Old 07-12-2012, 10:45 AM   #201
82ccshorty
82ccshorty's Avatar
Re: Project: B.A.D. 1976 K30 CCLB
Originally Posted by Dieselwrencher View Post
Here is a little something to look at while I work on rounding up money to buy new parts and paint for this truck.
I went ahead and cut off the rear portion of the frame because it looked goofy when I notched it.
In case any one is curious, 4 out of the 8 bolt holes worked for the bed. I only have to drill 4 new holes and the bed will be totally bolted down.
was it hard to make that front end work on a 76? i want to do this to my 76. i have everything but that cowl panel behind the hood.
1969 chevy camaro Z28 #matchin Factory 4wheel disc
1969 chevy cst10 big block overdrive 5/7 drop dog dishs
1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s
2004 gmc sierra dually 4/4 lowering daily driver
82ccshorty is offline   Reply With Quote
Old 07-12-2012, 04:22 PM   #202
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
The fenders and rad support are cake. The hood and hinges require cutting the firewall and making holes for the 81 up hood dinges. Then you have to adapt the hinges to the firewall. You slao have to make mounts for the cowl pins to set in. I decided that was more work than I wanted to spend on this thing, so I purchased a 74 front clip for this truck. The hood is just setting on there in the pics.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 07-12-2012, 04:24 PM   #203
82ccshorty
82ccshorty's Avatar
Would you still sell the truck? I really liked it better with the big lift and tires.
Old 07-12-2012, 04:27 PM   #204
Dieselwrencher
Yeah, everything has it's price.
Ryan
Old 07-12-2012, 04:30 PM   #205
82ccshorty
82ccshorty's Avatar
in this picture how much lift did it have? i know where there is a 4x4 80 model dually for sell and i would love to make it that big.
Old 07-12-2012, 04:31 PM   #206
Dieselwrencher
It had about 20" of lift and the tires were 52". Some people say they are 53". I never really measured them.
Ryan
Old 07-12-2012, 04:37 PM   #207
82ccshorty
82ccshorty's Avatar
What all did u do? I seen it said 12 inch springs
Old 07-12-2012, 04:41 PM   #208
Mattman2010
Mattman2010's Avatar
He has a 4x4 welded to the bottom of the frame for the front springs to mount, and a longer shackle for the rear of the front spring and also looks like a 4 inch body lift.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 07-12-2012, 08:22 PM   #209
Dieselwrencher
You're almost right.
It had a 3" body lift, shackle flip in the rear with 8" springs and a 4" block. It had 12" springs in the front with a 4"x4" 1/4" thick tube that the spring perches are wlded to, and the front shackles were longer. I moved the shackles back in the frame to give it more lift as well. It sat 22" taller with 235's on it that a stock height K20 did with 235's on it.
Ryan
Old 07-12-2012, 09:06 PM   #210
82ccshorty
82ccshorty's Avatar
I think I'm going to just do 12 inch springs and 4 inch blocks and run like 44s
Old 07-28-2012, 10:11 PM   #211
atvpro
atvpro's Avatar
Well Ryan. thanks to you, I have just thrown another iron in the fire.I posted it on my crew cab thred.
atvpro is offline   Reply With Quote
Old 08-29-2012, 01:19 PM   #212
Ackattack
Ackattack's Avatar
I might get the truck put together in August. We'll have to see.
August is almost up, are ya done yet?
Ackattack is offline   Reply With Quote
Old 08-29-2012, 01:43 PM   #213
Mattman2010
Hahaha I don't think this thing has been touched sense he posted that tbh!
Build Thread
Build Thread
Thread
Old 08-29-2012, 04:56 PM   #214
6lcummins
He has been focusing on a customers truck this month trying to finish that conversion.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
Old 08-29-2012, 05:15 PM   #215
Dieselwrencher
Between that and the Longhorn, plus we just finished our friend's pulling truck. We need more hours in the day.
Ryan
Old 08-29-2012, 05:26 PM   #216
Mattman2010
I know what he's been up to, I seem to get random pictures sent to me of his progress on stuff.
I think there is a cummins that needs to be torn apart and put back together if I remember correctly and if I had a dollar for every time you said you need more hours in a day I'd have you payed off by now!
Build Thread
Build Thread
Thread
Old 08-29-2012, 09:10 PM   #217
6lcummins
I know what he has been doing too, I keep tripping over it...
It will help when I have all the right parts for my truck so I can stop playing with it. Maybe ill ake a head off a Cummins someday and see what it looks like...
"STOCK"
ASSEMBLY THREAD
Old 08-29-2012, 09:22 PM   #218
Mattman2010
Haha I bet he has a ton of stuff and he keeps telling me he is thinking about buying another project... That's all he needs. What all are you
Doing to your truck?
Build Thread
Build Thread
Thread
Old 08-29-2012, 09:57 PM   #219
6lcummins
Tryin to put a bigger drivershaft in, reverse light, front bumper if its ever done, new "regulator" for fuel system, and a few other things to have done for this weekend.
"STOCK"
ASSEMBLY THREAD
Old 08-29-2012, 10:13 PM   #220
Mattman2010
Is there something this weekend or just trying to get it done? Are you going to the truck show with Ryan the 8th?
Build Thread
Build Thread
Thread
Old 08-29-2012, 10:34 PM   #221
6lcummins
Im pretty sure im going lol and there is a 2 day sled pull this weekend
"STOCK"
ASSEMBLY THREAD
Old 08-30-2012, 12:20 AM   #222
Mattman2010
Sounds like fun, if you are there then I probably will see you there. Is Ryan making you work on my motor? Lol
Build Thread
Build Thread
Thread
Old 08-30-2012, 02:30 AM   #223
Dieselwrencher
Listen to you two ladies. Blab blab blab. Get to work punks!
Ryan
Old 08-30-2012, 08:46 AM   #224
Mattman2010
You keep saying there is not enought time Ina day, so why are you wasteing time on the computer?
Build Thread
Build Thread
Thread
Old 08-30-2012, 07:42 PM   #225
Dieselwrencher
Cause I should have been sleeping ITTO.
Ryan
