11-27-2014, 02:31 PM | #201 |
Re: 55 TF Stretched Cab/Fleetside/LSx/Trailblazer Frame
Awesome! What a cool power combo for this build!
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
11-27-2014, 08:18 PM | #202 | |
Thanks for the comment. I love how the 6.0 engine in our GTO runs, and can't wait to get this one on the road. Here is a picture of the headers and assorted other parts that need to be installed. We will see what happens on Saturday. Ricky
Rick's 55 TF/Fleetside/LSx build 1958 Corvette LS1/T56 Build 1966 GTO LQ9/T56 Restomod |
12-03-2014, 06:59 AM | #203 |
Gotta catch up with the progress. You are really moving. Sent you a PM regarding local stuff. Dug
My Build - http://67-72chevytrucks.com/vboard/s...d.php?t=515876 |
12-03-2014, 09:45 AM | #204 |
Dug,
Thanks for checking in. Would you resend the PM? I checked my in box and didn't have anything. I going through withdrawal on your build - please post up some current pictures. I'm currently trying to get the radiator/fans to fit in (I want to use the Camaro fans, if possible) and having issues making it work. I might give you a call this weekend if I can get back on the truck then. I'm in Dallas this week working, so no evening time. Ricky
12-03-2014, 02:01 PM | #205 | |
12-09-2014, 08:47 PM | #206 |
Last weekend I worked a couple of hours trying to get everything mocked up under the hood. I want to use a Camaro radiator/fan/AC condenser in my truck as it will cut down on fab time, the parts are readily available, and it has worked great on the GTO. I have a Camaro radiator and fan that were damaged that I use for this purpose. I could not get everything under the hood using the "truck" pulley system. By using the "Corvette" pulley system (1 and ½ inches shorter) and a 2006 corvette water pump, I will able to come up with all the room I need. In this picture I have the "Holley" mounting brackets I bought to use on another project as a test fit – I will use this setup. Here is the truck with everything in its "approximate" location (and using a corvette/Camaro water pump from 2002 – but because the 2006 water pump pulley is a lot closer, when I get it bolted on it will free up more space).
The rest of my time was spent pulling and disassembling the steering column from the GTO. While in Dallas last week someone attempted to steal the car. I was parked in a out of the way spot in downtown Dallas (I park in this lot all the time-but in a lot more visible spot- where I can see the car from my 37 floor office window). I was working late, and I found the car with the door opened and the steering column trashed. The thief knew what he was doing, thank goodness, and was careful not too damage anything else. Because I have the theft system turned on in the GM computer and the PASSKEY wired up, he could not get it to crank (or do anything) without using the correct key. Eric and I will be doing additional upgrades to the theft system, but I'm glad the passkey worked like GM designed! I have another column that I use to mock up with, so I pulled the parts needed to fix the GTO from it, and spent about 10 hours figuring it out. We were very Lucky - and I am thankful. Ricky Time spent : 3 hours Total time: 134
Rick's 55 TF/Fleetside/LSx build 1958 Corvette LS1/T56 Build 1966 GTO LQ9/T56 Restomod Last edited by ricott; 12-09-2014 at 08:53 PM. |
12-10-2014, 12:07 AM | #207 |
Man oh man, downtown Dallas! You are truly one lucky guy. I wouldn't park anything I wanted to keep there. I've heard of them loading cars on roll back wreckers to steal them.
12-10-2014, 07:33 AM | #208 |
So, you are fabricating your own core support or going with the factory one? Love the engine paint. Fits like a glove.
On a positive spin, the GTO is soooo nice somebody tried to steal it. Kind of an underhanded compliment. Congratulations?...and good job keeping the security in place.
12-10-2014, 08:46 AM | #209 |
Yes, a beautiful car. And a theft system that worked. The extended cab project is just a fantastic build.
12-10-2014, 11:45 AM | #210 |
Very cool that you left the anti-theft active in the Goat and that it worked for you. Nice work on getting the engine bay laid out too, looks great!
12-22-2014, 09:29 PM | #211 |
Thanks everyone for your comments. Today marks the end of the first year of this build - and I've spent 142 hours (give or take a few) getting the truck to this point. I've not had any real time since Thanksgiving to work on this truck - the only real block of time was pulling three Trailblazer EXT gas tanks to find one that was not cracked at the gas inlet (It was an 06). It turns out the 2003-2004 EXT tanks had a defect in attaching the filler neck that caused them to break. GM warrantied all EXT tanks for those years for 10 years/150K miles - free replacement. Since we are outside the window (and I couldn't drive the EXT to the Dealer!!!), I picked up a 2006 tank, but that required changing the pump for the 2005 and up design.
The Headers have been installed, and most of the front pulley system. I still need to pull the Harmonic balancer (truck design) and replace it with the Corvette design, and get the power steering pump installed. I have two wiring harnesses from chevy trucks - both missing parts. One is a Drive by Wire, the other is Drive by Cable. I will make one good Drive by Cable out of these after Christmas (just enough to get the truck running). I really want to hear this truck make some noise with open headers! To all those that stop by this build, I hope you have a wonderful Christmas. I always love this time spent with the extended family from both sides! It is always great times. Ricky Time spent 8 Hours Total time 142 hours.
12-22-2014, 10:43 PM | #212 |
Nice progress Ricky, thanks for taking the time to share.
Harness looks a bit intimidating! Merry Christmas to you and your family! |
12-23-2014, 01:17 AM | #213 |
Nice progress.
Merry Christmas. Kim |
12-23-2014, 01:51 AM | #214 |
That's a lot of figgerin on just the fuel tank and pumps, can't imagine the harness and all that jazz you have going! Well done and happy holidays to you too!
12-23-2014, 01:59 AM | #215 |
hey Ricky, nice job. the wiring will be easier than you think. let me know if you are having trouble sorting it out, my buddy is well versed in the quick run harness because he put several in a mustang (blew them all up from too much boost on a worn out motor, but fun while it lasted) i'm sure he would give me a few hints. I am in the same boat as you as far as time. busy at work studying to train the guys on a new computer we will be getting in our fire engiines and studying for a promotion at the same time as daily work stuff and employee evaluations etc etc.
anyay, your progress is coming along pretty good for no time. wish mine looked like that with an engine in the frame and cab installed as well. ready to run, that will be a sweet day. well, hope you have a great Christmas and happy new year. stay safe. dennis |
12-23-2014, 09:30 AM | #216 | |||
Ricky
12-23-2014, 10:57 AM | #217 |
A320 Pilot/USAF Retired
This is going to be one nice ride, hope you can get more time on it after the holidays! Merry Christmas!!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
12-23-2014, 11:17 AM | #218 | |
I'm looking forward to seeing your new frame come together as time permits - I bet you will really enjoy driving the 2.0 version of your truck. Ricky
12-23-2014, 11:27 AM | #219 |
"Version 2.0" I like that!
12-23-2014, 11:55 AM | #220 |
The more I follow along the more you inspire me. Maybe one day we will both figure out how to buy some time and get a chance to meet up.
By any chance have you read through any of clemdaddy threads? He has a get together in October and that is pretty close to you. Have a Merry Christmas and happy New Year. |
01-17-2015, 08:10 PM | #221 |
I hope everyone had a great time over the holidays – we sure did - but it left very little time to work on this project. Now that the holidays are over it is time to get serious on this build. I am committed to spending at least 6 hours a week working on my truck, and more when I can.
I spent a few hours on December 30 pulling the front seats and carpet from a 2004 Trailblazer. The seats/carpet are pretty good, and for $60.00 the price was right. Because I'm using the Trailblazer floor pan, both the seats and carpet will install with very little effort. Over the course of three evenings I pulled the sheet metal from the frame and replaced the cut wires in the Drive by Cable harness I'm using on this truck. By using a Chevrolet truck wiring harness/fuse block, there are only 5 wires (none in the engine harness) you need to deal with to make the engine run (assuming the Theft is OFF in the computer). Because I'm using a Manuel transmission, there are two additional wires (in the engine harness) that must be spliced together to bypass the Neutral Safety Switch that is tranny mounted. I have my trusty engine wiring schematic for a chevy truck for this stage of figuring it out. To make the engine run, I have a 2001 Chevy 5.3 truck computer with the theft turned off. I have used this computer a couple of time to hear "junkyard" engines run before I pull them out. Once a vehicle is up and running, I switch the computer over to one that has been programmed for the specific project. After I got it all ready, I had the WRONG fuseblock (one for a 2003 up Drive by Wire pickup). So the open headers will have to wait for Monday. I will run down to my friend's yard and pull the right fuseblock. Once I finish up the fuel lines and hook up the radiator, I will run the engine for 30 or so minutes (hopefully next weekend), And I will post a video of it running. Body welding begins in earnest after it runs. As always, more to come. Ricky Time spent : 18 hours Total time: 160
Rick's 55 TF/Fleetside/LSx build 1958 Corvette LS1/T56 Build 1966 GTO LQ9/T56 Restomod Last edited by ricott; 01-17-2015 at 08:16 PM. |
01-17-2015, 08:25 PM | #222 |
You make this LS stuff look like Tinker Toys! Can't wait to hear it.
6hrs a week sounds like chum but I know first hand how hard it is to find six solid hours. You sure seem to get a lot done in those hours though
01-17-2015, 09:33 PM | #223 |
Looking good.
Hope you get it running soon. Kim |
01-17-2015, 10:21 PM | #224 |
Ricky that was a great buy on the seats! Looking forward to start up.
01-18-2015, 12:37 AM | #225 |
Man what I wouldn't give for 6 hrs a week to work on my truck. And I'd double that to have some of the LS knowledge you have locked away.
Can't WAIT to see the vid! |
