Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 11-25-2012, 07:58 PM   #176
YBNORML
YBNORML's Avatar
Re: 72 Dropmember Suburban
Awesome!! One of my favorite color combos. I cant wait to see it all reassembled.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 11-25-2012, 08:33 PM   #177
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks *****in!!!!!
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-27-2012, 09:20 PM   #178
blfuller123
blfuller123's Avatar
Well I have been talking to Mar-K about getting the upper trim and they are telling me they are not going to be able to make the upper trim that I am looking for. Anyone have any other suggestions?
blfuller123 is offline   Reply With Quote
Old 11-27-2012, 09:48 PM   #179
Hart_Rod
Hart_Rod's Avatar
Are you talking about the truck upper trim? Who did you talk to?
Hart_Rod is offline   Reply With Quote
Old 11-27-2012, 09:55 PM   #180
Hart_Rod
Hart_Rod's Avatar
You need to talk to James. He's the one that I worked with for the trim on my suburban. I'm pretty sure he told me that that made several sets.
Old 11-27-2012, 09:56 PM   #181
blfuller123
Yes the upper trim. I was talking to someone named Vickie and she was talking to James. They did remember your burb. They said they didnt have the tooling to make make the curve to match the body line and it wouldnt fit right.
Old 11-27-2012, 10:13 PM   #182
Hart_Rod
Hart_Rod's Avatar
I'm not sure what she's talking about. All they did for me was to make the truck bed piece longer. No special tooling was required. Send her these pictures to help remind her, .
Old 11-27-2012, 10:52 PM   #183
blfuller123
I was playing email tag with them today. Ill give them a call tomorrow and see if I can get another answer. I did just forward them your pictures.
Old 11-28-2012, 09:43 PM   #184
blfuller123
Got the wind shield installed, the hood set and the cowl on today.
Mar-K is supposed to be sending me some information on the upper trim tomorrow. I think (hope) it is going to be able to work.
Old 11-29-2012, 12:14 AM   #185
gumbys10
Please let us know how you make out, as I am looking to get a upper set of trim as well.
gumbys10 is offline   Reply With Quote
Old 11-29-2012, 11:30 AM   #186
stanton77
x2 on the info you find out about the upper trim. I'm looking for a set for my burb.
Thanks,
Mike
72' Family Truckster
stanton77 is offline   Reply With Quote
Old 11-29-2012, 04:36 PM   #187
blfuller123
I tried getting the rear side glass installed and Im stumped on how to get them in. I may end up calling a glass company to install them, anyone have any tips?
I got an email back from Mar-K and I dont get what they are telling me. They say they have the trim and I can get it long enough for the suburban, but it wont fit right because of a body line the suburban has. Here are the pictures they sent to me showing why it wont fit correctly.
Old 11-29-2012, 04:41 PM   #188
Hart_Rod
Hart_Rod's Avatar
Looks pretty close to me, I bet you could make it work. I would find a used piece of bed trim and try it out first, before you purchased the new stuff.
Old 11-30-2012, 11:51 AM   #189
BIGMAC68
BIGMAC68's Avatar
Maybe I can shed some light on this issue. This is James at Mar-K. One of the things that made the bedside trims work for "Hart Rod" is that he modified the rear ends of his bedside area on his Suburban. He grafted the Fleetside bedside ends to his Suburban. The Fleetside bedside ends have a slightly different shape (less curve inward at taillight area) to them than the Suburban. It is not an up and down curve issue. What the pictures are trying to show is that the trim leaves the body surface the last 1" or so on a stock Suburban. These trims do not like to bend much without cracking the finish. This is the reason for us not selling these to fit the standard Suburbans. We will sell them as long as you understand what you are getting. Also, you will need to use all bolt in clips on the front fender upper trim. This trim is die stamped instead of roll formed. The adhesive clips will not fit this trim. The reason I'm telling you this is that the front fenders will need to come off to install the front fender upper trim. I hope I did not just rain on your parade.
99 GMC extended cab/99 Chevy suburban
89 Chevy Long bed Extended cab on air ride
71 Chevy long wide/70 Chevy short wide
68 Chevy short wide/68 Chevy short step
68 Pontiac GTO
51 Chevy five window 1/2 ton short bed
50 Studebaker 2-door sedan
50 Ford 2-door sedan with flat head v-8
49 Studebaker pickup
40 Dodge flat bed truck
BIGMAC68 is offline   Reply With Quote
Old 11-30-2012, 01:42 PM   #190
blfuller123
Thanks James. No you didnt rain on my parade at all.
Here is a picture I just took looking down. I put a straight edge on the back where I would like the trim to go and I do see the gap and it seem very minimal in my opinion and it seems like it could be bent. It looks like difference in the curve is less than 0.25 inch over a 6 inch span. I think I am going to do what Rob suggested and find an old piece and see if I can get it to bend without damaging it.
Old 12-02-2012, 06:41 PM   #191
gumbys10
Thank you for the info James. I am sure I can massage it to fit how I want, so I am still gonna order a new set.
Old 12-02-2012, 07:16 PM   #192
blfuller123
If you get a set and get it installed before I get a scrap piece, can you let me know your results?
Old 12-03-2012, 10:31 AM   #193
blfuller123
She is off the jackstands now. I have to work for the next week or so no more progress until I get back.
Old 12-03-2012, 10:50 AM   #194
jasonhall
jasonhall's Avatar
Cool !!!
jasonhall is offline   Reply With Quote
Old 12-03-2012, 11:02 PM   #195
gumbys10
I'm sure you'll be ready before I am. I do not plan to put them on till i do paint in march/april, I have to put the air ride in and new drivetrain first. I hope to start that at christmas.
Your burb is looking great, I would love to go blue and white like you, but I do not have the cash to redo the interior to match. Love the aired out pic, cannot wait to see it done. I even like the dog dish look.
Old 12-05-2012, 03:23 PM   #196
jeffg1010
jeffg1010's Avatar
Ironically, i am also looking for this trim to redo mine before we go on the Hot Rod Power Tour. I emailed Mar-K and they actually directed me to this thread to talk with you guys. Is anybody doing this soon?
Jeff
1972 Blazer CST 2wd- My son Sam's Project "S" Project "S"
1970 Suburban - SOLD "One Bad Burb" Photobucket Album
1986 C30 Crewcab - 63K original miles, original paint
Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP...
jeffg1010 is offline   Reply With Quote
Old 12-10-2012, 06:10 PM   #197
blfuller123
I will probably order trim in another month or two. I have to get the paint sanded and buffed first.
Speaking of color sanding and buffing, I got started today and it is going to take a while to get it done. I started working on half of the hood today and im really happy with the results. I may go ahead and get it moved back over to my garage this week too, gotta clear out some stuff first.
Old 12-10-2012, 06:20 PM   #198
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Paint looks great.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 12-10-2012, 07:52 PM   #199
Splash4195
Cool Build!
Splash4195 is offline   Reply With Quote
Old 12-13-2012, 08:21 AM   #200
blfuller123
I broke down yesterday and called the glass guy out to install the back windows...I have to say that was money well spent. I also got the weather stripping in.
Got a little more of the sanding and buffing done. Not bad for a garage paint job.
Im hoping to get her moved home to my garage today. My wife says the suburban is my mystress and so she has a name....Alice
