Old 03-22-2016, 08:12 PM   #151
Average Joe
Average Joe's Avatar
Re: What did you do to your Suburban Today?
Originally Posted by RedRoad View Post
Polished and detailed some old hubcaps. Hope they dont pop off the rims when I hit a bump!
Looks great!
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 03-28-2016, 03:53 PM   #152
highwinger
highwinger's Avatar
I took last week off work to remove some rocker rust and a couple other odds & ends. The angle grinder & I have seen enough of each other for a while now.
highwinger is offline   Reply With Quote
Old 03-28-2016, 06:04 PM   #153
4shongo
A little cleaning, topped off the fluids, adjusted the fan relay, and charged the A/C with a few ounces of refrigerant. I'm ready to ride!!!
4shongo is offline   Reply With Quote
Old 03-28-2016, 06:21 PM   #154
BK72BURB_3/4Ton4x4
BK72BURB_3/4Ton4x4's Avatar
Replacing my wood floor with sheet metal
If "what I did to my Suburban" includes dropping it off with a local hot rod builder/fabricator to replace my rear wood floor. This fab work is outside of my skill/time level so was better left to expert Brent Jackson http://www.brentjacksonscustoms.com/index.html who just happens to live a few miles from my house. Old wood floor had run its course so rather than replace with wood decided to replace with 12 awg sheet metal.
BK72BURB_3/4Ton4x4 is offline   Reply With Quote
Old 03-28-2016, 06:26 PM   #155
BK72BURB_3/4Ton4x4
Replacing wood floor with sheet metal (more pics)
After cutting out the old wood, had to blast and frame to make up for the gap between 3/4 plywood and 12 awg steel. He's going to weld up all the seams and coat the entire back section with Lizard Skin. Should quiet up the inside and add some good stability to the rig when done.
Old 03-30-2016, 03:03 PM   #156
RedRoad
RedRoad's Avatar
Originally Posted by Average Joe View Post
Looks great!
Thanks! Finally got all 4 on
RedRoad is offline   Reply With Quote
Old 04-05-2016, 11:43 AM   #157
shuegele
Re: Replaced my 2X4 hatch holder with gas struts
Originally Posted by BK72BURB_3/4Ton4x4 View Post
My OE hatch hinges never worked right so I've been using a 2X4 to keep the door from dropping on my head. Finally sourced some gas struts from McMaster: http://www.mcmaster.com/#gas-struts/=10gvykk and now the hatch stays up by itself!
Do you have the exact pn for the strut that fits?
shuegele is offline   Reply With Quote
Old 04-05-2016, 11:56 AM   #158
BK72BURB_3/4Ton4x4
Yes, here is a copy of the spec sheet an PN from McMaster:
http://67-72chevytrucks.com/vboard/s...&postcount=110
Old 04-05-2016, 12:22 PM   #159
shuegele
Re: McMaster-Carr PN 4138T585
Here's the strut I used...specify the 50lb version
Thanks I appreciate the info.
Old 04-07-2016, 12:02 PM   #160
Burban67
Installed a Lokar floor shifter on my th350.
Burban67 is offline   Reply With Quote
Old 04-07-2016, 07:46 PM   #161
Franks 72
Franks 72's Avatar
Brought Franks 72 home from the paint shop. We choose to do the interior first then assemble (hang doors etc) to avoid over spray. Dads old truck was never this shinny !
Franks 72 is offline   Reply With Quote
Old 04-12-2016, 05:57 PM   #162
BK72BURB_3/4Ton4x4
Wow, paint looks great. Is that the factory Ochra color?
Old 04-12-2016, 06:20 PM   #163
BK72BURB_3/4Ton4x4
Rear Floor installed and Lizard Skinned
Metal floor is done and coated with POR15 and lizard skin. Finally solid enough to mount up the new shoulder harness seat-belts from Juliano's. Feels a little safer with the kids rolling down the highway.
Old 04-12-2016, 09:12 PM   #164
Franks 72
Franks 72's Avatar
Yes , single stage Ochra . It really pops ! Can you send photos showing your rims and tires ?
Old 04-13-2016, 12:23 PM   #165
BK72BURB_3/4Ton4x4
I have a few pics in my photo album, I think this is view-able by anyone?
http://67-72chevytrucks.com/vboard/a...p?albumid=1928
If you'd like any others I can snap a few and upload them.
Cheers,
Brian
Old 04-13-2016, 09:01 PM   #166
Franks 72
Franks 72's Avatar
That works . Thanks ! Super looking machine !
Old 04-14-2016, 11:35 PM   #167
Average Joe
Re: Rear Floor installed and Lizard Skinned
Great idear! Looks nice too.
Old 04-15-2016, 10:59 AM   #168
Number98
Prestige Worldwide
Number98's Avatar
Got her off the jack stands and out in the sun for the first time in months.
Number98 is offline   Reply With Quote
Old 04-15-2016, 04:50 PM   #169
BK72BURB_3/4Ton4x4
Love that color combo, especially with the patina, cool white steelies, hubcaps, and roof rack...coolness.
Old 04-18-2016, 06:48 AM   #170
Number98
Prestige Worldwide
Number98's Avatar
Thanks!
Old 04-18-2016, 11:26 AM   #171
Dburger
Dburger's Avatar
Discovered another flat on my '69. Just replaced the left rear tire which kept going flat, and now this one goes flat...
dslr40 052crop by FordTorino73, on Flickr
As for the other two, grass has started growing around them
1953 Suburban Carryall 3106, 1993 S10 4x4 ext cab
1958 Suburban Carryall 3116 ex school bus
1959 Apache 36, 1984 C30 3+3 DRW 6.2 4MT
1967 C10 fleetside LWB, 1969 Chevy Suburban C10
1972 GMC Suburban C10
1972 Chevy Suburban C10 clam shell/tailgate
Dburger is offline   Reply With Quote
Old 04-21-2016, 04:44 PM   #172
RedRoad
RedRoad's Avatar
Finished rebuilding the SM465 and started working on the NP205.
I find it VERY difficult to get things done during babys nap time! Only an hour or so a day with no loud noises makes it slow going.
Old 04-24-2016, 10:33 AM   #173
Hart_Rod
Hart_Rod's Avatar
Installed new door handles and sport mirrors, !
Hart_Rod is offline   Reply With Quote
Old 04-24-2016, 11:15 AM   #174
Average Joe
Nice work! That looks great.
Its tough working around nap times. Im glad were past that stage.
Old 04-24-2016, 11:17 AM   #175
Average Joe
She's coming back to life!
