Old 01-24-2015, 06:44 AM   #201
Step-Ed
Step-Ed's Avatar
Re: Dutch '59 Fleetside Longbed
Originally Posted by RockinKees View Post
What's with Lelystad, Ed??
I thought thats wat you mean by " Dutch freight shop"
Nice project, looks great
Step-Ed is offline   Reply With Quote
Old 01-24-2015, 07:17 AM   #202
RockinKees
RockinKees's Avatar
Thanks Ed,
Our own Dutch Harbor Freightshop is called Hornbach
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 01-25-2015, 05:02 PM   #203
RockinKees
RockinKees's Avatar
Small update, due to my health problems nothing heavy has been done.
I only took the new/old steeringcolumn apart and painted it.
In primer:
And nice black paint:
Hope I can get at it again tomorrow, I want the rear axle out and set the truck at rideheight.
Then I can measure the IRS in.
Cheers!! Kees.
Kool Guyz CC
Old 01-25-2015, 06:14 PM   #204
Clarance J
Clarance J's Avatar
RockinKees. Get better first. We'll wait. Really like what you have done so far. You gave me some ideas about the wiper linkage that I am going to try to solve my problem. Thanks for that and the posts. Hours of good reading on this forum.
You have to have patiences or you'll be one.
Clarance J is offline   Reply With Quote
Old 01-25-2015, 06:37 PM   #205
RockinKees
RockinKees's Avatar
Thanks for your kind words, Clarance J, but I have to live with this problem.
I manage
I have good and bad times, it'll work out
And it's sure is good reading on this forum!!
Cheers!! Kees.
Kool Guyz CC
Old 01-25-2015, 07:25 PM   #206
Kim57
Kim57's Avatar
Looks real nice.
I know what it's like to have chronic health problems. I deal with my back on a daily basis.
Just do what you can and you'll get there.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 01-25-2015, 08:45 PM   #207
oldman3
oldman3's Avatar
Sounds like a bunch of us are in the hurt, take it easy and slow...Jim
oldman3 is offline   Reply With Quote
Old 01-26-2015, 02:41 PM   #208
RockinKees
RockinKees's Avatar
Thank you guys!!
I'm taking it easy and slow.....
Today I got a little help so we got the rearend out and the front springs out (again...)
Took the frontsprings out, because I first want the truck at rideheight, chassis leveled front to rear and left to right.
Put on the frontwheels, set the Jag IRS in his future home.
Now I can measure everything up.
If that's done, I temporary put the engine in to set the pinion/trans at the right angle.
Everything must be done in one "flow", i think, to get things right.
A straightaxle is much easier...but I love a challange now and then
Tommorow afternoon I get back to it, stay tuned
Cheers!! Kees.
Kool Guyz CC
Old 01-26-2015, 08:07 PM   #209
reaper71
reaper71's Avatar
Looking forward to it Kees!!
reaper71 is offline   Reply With Quote
Old 01-26-2015, 08:35 PM   #210
Advanced Design
Advanced Design's Avatar
Good progress Keys!
Seeing less floor space right now too...
Advanced Design is offline   Reply With Quote
Old 01-30-2015, 03:59 PM   #211
RockinKees
RockinKees's Avatar
Well, it took a bit longer to get back at it....
Today I got the IRS measured in, and figured out how I want to do it.
First got the truck at static rideheight
It looks a bit high, but I solve that when all parts are in. It's now 3,5 inch lower as it was. I want it a bit lower than that.
I set the static height at the Jag stock height, under the frontend you've then got 6 3/4", from there I set the frame level and measured the height of the IRS.
I measured the height of the low profiles under the bed, so that I know how much I can come up with the IRS without modifying the bed.
The yellow level is where the underside of the bedprofile sits.
This way I can mount the IRS a bit higher in the frame, so the truck comes down, easy does it
I will make a "H" in between the framerails where I mount the diff at two angled pieces, so that I can set the pinionangle.
Does it make sence??
The front X-member looks like this, I grind it in so it fits around the framerail, the other one gets the same threathment.
To get the back x-member in I had to take out the shockmounts x-member.
When this all fits the way I thought, I tack it together and measure a few times more, put the driveshaft in and try to get the engine at its place.
If that all goes to plan, I can weld the pieces together.
Then I have to find a place to mount the shocks...
If I set them angled to the inside, I must modify the framerail at the lower-inside, or I can mount them at the outside of the frame....any suggestions?
When you read this and you have any tips to do it different or in a better way, please say so.
I learn from critics, and I'm sure I'm not the only one
Cheers!! Kees.
Kool Guyz CC
Old 01-30-2015, 05:31 PM   #212
Kim57
Kim57's Avatar
I've got to say it's looking good.
I have no experience with IRS so I can't give any advice on what's the best way to mount the shocks.
Kim
My build thread
Old 01-31-2015, 06:12 AM   #213
bogape
You're getting on really well here. Puts me to shame, but I have started on mine.
I was thinking when i install my Jag IRS i would not put the diff too high as i don't want to notch the frame rails but want to have the truck low with some travel. Perhaps it doesn't matter that much as the IRS allows a lot more travel than a live axle with the pivot point being so close to the frame rail.
bogape is offline   Reply With Quote
Old 01-31-2015, 10:57 AM   #214
reaper71
reaper71's Avatar
Angled inside would be just fine....just beware of clearance for the exhaust, if you plan on running over the axle.
The outside may be a bit better choice, again be aware of clearance for the bed..
Mark..
Old 01-31-2015, 01:46 PM   #215
OneOffStroker
I would not run your shocks outside, because they might bind. They should be installed at the same angle that they were in the Jag cage. Because the arc of motion on the driveshaft will swing in instead of out, I think the shocks angled the other way, they might bind. Does that make sense?
It is this exact problem that made me put the Camaro suspension in mine until I build a wider frame to mount the IRS the right way.
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292
1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987
Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker
OneOffStroker is offline   Reply With Quote
Old 01-31-2015, 01:58 PM   #216
1958Warrior
1958Warrior's Avatar
Smile Re: Dutch '59 Fleetside Longbed
Glad to see you felling better ,pace yourself so not to make me look too bad.
Looking good so far , interested in seeing how the IRS goes in.
1958Warrior is offline   Reply With Quote
Old 01-31-2015, 06:22 PM   #217
RockinKees
RockinKees's Avatar
Kim57
Kim
Thanks Kim, appreciate you saying that!!
reaper71
Mark..
Mark, the bed isn't in the way of things, thats above it all, exhaust is a problem that will be solved later...
bogape
Thanks! You don't need to notch the frame if you don't want a slammed truck. It will be lower but not that much. The IRS has about 4,5 inch travel.
You mean the pivot point at the diff side of the LCA? That is about 10 inch from the frame.
And you also make sure you make a build thread!!
1958Warrior
Thanks! When I'm feeling good, I'm at the right speed
I don't mean to make you look bad...you have to work a little faster to keep up
I went to see how it will turn out, both ways, regarding the shocks.
OneOffStroker, you are right about binding.
The Jag-angle is 70 degrees to the inside, I think I can put them at 65-60 degrees with a little grinding in the lower framerails. If I grind about one inch out, I should be able to mount the shocks at that angle. If I box that section, it must be good?
I took some pics of it, but forgot to take back my camera
Cheers!! Kees.
Kool Guyz CC
Old 02-02-2015, 11:59 AM   #218
RockinKees
RockinKees's Avatar
Did grind a lot today
This is how the rear X-member is going to be:
I set the pignion angle at 3 degrees, my old driveshaft is a direct fit with the Jag joke, only had to press the U-joint over.
The diff is hanging at two angled strips, which later on will be welded at the cross member. I will have some extra brackets welded on aswell.
After some brainstorming what to do with the rear shocks, I choose the angled inside way.
This because I then can adjust the rear ride height a bit. If I mount them outside the chassis, the shocks will stand straight up and I can't adjust them any more.
So I cut about an inch out of the lower framerail, so that the shocks are somewhat upright.
I will make two or three different pipes where the shocks will be mount at, so its a bit adjustable that way. Only have to think how
The framerails going to be boxed into the new cross member.
This is a small problem, without cutting a piece of the framerails:
I took this part away, later this is going to be all boxed and welded in:
Cheers!! Kees.
Kool Guyz CC
Old 02-02-2015, 08:42 PM   #219
reaper71
reaper71's Avatar
Looking good Kees...very beefy I like it..
Old 02-02-2015, 09:30 PM   #220
Kim57
Kim57's Avatar
Real nice work.
Kim
My build thread
Old 02-03-2015, 12:23 AM   #221
oldman3
oldman3's Avatar
Looks great...Jim
Old 02-04-2015, 12:09 PM   #222
RockinKees
RockinKees's Avatar
Thanks Guys!!
Today I tacked the new X-members in place and went ahead with more pieces of the puzzle.
Trying to get the x-members boxed in...
Made two templates (left and right) and grinded them out of steel:
Tacked those in aswell:
I will box the rear section around the x-members, maybe a bit overkill, but if it works for me, it works for the truck
Going to do the front of the x-member in the same way.
I think it will be strong enough.
Cheers!! Kees.
Kool Guyz CC
Old 02-04-2015, 06:38 PM   #223
Kim57
Kim57's Avatar
That looks to be plenty strong.
Kim
My build thread
Old 02-04-2015, 07:37 PM   #224
Steve-W
Steve-W's Avatar
I see you're going for dual shocks on each side, how did you figure out you would need that? ..or did I miss it in a post?
and will it be adjustable coilovers?
Feedback is always welcome!
projects:
1969 Chevy C10
1950 GMC 100
1958 Chevy C60 Viking ratrod
Steve-W is offline   Reply With Quote
Old 02-04-2015, 08:06 PM   #225
oldman3
oldman3's Avatar
Kees, I agree boxing in frame front,center and rear of crossmember is a good ideal...Jim
