooner than planed and the truck will be a bit longer sitting in the garage...
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 01-01-2016, 01:18 PM   #153
Possmguts
Possmguts's Avatar
Ok we got the head bolts deal squared away and shes all together. Just need to get some pulleys and headers..
Old 01-01-2016, 01:22 PM   #154
Possmguts
Possmguts's Avatar
Trying to get this big sway bar fitted and ran into a little road block.. clearance between the cradle cross member and the bushing mounts only give me like 2 inches, and there is still no weight from motor and trans on it so thats going to get tighter.... Not sure what to do here. Any ideas?
Old 01-01-2016, 10:27 PM   #155
Possmguts
Possmguts's Avatar
Hope there is enough clearance once all the weight is on it, because its in there now...
Old 01-02-2016, 10:53 AM   #156
Possmguts
Possmguts's Avatar
I had Chad go ahead and do some renderings for me. I really do think Im going to see what I can do to build this C/28 he dreamed up... But as far as color and the Yenko style stripe goes, I think he nailed it... Not sure on wheels yet. These ones do look really cool...
Old 01-02-2016, 01:16 PM   #157
sduckworth13
sduckworth13's Avatar
Nice work on the truck. I like the rendering too.
Scott
sduckworth13 is offline   Reply With Quote
Old 01-03-2016, 11:11 AM   #158
jlsanborn
jlsanborn's Avatar
Cool!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 01-05-2016, 12:47 AM   #159
lower50's
lower50's's Avatar
Good to hear you got the motor figured out. So if the sway bar hits would it act like a bump stop?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 01-05-2016, 09:51 AM   #160
Possmguts
Possmguts's Avatar
If it hits its most likely to smash the brackets...
Old 01-10-2016, 10:23 AM   #161
Possmguts
Possmguts's Avatar
Column is done, it was in real rough shape as far as paint goes. Pulled it all apart, cleaned it all up, and repainted. It was also a column shift automatic column. I got rid of the holes for the shifter and the gear selector thing...
Old 01-10-2016, 11:35 AM   #162
Advanced Design
Advanced Design's Avatar
Nice work on the steering column. Looks good!
Advanced Design is offline   Reply With Quote
Old 01-15-2016, 06:44 PM   #163
Possmguts
Possmguts's Avatar
anybody know if this is upside down or correct? The instructions dont show a pic.. I googled it and have seen pics of it mounted with the arch up and also with it down..
Old 01-15-2016, 08:09 PM   #164
RRR18
RRR18's Avatar
I would guess that whatever makes the sway bar link the straightest up at ride height is the best way.
'67 BAD IDEA
Ryan
Old 01-15-2016, 08:45 PM   #165
Possmguts
Possmguts's Avatar
It doesnt look like it will hit the bed cross-member being this way, so I guess Ill go ahead and mount it like this and find out later how it works out.
Old 01-16-2016, 11:13 AM   #166
Possmguts
Possmguts's Avatar
Thought about it and went this way instead...
Old 01-16-2016, 12:12 PM   #167
jlsanborn
jlsanborn's Avatar
I did the same thing, looked goofy and I flipped it. I think on one of Rob's threads there's a pic. I had to trim one of the brackets on the frame to get it in the right spot. Not much room under the bed floor.
Old 01-16-2016, 12:17 PM   #168
jlsanborn
jlsanborn's Avatar
Here's what I had to do...
Old 01-16-2016, 01:53 PM   #169
Possmguts
Possmguts's Avatar
Mine are right against the bed mounts but I didn't have to cut them.. how long ago was it that you did yours? I wonder if they made changes to the bar? I just hope the bed clears this thing... or is that why you have yours farther forward?
Old 01-16-2016, 07:46 PM   #170
Possmguts
Possmguts's Avatar
Drivers side door upper hinge area patch repair...
Old 01-17-2016, 01:07 PM   #171
Possmguts
Possmguts's Avatar
Well I'll be damned... it actually works... New metal around top hinge area. New top hinge and new pin and bushings in bottom hinge...
Old 01-17-2016, 08:58 PM   #172
RRR18
RRR18's Avatar
Awesome man. Wish I had the patience for that ****. If I screw something up I'm real quick to throw it across the street. Neighbors know what I'm talkin about.
'67 BAD IDEA
Ryan
Old 01-17-2016, 09:20 PM   #173
Possmguts
Possmguts's Avatar
It takes me a while to build myself up to get something like this done.. I have been looking for a better door, but havnt found one.. still gotta do bottoms on both doors too... Once I get to the wiring part, thats where stuff starts flying around the garage...
Old 01-18-2016, 09:46 AM   #174
lower50's
lower50's's Avatar
Looks good Poss. Sway bar looks better the way you have it now. Keep it up and before you know it you will be driving it.
1951 MG TD
Old 01-18-2016, 11:57 AM   #175
jlsanborn
jlsanborn's Avatar
Nice work on the door!
I may have gotten one of the first ones out of Rob. Had to wait quite a while for mine. I did have to move it forward for clearance. I set a couple of the cross rails on the frame and then spanned across those with a straight edge. It was a tight squeeze on mine.
