Old 04-14-2010, 09:37 PM   #176
tommys66
Re: Tommys66 Build
Originally Posted by daverod View Post
I like the mass of wires above the spark plug wires.
is that not how it goes?
I love the smell of lead paint!
tommys66 is offline   Reply With Quote
Old 04-19-2010, 09:59 PM   #177
TimE
Hey Y'all!!
TimE's Avatar
Re: Tommys66 Build
Sorry for the wrong part # on the wires. I didn't consider the difference between the coils setups.
Gotta tell you though, your build has a lot of great info. Great job!!
Just hopin' I live long enough to finish something!!!
TimE is offline   Reply With Quote
Old 04-19-2010, 10:25 PM   #178
tommys66
Re: Tommys66 Build
not a problem...without the wrong number, I may not have found the ones that I did.
thanks
Old 04-20-2010, 12:22 AM   #179
daverod
SSN 706
daverod's Avatar
Re: Tommys66 Build
That's the way I'd do it. I think you have the red one hooked up wrong though.
daverod is offline   Reply With Quote
Old 05-01-2010, 10:39 PM   #180
tommys66
Re: Tommys66 Build
well, I hope your wrong!! Its gonna get a smoke test one of these days
Old 05-01-2010, 10:48 PM   #181
tommys66
Re: Tommys66 Build
ordered a radiator from jegs, It is the chevrolet universal fit. dimensions are 26" wide, and 19" tall. it came with universal mounting straps, also got a polished cover for the top. I am not sure how to mount this thing....can I set the bottom in rubber pads as is or do I have to make a cover for the bottom?
Old 07-13-2010, 05:34 PM   #182
tommys66
Re: Tommys66 Build
Still working on radiator brackets, In the mean time I made the brake lines for the rear end. The only problem with the lines is I need a way to secure them. I don't know what was used on this rear end originally.
Old 07-13-2010, 06:10 PM   #183
Hart_Rod
Hart_Rod's Avatar
Re: Tommys66 Build
Cool build! Any pictures of where you bolted you oil dipstick to the motor? TIA.
R/
Hart_Rod is offline   Reply With Quote
Old 07-13-2010, 08:31 PM   #184
Strodder
Daring to be Different
Strodder's Avatar
Re: Tommys66 Build
It's coming along really nice. Good job.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 07-13-2010, 08:31 PM   #185
daverod
SSN 706
daverod's Avatar
Re: Tommys66 Build
Mine are held on with a little metal tab just welded to the axle. It just bends over the brake line. Looking gooood. I want one.
Old 07-13-2010, 08:46 PM   #186
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: Tommys66 Build
Nice work Tommy. I made a cover for the bottom of my radiator for more support so the coils don't crush.
Alan's Classic is offline   Reply With Quote
Old 07-13-2010, 09:01 PM   #187
tommys66
Re: Tommys66 Build
R/
this is the only pic I have. it is a lokar dipstick. It just presses into a rubber grommet at the block, and I haven't decided where to bolt the bracket to.
Old 07-13-2010, 09:02 PM   #188
tommys66
Re: Tommys66 Build
thanks, it is goin slow right now cause it's just too hot in the shop!
Old 07-13-2010, 09:03 PM   #189
Hart_Rod
Hart_Rod's Avatar
Re: Tommys66 Build
I've got the same one, but there doesn't seem to be an obvious place that "it" wants to bolt to, .
Old 07-13-2010, 09:03 PM   #190
tommys66
Re: Tommys66 Build
well I've already painted the rearend, so i was looking for something that wraps around the tube, like on the late model chevys
Old 07-13-2010, 09:05 PM   #191
tommys66
Re: Tommys66 Build
thanks, if the brackets i am making don't workout I will have to do that.
Old 07-13-2010, 09:08 PM   #192
tommys66
Re: Tommys66 Build
I think it is too short for this application, but it was too expensive to not use! Prolly have to make a bracket for it. had to make brackets for everything else so far, so why not this too.
Old 07-14-2010, 12:28 AM   #193
daverod
SSN 706
daverod's Avatar
Re: Tommys66 Build
Oh, like a zip tie
Old 07-14-2010, 01:02 AM   #194
muddpile
muddpile's Avatar
Re: Tommys66 Build
I pictured a zip tie right at that moment too. I've seen them used for some pretty crazy things.
muddpile is offline   Reply With Quote
Old 07-14-2010, 10:50 AM   #195
Dinos63
chevy only
Dinos63's Avatar
Re: Tommys66 Build
Nice work kat! Very slick
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 07-14-2010, 11:26 AM   #196
tommys66
Re: Tommys66 Build
Oh, like a zip tie
well, a little more ingenuity than a zip tie, maybe a hose clamp
yep, i use them for everything!
thanks
Old 07-24-2010, 11:16 PM   #197
structures
structures's Avatar
Re: Tommys66 Build
Where did you get your driveshaft?
Robert
1965 Chevy C10
http://67-72chevytrucks.com/vboard/s...d.php?t=374373
1997 Chevy K2500 6.5 diesel
structures is offline   Reply With Quote
Old 07-25-2010, 10:59 PM   #198
tommys66
Re: Tommys66 Build
I had it made at a machine shop. I think it was around $300
Old 08-12-2010, 08:27 PM   #199
tommys66
Re: Tommys66 Build
got my power steering hoses made. had to buy an adapter fitting(from napa) to go from the o-ring to flare fitting.
Old 08-12-2010, 08:33 PM   #200
tommys66
Re: Tommys66 Build
got the firewall and interrior painted. went with ppg vibrant blue.
