Old 09-27-2015, 02:45 PM   #201
deejaaa1
Re: Dunce's 59 Fleetside build
your build is incredible. fab skills are top notch too. subbed.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 11-03-2015, 11:49 PM   #202
Compton
I think you nailed the ride height!!
Hope mine looks half as good!
Compton is offline   Reply With Quote
Old 11-04-2015, 03:19 PM   #203
dunce79
Got a few more pix.
-swapped out the cam. I miss the big chopping idle of the TRex cam but the 228r has a nice mild lope to it and I have plenty of vacuum for the brakes now. Much more suited for street use now.
-Adjusted the front ride height just a bit and upsized the tires from 255/40/17 to 255/45/17. Now the fronts and rears have the same diameter and the fronts fill out the wheel well better.
-Battled the dreaded LS1 belt chirp issues for a couple weeks and finally kicked its butt. If anyone needs any info on that, hit me up.
-finished wiring my AC/Heat unit just in time for fall weather. Now just need to charge and test AC before next summer.
short idle vid. dropped the idle from 850 down to 750 or so but I think with some tweaking I can drop a bit more and hear more of the cam if I want to.https://www.youtube.com/watch?v=DuRiSy5b0W4
dunce79 is offline   Reply With Quote
Old 11-04-2015, 04:20 PM   #204
Kim57
Kim57's Avatar
Looks real sharp.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 11-04-2015, 08:24 PM   #205
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Truck looks great!
What's the spec's on the rear tire and wheel?
ChuckDriver is offline   Reply With Quote
Old 11-05-2015, 11:20 AM   #206
dunce79
Rears are 285/40/17 on 9.5 inch rim. 5.5 backspace but I'm using about a 1/2 inch spacer. 1970s camaro 10 bolt rear stock width.
Originally Posted by ChuckDriver View Post
Truck looks great!
Old 11-05-2015, 05:52 PM   #207
RockinKees
RockinKees's Avatar
Looks Awesome!!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 11-06-2015, 03:26 AM   #208
ChuckDriver
Thanks!!
Old 01-26-2016, 08:48 PM   #209
Compton
Truck looks amazing!!! You did an awesome job!!
Lets see some more videos when you get the time.
My build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=687265
Old 01-27-2016, 10:43 AM   #210
FarmerSid
FarmerSid's Avatar
Bare steel looks cool!
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 01-27-2016, 04:10 PM   #211
dunce79
Thanks guys! A little update...
-Finally got around to making the bumper brackets after deciding I wanted to install the bumber. Kinda like it both ways but for now, I'll run the bumper.
-Made a cold air box for the air intake and a radiator closeout panel. Box pulls air from behind the grill and the wheel well. Closeout panel fills the gap between the radiator and the core support. I like the look mainly but I think it could also function to prevent hot air from recirculating through the radiator and perhaps improve the efficiency of the condensor.
-Wife bought me a console (for her starbucks cup). I think I'll have the top of if recovered in the same material as the seat
-Most recent proejct is adding 2.5 inches to the rear wheel tubs. I had about 3/8 of an inch clearance on the inside so going around corners or pulling out of the driveway at an angle made it rub pretty good. Plus now I can fit some pretty large tires if I want to later. I don't think I'll ever take it any lower. Not really into the super low stance.. more muscle truck if you know what I mean.
Old 01-27-2016, 05:54 PM   #212
RockinKees
RockinKees's Avatar
Nice!!
Really NICE!!
Cheers!! Kees.
Kool Guyz CC
Old 01-27-2016, 06:47 PM   #213
59chev
59chev's Avatar
Nice! Front bumper really finishes it off.
Where did you get the console for the bench seat from? Fits right in with the rest of the cab.
My Build Thread: 59 Apache - Lifelong obsession
http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession
59chev is offline   Reply With Quote
Old 01-27-2016, 06:49 PM   #214
dunce79
I believe that console was from http://www.cupholdersplus.com/
Old 01-27-2016, 10:16 PM   #215
ChuckDriver
Nice work, beautiful truck!
Old 01-28-2016, 09:22 AM   #216
Kim57
Kim57's Avatar
Very nice looking.
Kim
My build thread
Old 01-28-2016, 08:33 PM   #217
Advanced Design
Advanced Design's Avatar
Really nice metal work. You can't see a seam on the tubs...impressive!
Advanced Design is offline   Reply With Quote
Old 01-29-2016, 05:21 PM   #218
RockinKees
RockinKees's Avatar
What happend to your pics, Dunce79, can't see them anymore??
Cheers!! Kees.
Kool Guyz CC
Old 01-29-2016, 05:27 PM   #219
dunce79
I would say photobucket is having trouble right now as I haven't deleted them. Man that would suck if they are gone. But their website is just timing out for me right now.
Old 01-29-2016, 05:33 PM   #220
RockinKees
RockinKees's Avatar
That should be it then.
I'll just have to wait.....
Thanks!
Cheers!! Kees.
Kool Guyz CC
Old 02-26-2016, 01:18 PM   #221
Zooms_58_Fleetside
Seen this truck in person.......all I can say is WOW! You did one hell of job building this truck.....very impressive and sounds awesome!
Zooms_58_Fleetside is offline   Reply With Quote
