Old 02-20-2013, 05:42 PM   #176
theastronaut
theastronaut's Avatar
Re: '55 International Metal/Body/Paint Work
Once the front of the bed sides were straightened and squared I fitted the header panel, primed it, and drilled holes for the plug welds.
The original header panel had extended bottom corners that I needed to replicate.
The corners fill in these gaps on either end of the header.
New pieces welded on.
With the bottom corners finished it was time to weld the header in place. I started from the bottom center and worked outward, keeping clamps on either side of each plug weld spot while welding.
The sides were butt welded to the bed corners.
And a tube was welded across the top to replicate the boxed section on the original header. The gap between the floor and header will be seam sealed just like the bed sides were. .
theastronaut is offline   Reply With Quote
Old 02-20-2013, 05:51 PM   #177
dantimdad
dantimdad's Avatar
Excellent work!
What brand of seam sealer do you use?
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline   Reply With Quote
Old 02-20-2013, 09:55 PM   #178
theastronaut
Originally Posted by dantimdad View Post
Excellent work!
Steven
Thanks! I use SEM 39377 two-part on normal seams like the bed floor. For drip rails I like to use Fuzor Self Leveling two-part sealer.
Old 02-20-2013, 10:22 PM   #179
duallyjams
duallyjams's Avatar
I think you really have a calling to become a teacher.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 02-21-2013, 12:47 AM   #180
theastronaut
It would have to be teaching adults, I don't think I could deal with the attitudes that most high school or tech kids have for very long. I'd have to kick most of them out so I could actually spend time teaching the ones that wanted to learn instead of herding the ones that are just there to pass a class. Or atleast that's the way it was when I went to Greenville Tech- 20-25 in a class and 5-8 that really wanted to learn it for a career. It has crossed my mind though.
Old 02-26-2013, 10:17 AM   #181
theastronaut
Since the metalwork on the bed is mostly finished up I moved to the fenders.
The left fender had a few cracked areas that I cut out and replaced. I also had to drill out the brace and fix it.
Old metal cut out, new metal ready to be welded in.
Fixing the other cracked spot.
Brace welded up, backside of brace and inside of fender coated with etch primer before welding.
Old 02-26-2013, 10:26 AM   #182
theastronaut
The right fender was in worse shape, nearly the whole back edge had to be cut out and replaced. There were tons of cracks/splits that had been reinforced with sheetmetal riveted in place.
"Pat. Apr. 13 1920" on the patch!
Matching the rounded edge on the patch to the original fender lip.
Patch welded in and smoothed.
New corner brace just like the original.
Test fit the brace and prepped it for welding.
Old 02-26-2013, 10:32 AM   #183
theastronaut
The right fender didn't fit the bedside stamping, there were dips and waves around the mounting flange.
Made a template of the stamping shape.
Made reference marks to line up the fender to the template.
Dips show up against the template.
Game plan for straightening, I'll use the shrinker/stretcher.
Set up a stand with the shrinker/stretcher inside.
Dip gone from the top after a few rounds of shrinking/stretching.
Test fit on the truck, still need to work on the corners and allow room for the fender beading.
Old 02-26-2013, 10:35 AM   #184
theastronaut
After reshaping the right fender edge, test fitting with the fender beading. Even gap and the beading fits flush against the bedside.
Old 02-26-2013, 12:00 PM   #185
dantimdad
dantimdad's Avatar
Very nice!
Question: What are you using to roll the edges? I am starting to look at metal working equipment so I can stop using a vise, sandbag and hammer for everything.
Steven
Old 02-26-2013, 01:47 PM   #186
theastronaut
Very nice!
Steven
The brake I'm using is adjustable to make different radius edges; you move the upper clamp part (don't know the technical name) back to make the roll bigger. On the bigger radius edges I have to make them by hand using tubing and a hammer.
Old 02-26-2013, 04:37 PM   #187
plainred65
plainred65's Avatar
Fantastic job, I always look forward to updates on this truck! The picture taking and documentation is first class and I know it's gotta slow you down at times. Much appreciated.
plainred65 is offline   Reply With Quote
Old 02-26-2013, 06:37 PM   #188
flashed
Amazing attention to detail ,its going to be very nice .
flashed is offline   Reply With Quote
Old 02-26-2013, 11:27 PM   #189
Southcity
Southcity's Avatar
X2^ - it's all in the details isn't it? your attention to detail, vision and skills are exemplary.
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 02-27-2013, 01:30 AM   #190
classicchev
classicchev's Avatar
Slip roll!!
67- 72 Parts collecter
classicchev is offline   Reply With Quote
Old 02-27-2013, 10:40 AM   #191
theastronaut
I just use my Iphone's camera so it's not that big of a hassle.
Thanks!!
Originally Posted by classicchev View Post
Slip roll!!
My buddies shop has one but it's so big that it won't make a small enough radius for fender edges or that kinda stuff. I have used one before though and they're pretty neat!
Made a rear shelf panel for a Nova that curved into the backrest and console using a slip roll.
Old 03-13-2013, 09:35 AM   #192
inovermyhead
Any new updates? And what's up w/that Nova?
81 GMC C15 RC SWB 5.3L 4L80E project
inovermyhead is offline   Reply With Quote
Old 03-13-2013, 10:01 AM   #193
theastronaut
The Nova was another shops project car. Dad took it in to do the interior but the owner had to stop progress due to health issues last summer. Not sure when or if we'll get to finish it.
On the '55, I've got the left fender straightened and prepped for epoxy, will be spraying it and a couple of the wheels today. Dad took in a '66 F100 for a full restoration so I'm having to split my time up now.
Old 04-12-2013, 04:44 PM   #194
theastronaut
Been awhile since I updated this, I'm still working on it though progress has slowed a bit since taking more restoration projects at the shop. We started on a '66 F100 about a month ago, and that's been taking up a good bit of time.
Here is the process to straighten the driver side fender. The wheel opening was crushed in on the back edge and there were dents everywhere.
Comparing the shape with the flexible straight edge, shows about a 1/4" gap.
Kink in the inner flange.
Kink straightened.
Working out the crushed spot.
Dents marked... I had to sharpen the pencil a few times to get them all
Overall shape of the crushed spot is back where it should be.
Dents fixed, metal shaping done and ready for epoxy and skim coating.
This angle shows the wheel opening shape pretty good.
Old 04-12-2013, 04:56 PM   #195
theastronaut
I sprayed a couple coats of PPG DPLF and let it sit overnight, then scuffed it and skim coated the fender with 3M Platinum. Platinum is pretty thin so its great for skim coating large areas and making sure it goes on thin- only about 1/16".
Starting to block the filler down.
First round of Slick Sand after blocking the filler with 36/80/180.
Second round of Slick Sand, ready for final blocking and shooting with tinted K93.
Here's a vid of me skim coating the front fender.
Old 04-12-2013, 05:00 PM   #196
theastronaut
I had two of the wheels blasted so I prepped them with PPG DX metal cleaner and metal conditioner, then shot them with PPG DPLF epoxy.
Had a couple spots that needed filler.
Shot with three coats of PPG K36 and guide coated.
Wetsanding with masking tape to protect the center from stray sanding gouges.
And painted...
Old 04-12-2013, 08:52 PM   #197
duallyjams
duallyjams's Avatar
So where's the thread for the other resto projects.
James
IG duallyjams
Old 04-12-2013, 09:20 PM   #198
theastronaut
I started one for the F100 on a F**d truck forum but those guys just wanted to pick the details apart right off the bat... not sure if I'll stick around over there yet. I'll post one up here in the alternate tinkerings section eventually. Don't have one for the El Camino, but here's a link to our shop's facebook pics of it:
https://www.facebook.com/media/set/?...1&l=2783d0dd09
Old 06-12-2013, 11:11 AM   #199
theastronaut
Got started back on the '55 after a bit of a break. The rear fenders are bodyworked and ready to wetsand/paint.
First round of Slick Sand.
Reprimed, ready for 2nd round of blocking.
The passenger fender had a crack. Forgot to take pictures of this after it was fixed.
Passenger fender primed and blocked.
Both fenders shot with tinted PPG K93, ready to wetsand and paint.
Old 06-12-2013, 12:18 PM   #200
dantimdad
dantimdad's Avatar
Very slick!
